Probing Errors with Prusa mk2.5s and PINDA sensor
1.0k
    achrn @Trafim
    @Trafim I've had another thought - your reported temperatures are about what you'd get at normalish room temperatures if you'd configured it with T10000 instead of T100000. Are you sure you have enough zeros?
      raftaman @Trafim
      @Trafim Hello, I have uploaded all the files provided by CNCKitchen, I have them hosted on a Duet 3 prusa 2.5s they really do not work correctly, the z gives me error G28 from there I have not advanced since I lack a lot of knowledge and time since it is a hobby, would someone have the .G files, working on a prusa like the one I have? Thank you
        raftaman @Trafim
        @Trafim said in Probing Errors with Prusa mk2.5s and PINDA sensor:
        Estoy reconstruyendo una Prusa mk2.5s para usar una duet 3 mini 5+. Estoy usando la mayor parte del código de la guía de CNCkitchen pero cambié algunas de las configuraciones de la sonda de acuerdo con este foro .
        Esto me dejó con este archivo de configuración:
        It is possible that you upload your correct files so that I can use them, I had a problem with the CNCKitchen files, and I could not solve them, lack of knowledge I have a Prusa MK2.5s like you with a Duet 3 board. It is just a hobby Thank you
          raftaman
          G28 Z Error: Homing file homez.g not found
          undefined 2 Replies Last reply 18 Sept 2023, 17:35 Reply Quote 0
            Phaedrux Moderator @raftaman
            @raftaman said in Probing Errors with Prusa mk2.5s and PINDA sensor:
            Do you have a homez.g file in your sys folder on the SD card?
            undefined 1 Reply Last reply 21 Sept 2023, 18:56 Reply Quote 0
              raftaman @Phaedrux
              @Phaedrux; 0:/sys/homez.g
              ; Home the Z axis
              ;M98 P"current-sense-homing.g" ; Ensure the current and sensitivity is set for homing routines.
              ; !!! If using Pinda, comment-out the following two lines
              ;M280 P0 S160 ; BLTouch, alarm release.
              ;G4 P100 ; BLTouch, delay for the release command.
              G91 ; Set relative positioning.
              G1 H0 Z3 F6000 ; Lift Z axis 3mm.
              G90 ; Set absolute positioning.
              G1 X105 Y105 F6000 ; Go to the center of the bed for probe point.
              M558 F1000 A1 ; Set probing speed to fast for the first pass.
              G30 ; Perform Z probing.
              G1 H0 Z5 F400 ; Lift Z axis to the 5mm position.
              M558 F50 A5 S-1 ; Set probing speed to slow for second pass, take 5 probes and yield the average.
              M558 F200 A1 ; Set normal z-probe speed.
              undefined 1 Reply Last reply 2 Oct 2023, 20:51 Reply Quote 0
                When exactly are you getting that error?
                undefined 1 Reply Last reply 24 Sept 2023, 19:49 Reply Quote 0
                  raftaman @Phaedrux
                  @Phaedrux when I do a startup test on the Prusa mk2.5s
                    What is the startup test exactly?
                    undefined 1 Reply Last reply 2 Oct 2023, 19:14 Reply Quote 0
                      raftaman @Phaedrux
                      @Phaedrux xxx-Duet3-error.jpeg When I click on: Home All, I get that error. Home X, super, Home Y., Super, Home Z. Mistake
                        It's not saying homez.g not found, it's saying a move was attempted on an axis before it was homed. In your homez.g you have this G1 H0 move trying to lift the Z axis before it has been homed. This should be G1 H2 to allow the move to proceed even though it is not homed.
                        undefined undefined 2 Replies Last reply 8 Oct 2023, 15:42 Reply Quote 0
                          raftaman @Phaedrux
                          @PhaedruxWhat step should I take, what code should I include?
                            Phaedrux Moderator @Phaedrux
                            @Phaedrux said in Probing Errors with Prusa mk2.5s and PINDA sensor:
                            undefined 1 Reply Last reply 16 Feb 2024, 11:38 Reply Quote 0
                              raftaman @Phaedrux
                              @PhaedruxI'M GOING TO TRY THIS WEEKEND WITH THE CODE YOU WRITE FOR ME. Thank
