    BtnCmd-DWC Plugin - Customise DWC - v01.03.08 01-03-25
    Plugins for DWC and DSF
    27
    244
    38.8k
    • MintyTreborundefined
      MintyTrebor @stuartofmt
      Released v01.01.01 for DWC 3.5+
      Changes:
      • updated for dwc 3.5
      • fixed some minor bugs
      • removed option to toggle radio button instead of selects
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      MintyTreborundefined 1 Reply Last reply Reply Quote 2
        MintyTrebor @MintyTrebor
        Released v01.01.02 for DWC 3.5+
        Changes:
        • Custom Charts (Wiki)
        • Support for Global variable Arrays
        • OM Lookup for OM Panel
        With Custom Charts you can:
        • Add chart data lines from the Object Model, set scales, colour, & legends
        • Define X & Y axis options
        • Set Chart Update Frequency
        • Set Chart Name
        • Hover over chart data line data-points for popup info
        • Save the Chart Data to CSV file
        Repo
        Diamondbackundefined MintyTreborundefined 2 Replies Last reply Reply Quote 6
        • Diamondbackundefined
          Diamondback @MintyTrebor
          @MintyTrebor Very nice! Thank you! 🙂
          • Phaedruxundefined Phaedrux referenced this topic
            Released v 01.02.02 for DWC 3.5
            Changes:
            Input Panel - option to run GCode command post user input
            OM Panel - option to perform basic maths on OM numeric values
            Fixed Bug in Colour Picker
            Fixed Reset Settings function
            Minor update - 01.02.02 - Update Bug fix to Input Panel
            Repo
            MintyTreborundefined 1 Reply Last reply Reply Quote 4
              Released v 01.02.04 for DWC 3.5
              Changes:
              • Added precision to custom charts - Existing charts will need to be edited and saved, before the full precision options become available (this is in order to upgrade their config data).
              • Added toggle to show current value in legend for custom charts.
              • Changed behaviour to load all BtnCmd Tabs in background on first access, to start custom chart data capture without needing to switch to relevant tab
              • Added option to quickly switch to BtnCmd and return to DWC dashboard on DWC launch, to allow custom chart's to begin to capture data immediately.
              • Fixed intermittent issue where panels would occasionally jump off screen in edit mode.
              • Edit mode behaviour change - When entering/exiting edit mode, screen will remain on current tab, unless tab(s) have been deleted.
              Repo
              • cosmowaveundefined cosmowave referenced this topic
              • infiniteloopundefined infiniteloop referenced this topic
              • MintyTreborundefined MintyTrebor referenced this topic
                Released v 01.02.06 for DWC 3.5.0-rc.1 Only
                Repo
                MintyTreborundefined 1 Reply Last reply Reply Quote 1
                  Released 01.02.07 for DWC 3.5.0-rc.1
                  Added custom icons to Input and Text Panels
                  Repo
                  1 Reply Last reply Reply Quote 6
                  • nikschaundefined
                    nikscha
                    I just found this plugin, I'm amazed! Keep up the good work!
                    Stay in school
                    • fcwiltundefined
                      fcwilt @nikscha
                      Been using BtnCmd for a while. Compared to BtnCmd, sliced bread is no longer the best thing ever... it's toast. 🙄
                      Anyway I gather that those of us running RRF 3.4.x are stuck with an older version of BtnCmd - 0.10.15 - which I guess is not getting any updates?
                      It has a few bugs.
                      But my real question is does BtnCmd have, or while it have, or could it have a way to persist selected settings between sessions (power off to power on)?
                      That would be grand!
                      MintyTreborundefined 1 Reply Last reply Reply Quote 0
                        MintyTrebor @fcwilt
                        @fcwilt said in BtnCmd-DWC Plugin - Customise DWC - v01.02.07 17-09-23:
                        Correct - 3.5 introduced some major differences and as this is just a spare time project for me, I do not have the time to maintain 2 code bases.
