    After Z probing, print head smashing into bed
    1.5k
    • Adam_Sw3undefined
      Adam_Sw3 @gloomyandy
      @gloomyandy That is correct, its a custom built machine with its own material holder on the top. All of these materials go through one nozzle (switching hotend)
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @Adam_Sw3
        @Adam_Sw3 What was the result of positioning the tool so that the nozzle is just touching the bed? What is the Z reading when in that position?
        Adam_Sw3undefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @Adam_Sw3
          @Adam_Sw3 said in After Z probing, print head smashing into bed:
          @fcwilt Hi There, yes it reports the result of 2.47. I have done this numerous times and somehow its still not working...
          Thanks for checking it.
          The code at the start of the print file looks correct.
          One of the first things it does is a G28 to home all.
          I assume homing works fine when done from the Dashboard?
          Adam_Sw3undefined 1 Reply Last reply Reply Quote 0
          • Adam_Sw3undefined
            Adam_Sw3 @fcwilt
            @fcwilt Hi frederick, thanks for confirming, yes the homing works fine etc.
            • Adam_Sw3undefined
              @gloomyandy ermmm, you may have got me onto this issue, its reporting 7.2mm.
              • fcwiltundefined
                fcwilt @Adam_Sw3
                Do you have some code that is setting the Z offset of the tool?
                Adam_Sw3undefined 2 Replies Last reply Reply Quote 0
                • Adam_Sw3undefined
                  Adam_Sw3 @fcwilt
                  @fcwilt Hi, i am using the duet reccomended way -> https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                  The problem, i am having it seems, is that when I centre the nozzle and place it onto the bed after following this guide, it reports 4mm even though its technically zero (since the nozzle is touching)? I dont really understand whats going on here.
                  • Adam_Sw3undefined
                    Adam_Sw3 @fcwilt
                    @fcwilt It looks like the Z probe is 3.91mm away but the nozzle is touching the bed. I dont really understand...
                    • fcwiltundefined
                      fcwilt @Adam_Sw3
                      Do you have config-override.g file? If so did you check it's contents for something affecting the settings of the probe or tool?
                      What sort of Z probe are you using?
                      After setting the Z=0 Datum using G30 you should be able to move the nozzle so it is just touching the bed and the Z position should be shown as 0 or close to it.
                      Does it work that way?
                      Adam_Sw3undefined 2 Replies Last reply Reply Quote 1
                      • Adam_Sw3undefined
                        Adam_Sw3 @fcwilt
                        @fcwilt I do but it is empty. I am using a inductance sensor. I have done that G30 command proccess. But turned out the problem was that the bed wasnt level, anyways I used true bed levelling that sorted this. I repeated the proccess again, yet when the nozzle is touching the build plate it reads a z position of 1.4mm. Which i dont really understand?
                        • Adam_Sw3undefined
                          Adam_Sw3 @fcwilt
                          @fcwilt Would increasing my Z offset bring it further away from the bed and then from there, i could baby step it down onto the bed? Or would it be the inverse (decreasing Z offset)
                            Can you share your homing files and bed.g and any other macros you're using for leveling?
                            What firmware version?
                            M92 X80.00 Y80.00 Z1066.67
                            How did you determine those steps per mm for Z? It seems a strange value.
                            For a leadscrew z axis the formula for steps per mm is as follows.
                            Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                            • Adam_Sw3undefined
                              Adam_Sw3 @Phaedrux
                              @Phaedrux hello Phaedrux! yes certainly, i will supply these in the morning (GMT 08:00) i will share these. I got these z steps per mm using the prusa calculator. I am using this Lead screw https://uk.rs-online.com/web/p/lead-screws/8625281?gb=s i also checked with verniers ie down 25mm etc.
                              Thank you.
                              • fcwiltundefined
                                fcwilt @Adam_Sw3
                                That would be putting a bandage on the symptoms and hiding the real problem.
                                Hang in there - we will sort it.
