    After Z probing, print head smashing into bed
    1.5k
    • Adam_Sw3undefined
      Adam_Sw3
      Good Evening all, as the title states my print head smashes into the bed. I have checked my leadscrew pitch all correct etc. I have levelled it using true bed levelling etc its all flat and the Z probe offset is accurate. The only problem is, is that when I start a print, it seems to disregard all this effort and just smash the head straight into the bed! Any help?
      Config Below:
      .; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 18:08:10 GMT+0100 (British Summer Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Printer"                                 ; set printer name
      M669 K1                                        ; select CoreXY mode
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes forwards X axis
      M569 P1 S0                                     ; physical drive 1 goes forwards Y Axis
      M569 P2 S0                                     ; physical drive 2 goes forwards 2 x Z axis
      M569 P3 S1                                     ; physical drive 3 goes forwards Extruder 0
      M569 P4 S0                                     ; physical drive 4 goes forwards - Extruder 1
      ;M569 P5 S0                                     ; physical drive 5 goes forwards - Extruder 2
      ;M569 P6 S0                                     ; physical drive 6 goes forwards - Extruder 3
      M569 P7 S1                                     ; physical drive 9 goes forwards - 3rd Z motor
      M569 P6 S1                                     ; physical drive 2 goes forwards 2nd Z motor
      M584 X0 Y1 Z2:5:6 E3:4                               ; set drive mapping
      M671 X290:0:470 Y10:470:470 S0.5 ; position of leadscrew/bed pivot point at front left, rear middle and front right
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1066.67 E446.8              ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X470 Y470 Z500 S0                         ; set axis maxima
      M574 X1 S1 P"!xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M558 P1 C"!zprobe.in" H10 F240 T6000            ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X35 Y0 Z2.47                          ; set Z probe trigger value, offset and trigger height
      M557 X15:525 Y10:400 S50                       ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.310 K0.291:0.000 D1.41 E1.35 S1.00 B0                              ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"MATERIAL 1" D3 H1 F0                 ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"MATERIAL 2" D4 H1 F0                 ; define tool 1
      G10 P1 X0 Y0 Z0                                ; set tool 1 axis offsets
      G10 P1 R0 S0                                   ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 S"MATERIAL 3" D5 H1 F0                 ; define tool 2
      G10 P2 X0 Y0 Z0                                ; set tool 2 axis offsets
      G10 P2 R0 S0                                   ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 S"MATERIAL 3" D5 H1 F0                 ; define tool 2
      G10 P3 X0 Y0 Z0                                ; set tool 2 axis offsets
      G10 P3 R0 S0                                   ; set initial tool 2 active and standby temperatures to 0C
      Is my G31 P value correct?
      Heres a sample of my start code exported out of cura.
      ;FLAVOR:RepRap
      ;TIME:958
      ;Filament used: 1.06216m
      ;Layer height: 0.2
      ;MINX:271
      ;MINY:208
      ;MINZ:0.3
      ;MAXX:299
      ;MAXY:236
      ;MAXZ:19.9
      ;Generated with Cura_SteamEngine 5.4.0
      T0
      M190 S50
      M104 S250
      M109 S250
      M82 ;absolute extrusion mode
      G28 ;Home
      G1 Z15.0 F6000 ;Move the platform down 15mm
      ;Prime the extruder
      G92 E0
      G1 F200 E3
      G92 E0
      M83 ;relative extrusion mode
      G1 F1500 E-6.5
      ;LAYER_COUNT:99
      ;LAYER:0
      M107
      G0 F3600 X271.858 Y209.549 Z0.3
      ;TYPE:SKIRT
      G1 F1500 E6.5
      G1 F1800 X272.284 Y209.084 E0.03146
      G1 X272.779 Y208.691 E0.03153
      G1 X273.325 Y208.382 E0.0313
      G1 X273.857 Y208.18 E0.02839
      G1 X274.516 Y208.04 E0.03361
      G1 X274.961 Y208.003 E0.02228
      G1 X294.351 Y208 E0.96737
      G1 X295.083 Y208.012 E0.03652
      Any help would be greatly appreciated, thank you.
      fcwiltundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @Adam_Sw3
        @Adam_Sw3
        As a test:
        • move the probe to the center of the bed
        • execute G30
        • execute G30 S-1
        The G30 S-1 should report the same value as used in G31 for your Z probe trigger value.
        Let us know the result.
        Adam_Sw3undefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @Adam_Sw3
          @Adam_Sw3 It looks like you have multiple extruders. What sort of printer is this do you have a toolchanger of some sort? Posting a picture of the printer might make it easier for folks to help you.
          With tool 0 selected, if you manually move the print head so that the tool 0 nozzle just touches the bed, what Z position is displayed in DWC?
          Adam_Sw3undefined 1 Reply Last reply Reply Quote 1
          • Adam_Sw3undefined
            Adam_Sw3 @fcwilt
            @fcwilt Hi There, yes it reports the result of 2.47. I have done this numerous times and somehow its still not working...
            • Adam_Sw3undefined
              Adam_Sw3 @gloomyandy
              @gloomyandy That is correct, its a custom built machine with its own material holder on the top. All of these materials go through one nozzle (switching hotend)
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
                @Adam_Sw3 What was the result of positioning the tool so that the nozzle is just touching the bed? What is the Z reading when in that position?
                • fcwiltundefined
                  fcwilt @Adam_Sw3
                  @Adam_Sw3 said in After Z probing, print head smashing into bed:
                  Thanks for checking it.
