    Probing Errors with Prusa mk2.5s and PINDA sensor
    1.0k
    • raftamanundefined
      raftaman
      G28 Z Error: Homing file homez.g not found
      Phaedruxundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @raftaman
        @raftaman said in Probing Errors with Prusa mk2.5s and PINDA sensor:
        Do you have a homez.g file in your sys folder on the SD card?
        raftamanundefined 1 Reply Last reply Reply Quote 0
        • raftamanundefined
          raftaman @Phaedrux
          @Phaedrux; 0:/sys/homez.g
          ; Home the Z axis
          ;M98 P"current-sense-homing.g" ; Ensure the current and sensitivity is set for homing routines.
          ; !!! If using Pinda, comment-out the following two lines
          ;M280 P0 S160 ; BLTouch, alarm release.
          ;G4 P100 ; BLTouch, delay for the release command.
          G91 ; Set relative positioning.
          G1 H0 Z3 F6000 ; Lift Z axis 3mm.
          G90 ; Set absolute positioning.
          G1 X105 Y105 F6000 ; Go to the center of the bed for probe point.
          M558 F1000 A1 ; Set probing speed to fast for the first pass.
          G30 ; Perform Z probing.
          G1 H0 Z5 F400 ; Lift Z axis to the 5mm position.
          M558 F50 A5 S-1 ; Set probing speed to slow for second pass, take 5 probes and yield the average.
          M558 F200 A1 ; Set normal z-probe speed.
            When exactly are you getting that error?
            • raftamanundefined
              raftaman @Phaedrux
              @Phaedrux when I do a startup test on the Prusa mk2.5s
                What is the startup test exactly?
                • raftamanundefined
                  raftaman @Phaedrux
                  @Phaedrux xxx-Duet3-error.jpeg When I click on: Home All, I get that error. Home X, super, Home Y., Super, Home Z. Mistake
                    It's not saying homez.g not found, it's saying a move was attempted on an axis before it was homed. In your homez.g you have this G1 H0 move trying to lift the Z axis before it has been homed. This should be G1 H2 to allow the move to proceed even though it is not homed.
                    raftamanundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • raftamanundefined
                      raftaman @Phaedrux
                      @PhaedruxWhat step should I take, what code should I include?
                        Phaedrux Moderator @Phaedrux
                        @Phaedrux said in Probing Errors with Prusa mk2.5s and PINDA sensor:
                        • raftamanundefined
                          raftaman @Phaedrux
                          @PhaedruxI'M GOING TO TRY THIS WEEKEND WITH THE CODE YOU WRITE FOR ME. Thank