                                • Adam_Sw3undefined
                                  Adam_Sw3 @Phaedrux
                                  @Phaedrux
                                  Hi Phaedrux, my bed.g is here
                                  ; bed.g
                                  ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 18:08:10 GMT+0100 (British Summer Time)
                                  G28 ; home
                                  G30 P0 X0 Y440 Z-99999 ; probe near a leadscrew
                                  G30 P1 X570 Y440 Z-99999 ; probe near a leadscrew
                                  G30 P2 X290 Y10 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                                  ;M561 ; clear any bed transform
                                  ;G29  ; probe the bed and enable compensation
                                  Home all
                                  ; homeall.g
                                  ; called to home all axes
                                  G1 H2 Z5 F6000          ; lift Z relative to current position
                                  G1 H1 X-555 Y-415 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                  G1 H1 X-555             ; home X axis
                                  G1 H1 Y-415             ; home Y axis
                                  G1 X5 Y5 F6000          ; go back a few mm
                                  G1 H1 X-555 F360        ; move slowly to X axis endstop once more (second pass)
                                  G1 H1 Y-415             ; then move slowly to Y axis endstop
                                  G90                     ; absolute positioning
                                  G1 X-20 Y10 F6000       ; go to first bed probe point and home Z
                                  G30                     ; home Z by probing the bed
                                  ;G91                    ; relative positioning
                                  ;G1 Z5 F100             ; lift Z relative to current position
                                  ;G90                    ; absolute positioning
                                  Home X
                                  ; homex.g
                                  ; called to home the X axis
                                  G1 H1 X-555 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                  G1 X5 F6000       ; go back a few mm
                                  G1 H2 Z-5 F6000   ; lower Z again
                                  Home Y
                                  ; homey.g
                                  ; called to home the Y axis
                                  G1 H1 Y-415 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 Y5 F6000       ; go back a few mm
                                  G1 H1 Y-415 F360  ; move slowly to Y axis endstop once more (second pass)
                                  Home Z
                                  ; homez.g
                                  ; called to home the Z axis
                                  G1 X-20 Y10 F6000 ; go to first probe point
                                  Current firmware is
                                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2022-10-20 16:17:41
                                  • Adam_Sw3undefined
                                    Adam_Sw3 @fcwilt
                                    @fcwilt Thanks Frederick! Its people like you that really go under appreciated in these forums, thanks for your help. I have replied to phaedrux below so we shall see what he says.
                                    • fcwiltundefined
                                      fcwilt @Adam_Sw3
                                      @Adam_Sw3
                                      You mentioned that you use an inductance sensor.
                                      In your probe configuration you have chosen type P1. Does you sensor actually have an analog output like a "smart IR probe"?
                                      I've used many inductive sensors and I have always specified type P8, since the output of the probe is either "on" or "off".
                                      I also would like to share with you what steps I perform when starting a print and why I do them.
                                      But I don't have the time right now - it's 5.00 AM.
                                      Doing the needed things in the correct order at the start of a print is important.
                                      • Adam_Sw3undefined
                                        Adam_Sw3 @fcwilt
                                        @fcwilt Hi Fredrick, my inductance sensor is similar to here https://www.aliexpress.com/item/1005004853709100.html?spm=a2g0o.productlist.main.33.60c8l3fwl3fwqS&algo_pvid=6f2ef3f2-1dd9-4b63-a7bd-bb78c1f5cfd8&algo_exp_id=6f2ef3f2-1dd9-4b63-a7bd-bb78c1f5cfd8-16&pdp_npi=4%40dis!GBP!6.68!6.68!!!7.89!!%4021038eda16964986241754812e39f3!12000030753506738!sea!UK!2004704503!&curPageLogUid=BWGfMQ4DwVrl
                                        it has 3 leads, power is connected to my fan header (always on) so i put my z probe signal to my z probe signal header. what does p8 specify?
                                        Thank you.
                                        • fcwiltundefined
                                          fcwilt @Adam_Sw3
                                          @Adam_Sw3
                                          It is fairly typical of Chinese units - a bit short on specs. It says it has fast response but I didn't see a frequency spec. Higher frequency normal yields faster response.
                                          I usually get my units from here:
                                          Automation Direct
                                          They have a good selection - for example they list 35 4mm units. And they usually provide full specs. They tend to be more expensive.
                                          Probe type 8 just specifies that the probe sends an signal that is either ON or OFF, which is what these types of probes typically do.
                                          • Adam_Sw3undefined
                                            Adam_Sw3 @fcwilt
                                            @fcwilt Hi Frederick,
                                            Yes that makes sense, So should i change my code to:
                                            M558 ***P8*** C"!zprobe.in" H10 F240 T6000            ; set Z probe type to unmodulated and the dive height + speeds
                                            G31 P500 X35 Y0 Z2.47                          ; set Z probe trigger value, offset and trigger height
                                            M557 X15:525 Y10:400 S50                       ; define mesh grid
                                            What did my P1 previously mean? I am guessing this is frequency specification? As I would be happy for it to work as a switch.