                  The code at the start of the print file looks correct.
                  One of the first things it does is a G28 to home all.
                  I assume homing works fine when done from the Dashboard?
                  • Adam_Sw3undefined
                    Adam_Sw3 @fcwilt
                    @fcwilt Hi frederick, thanks for confirming, yes the homing works fine etc.
                    • Adam_Sw3undefined
                      @gloomyandy ermmm, you may have got me onto this issue, its reporting 7.2mm.
                      • fcwiltundefined
                        fcwilt @Adam_Sw3
                        Do you have some code that is setting the Z offset of the tool?
                        Adam_Sw3undefined 2 Replies Last reply Reply Quote 0
                        • Adam_Sw3undefined
                          Adam_Sw3 @fcwilt
                          @fcwilt Hi, i am using the duet reccomended way -> https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                          The problem, i am having it seems, is that when I centre the nozzle and place it onto the bed after following this guide, it reports 4mm even though its technically zero (since the nozzle is touching)? I dont really understand whats going on here.
                          • Adam_Sw3undefined
                            Adam_Sw3 @fcwilt
                            @fcwilt It looks like the Z probe is 3.91mm away but the nozzle is touching the bed. I dont really understand...
                            • fcwiltundefined
                              fcwilt @Adam_Sw3
                              Do you have config-override.g file? If so did you check it's contents for something affecting the settings of the probe or tool?
                              What sort of Z probe are you using?
                              After setting the Z=0 Datum using G30 you should be able to move the nozzle so it is just touching the bed and the Z position should be shown as 0 or close to it.
                              Does it work that way?
                              Adam_Sw3undefined 2 Replies Last reply Reply Quote 1
                              • Adam_Sw3undefined
                                Adam_Sw3 @fcwilt
                                @fcwilt I do but it is empty. I am using a inductance sensor. I have done that G30 command proccess. But turned out the problem was that the bed wasnt level, anyways I used true bed levelling that sorted this. I repeated the proccess again, yet when the nozzle is touching the build plate it reads a z position of 1.4mm. Which i dont really understand?
                                • Adam_Sw3undefined
                                  Adam_Sw3 @fcwilt
                                  @fcwilt Would increasing my Z offset bring it further away from the bed and then from there, i could baby step it down onto the bed? Or would it be the inverse (decreasing Z offset)
                                    Can you share your homing files and bed.g and any other macros you're using for leveling?
                                    What firmware version?
                                    How did you determine those steps per mm for Z? It seems a strange value.
                                    For a leadscrew z axis the formula for steps per mm is as follows.
                                    Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                                    • Adam_Sw3undefined
                                      Adam_Sw3 @Phaedrux
                                      @Phaedrux hello Phaedrux! yes certainly, i will supply these in the morning (GMT 08:00) i will share these. I got these z steps per mm using the prusa calculator. I am using this Lead screw https://uk.rs-online.com/web/p/lead-screws/8625281?gb=s i also checked with verniers ie down 25mm etc.
                                      Thank you.
                                      • fcwiltundefined
                                        fcwilt @Adam_Sw3
                                        That would be putting a bandage on the symptoms and hiding the real problem.
                                        Hang in there - we will sort it.
                                        • Adam_Sw3undefined
                                          Adam_Sw3 @Phaedrux
                                          @Phaedrux
                                          Hi Phaedrux, my bed.g is here
                                          ; bed.g
                                          G28 ; home
                                          G30 P0 X0 Y440 Z-99999 ; probe near a leadscrew
                                          G30 P1 X570 Y440 Z-99999 ; probe near a leadscrew
                                          G30 P2 X290 Y10 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                                          ;M561 ; clear any bed transform
                                          ;G29  ; probe the bed and enable compensation
                                          Home all
                                          ; homeall.g
                                          ; called to home all axes
                                          G1 H2 Z5 F6000          ; lift Z relative to current position
                                          G1 H1 X-555 Y-415 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-555             ; home X axis
                                          G1 H1 Y-415             ; home Y axis
                                          G1 X5 Y5 F6000          ; go back a few mm
                                          G1 H1 X-555 F360        ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y-415             ; then move slowly to Y axis endstop
                                          G90                     ; absolute positioning
                                          G1 X-20 Y10 F6000       ; go to first bed probe point and home Z
                                          G30                     ; home Z by probing the bed
                                          ;G91                    ; relative positioning
                                          ;G1 Z5 F100             ; lift Z relative to current position
                                          ;G90                    ; absolute positioning
                                          Home X
                                          ; homex.g
                                          ; called to home the X axis
                                          G1 H1 X-555 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F6000       ; go back a few mm
                                          G1 H2 Z-5 F6000   ; lower Z again
                                          Home Y
                                          ; homey.g
                                          ; called to home the Y axis
                                          G1 H1 Y-415 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 Y5 F6000       ; go back a few mm
                                          G1 H1 Y-415 F360  ; move slowly to Y axis endstop once more (second pass)
                                          Home Z
                                          ; homez.g
                                          ; called to home the Z axis
                                          G1 X-20 Y10 F6000 ; go to first probe point
                                          Current firmware is
                                          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2022-10-20 16:17:41
                                          • Adam_Sw3undefined
                                            Adam_Sw3 @fcwilt
                                            @fcwilt Thanks Frederick! Its people like you that really go under appreciated in these forums, thanks for your help. I have replied to phaedrux below so we shall see what he says.