                        When you say 'persist selected settings' do you mean changing the values of global variables via an input panel, or something else?
                        Repo
                        • fcwiltundefined
                          fcwilt @MintyTrebor
                          @MintyTrebor said in BtnCmd-DWC Plugin - Customise DWC - v01.02.07 17-09-23:
                          And someday when 3.5 is ready for prime time I will move to it. I am not a fan of alpha, beta, gamma and RC releases. Even x.0 releases are best avoided. 😁
                          I already use BtnCmd to manipulate global variables. It is a great feature.
                          But it would be grand if certain of the values could be saved in some sort of non-volatile storage so when I come back the the printer the next day they are as I had set them using BtnCmd.
                          Tinchusundefined 1 Reply Last reply Reply Quote 0
                          • deckingmanundefined deckingman referenced this topic
                          • Tinchusundefined
                            Tinchus @fcwilt
                            @fcwilt what if you ECHO those variables to a file, and in the next restart you just read thta file again in config.g. This is how Im doing now to store the total printing time of my printer and it works
                            chimaeraghundefined 1 Reply Last reply Reply Quote 1
                            • chimaeraghundefined
                              chimaeragh @Tinchus
                              @Tinchus Can you give an example (code) of how this works in both situations (save and restore values)? I am trying to achieve something like this.
                              Thanks
                              Duet 2 Wifi, Ooznest Workbee CNC 1510
                              • Tinchusundefined
                                Tinchus @chimaeragh
                                @chimaeragh Sure. For example, when I want to save the total uptime of the machine I execute count.g:
                                echo >"uptime.g" "global.ontime =",{global.ontime + state.upTime/60}
                                This saves in uptime.g the value of the global.ontime, and I get that value from the object model
                                Next time the machine restarts, in config.g I have a M98 P"uptime.g", so the value of the global variable is read again and keeps being incremented.
                                chimaeraghundefined 1 Reply Last reply Reply Quote 2
                                  chimaeragh @Tinchus
                                  @Tinchus Thanks
                                    MintyTrebor @chimaeragh
                                    BtnCmd 01.03.0 for DWC 3.5 has been published on github here
                                    Changes Since 0.10.15 (DWC 3.4.6)
                                    • Global Settings - Removed option to toggle radio button instead of selects
                                    • Added New Custom Charts Panel (Wiki) - (Includes ability to save chart data to csv)
                                    • Added Support for Global Arrays in panels
                                    • Added Job Progress Bar Panel
                                    • OM Panel - Added Object Model Lookup feature
                                    • Input & Text Panels - Added function to add an material designs icons to the panels - user can define icon and colour size
                                    • Input Panel - New option to run GCode command post user input
                                    • Input Panel - New option to enable automatic acceptance of inputted values on focus change
                                    • OM Panel - New option to perform basic maths on OM numeric values
                                    • Alt WebCam Panel - Added Nozzle Alignment Overlay Feature
                                    • Fixed Bug in Colour Picker
                                    • Fixed Reset Settings function
                                    • Changed Startup behaviour to load all BtnCmd Tabs in background on first access, to start custom chart data capture without needing to switch to relevant tab
                                    • Global Settings - Added option to quickly switch to BtnCmd and return to DWC dashboard on DWC launch, to allow custom chart's to begin to capture data immediately.
                                    • General non-critical javascript bug fixes
                                    Custom Charts:
                                    Example Custom Icons:
                                    Nozzle Alignment :
                                    Repo
                                      updated to v01.03.01
                                      Fixed issue with macros from a button in custom panel
                                      Repo
                                        Updated to 01.03.03
                                        No functional changes - re-packaged for 3.5.2
                                        Repo
                                          Updated to 01.03.04
                                          • Fixed Bug switching between create & edit mode where new items could be added to the wrong layout/custom panel
                                          Repo
                                            Updated to 01.03.05 for DWC 3.5.3 compatability.
                                            No functional changes.
                                            Repo
                                            • o_lampeundefined o_lampe referenced this topic
