    Duet2 ethernet and 12864 display using ST7567
    42
    3.8k
    • gloomyandyundefined
      gloomyandy @CNCModeller
      @cncmodeller The schematic for the display is here: https://github.com/FYSETC/FYSETC-Mini-12864-Panel/blob/master/hardware/V2.1/Mini12864(RGB)V2.1_sch.pdf
      Looks like the Neopixel control signal is the "Red" pin 5 on EXP1
      CNCModellerundefined 1 Reply Last reply Reply Quote 0
      • CNCModellerundefined
        CNCModeller @gloomyandy
        @gloomyandy said in Duet2 ethernet and 12864 display using ST7567:
        Thanks @gloomyandy I'll give it a go and report back.
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
        • o_lampeundefined
          o_lampe @fulg
          @fulg said in Duet2 ethernet and 12864 display using ST7567:
          M150 is not supported on Duet2 due to lack of memory
          This statement frightens me. I'm planning on writting big(ger) meta command macros for Duet2.
          Now I'm afraid they don't fit....or is the Neopixel library so huge?
            droftarts administrators @o_lampe
            @o_lampe it’s running out of flash ROM space for the firmware, not RAM. Your macros should be fine.
            @CNCModeller I have asked @dc42 if he can add Neopixel support to Duet 2; the other forum post suggested he was going to look into it, and I don’t see a reply about lacking memory (though I know it is tight). If it isn’t possible, I’ll update the documentation to say that only boards with single colour backlight (ie v1.2 of Fysetc 12864 LCD) are supported.
              CNCModeller @droftarts
              @droftarts thanks for the update! It's usable now but not great. I'll hang on for an update from @dc42 but can always fall back on a separate Arduino if required.
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
              rilotundefined 1 Reply Last reply Reply Quote 0
              • rilotundefined
                rilot @CNCModeller
                @cncmodeller I'm using a seperate Arduino to drive the backlight. Works fine.
                CNCModellerundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                  CNCModeller @rilot
                  @rilot said in Duet2 ethernet and 12864 display using ST7567:
                  @rilot good to know, thanks.
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                  • o_lampeundefined
                    o_lampe @rilot
                    I have some ATMega44 chips soldered on a small SOP16 PCB(*), would they be powerful enough to drive the Neopixel?
                    Can you compile your program with Atmega44 selected?
                    Does it switch the backlight on/off, when I push the button on the LCD?
                    *) It's the green PCB (Pololu stepper driver footprint)
                    • Topherundefined
                      Topher
                      @cncmodeller M150 is not supported on Duet2 due to lack of memory. There are some details in this thread but it is hard to follow. That thread specifically says V2.1 of the display (the one with a NeoPixel) does not work on Duet2.
                      I can confirm a Fysetc V1.2 12864 display works on Duet2 with RRF 3.2.2, you just need a custom wiring loom. I have since moved on to a Mini5+ where the V2.1 is natively supported.
                      I just picked up a Mini5+. Sticker on the back says V1.0 and connected to the Fysetc 12864 display with included 2811 RGB drivers. After adding M918 P2 E2 and M150 X1 Q3000000 to my config file, the LCD works just fine, but nothing on the side of M150 controlling the screens LED's. Any ideas?
                        jay_s_uk @Topher
                        @leckietech
                        Which firmware?
                        And which version of fysetc screen?
                        Topherundefined 1 Reply Last reply Reply Quote 0
                          Firmware 3.3beta3 will support a short string of Neopixels on Duet WiFi and Ethernet.
                          • Topherundefined
                            Topher @dc42
                            @dc42 said in Duet2 ethernet and 12864 display using ST7567:
                            I will give this a try when I get to work tomorrow, thanks. Will this firmware allow the M300 to play tones with wifi2? Currently, it just sends DC out to the piezo for the set duration but no oscillation.
                            • Topherundefined
                              Topher @jay_s_uk
                              @jay_s_uk said in Duet2 ethernet and 12864 display using ST7567:
                              @leckietech
                              Which firmware?
                              Im running RRF 3.2.2 with 12864 display using ST7567 and its got 3 on board 2811 drivers:
                              https://www.aliexpress.com/item/32862853197.html?spm=a2g0s.9042311.0.0.5d614c4doODGv6
                              • fs9undefined
                                fs9
                                Hello!
                                This is my first post on the forum, so if I apologize in advance for any gaffes I eventually make. 😬
                                I've been following this topic and others related to ST7567-based LCDs for a while, and a few days ago, I was discussing with a friend about the mess that wiring it for the Duet2 can quickly become, so I made a simple adapter board and wanted to share it, in case anyone has an interest. I have tested the wiring the board is based on, but not yet the board itself (I'll make it on a protoboard before placing an order), but it does look pretty straightforward. Board sits directly over Duet2, and EXP_1/EXP_2 cables go between it and the LCD.
                                https://github.com/fs9/Duet-Mini12864
                                I would very much appreciate feedback and suggestions, should anybody have any. 😁
                                  dc42 administrators @Topher
                                  @leckietech you need to run RRF 3.3 to be able to drive the WS2811 LEDs.
                                  izemanundefined 1 Reply Last reply Reply Quote 1
                                  • izemanundefined
                                    izeman @dc42
                                    @dc42 I installed 3.3 and a ST7567 https://wiki.fysetc.com/Generic_12864_Panel/ to my duet2 wifi. Did the wiring loom and all seems to work fine. Communication between display and printer works, SD card access works etc.
                                    Only thing not working is the LED.
                                    I set the display up with M918 P2.
                                    And then I should be able to address the Neopixel LEDs with M150. Only command accepted is M150 X2, but it doesnt drive any LED of the display.
                                    And M150 X1 gives Error: M150: Unsupported LED strip type
                                    Any idea what to do to make the backlight of this display work with the Duet Wifi?
                                    izemanundefined 1 Reply Last reply Reply Quote 0
                                    • izemanundefined
                                      izeman @izeman
                                      Could someone using the Fysetc 2.1 and running a DUET please post his config here? I had it running for month now, but somehow my config got erased, and I can't get the display's LEDs working again. 😞
                                      I need this part, with the CORRECT PIN to setup... io5.out is not the correct one, and even after looking into manual ans stuff I can't figure it out. That's very confusing to me.
                                      M918 P2 E-4 F2000000           ; Fysetc 12864mini
                                      M950 E1 C"io5.out" T1 U3       ; create a RGB Neopixel LED strip with 3 LEDs on the Duet 3 Mini 5+ 12864_EXP1 header
                                      M150 E1 R0 U0 B255 P255 S1 F1  ; display led blue
                                      M150 E1 R255 U0 B0 P255 S1 F1  ; left encoder led red
                                      M150 E1 R0 U255 B0 P255 S1 F0  ; right encoder led green
                                        dc42 administrators @izeman
                                        @izeman which firmware version are you using?
                                        • izemanundefined
                                          izeman @dc42
                                          3.5.0-rc.1
                                          Thanks!
                                            @izeman try pin name "connlcd.np".
