    PanelDue Firmware 3.4.1 released
    PanelDue
    1.0k
    • mfs12undefined
      mfs12
      Hey,
      new version of Paneldue Firmware was released.
      Release Notes
      This release requires RepRapFirmware 3.3 or later.
      Version 2 (after August 2016) and Version 3 PanelDue are supported.
      3.4.1-pre1:
      • M291 S3 message not cleared
      • Fix m291 jogging axes shown
      • Add support for QOI thumbnails in gcode files (supports one QOI image with max size 160x160)
        • https://github.com/phoboslab/qoi/
      3.4.1-pre2:
      • improved file detail popup layout
      • use faster stack size calculation when not debugging
      • updated RRFLibrary
      • added CRC16 to gcode request
        • by default CRC16 is enabled
        • added option to disable checksum and CRC16 in gcode requests
      • improved m291 jogging layout
      • fixed m291 axis selection handling
      3.4.1-pre3:
      • fixed babystep button handling
      • added polish translation
      • update RRFLibraries
      3.4.1:
      Downloads and flashing instructions:
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.1
      Flashing instructions can be found at https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
      Visit me on github at https://github.com/mfs12/
      os1r1sundefined 1 Reply Last reply Reply Quote 4
      • mfs12undefined mfs12 pinned this topic
      • os1r1sundefined
        os1r1s @mfs12
        @mfs12 This is awesome! Will it pick the correct QOI image if there are two embedded in the gcode?
        • mfs12undefined
          mfs12
          @os1r1s, it takes the last qoi image transmitted.
          • Mike3Dundefined
            Mike3D
            I like to see the Dutch translation.
            If i need to help................ i am Dutch.
              droftarts administrators @Mike3D
              @Mike3D Thanks for offering your services!
              See this thread: https://forum.duet3d.com/topic/24515/integrate-polish-translation/
              This text file lists all the different on-screen words that need translation (this one is Polish): polish-translation-0.3.txt
              I think if you can translate them, and post a translated text file back here, @mfs12 can integrate it.
              Mike3Dundefined 1 Reply Last reply Reply Quote 0
              • Mike3Dundefined
                Mike3D @droftarts
                @droftarts
                Thanks for the file.
                I have made a Dutch translation.
                1644677487089-dutch-translation-.txt
                Feel free to ask if the text is to long.
                droftartsundefined 1 Reply Last reply Reply Quote 1
                  @Mike3D Great, thanks! Hopefully @mfs12 can integrate it into the next release.
                  • mfs12undefined
                    mfs12
                    @Mike3D said in PanelDue Firmware 3.4.1 released:
                    Created an github issue.
                    https://github.com/Duet3D/PanelDueFirmware/issues/281
                    mfs12 created this issue in Duet3D/PanelDueFirmware
                    closed add dutch translation #281
                    • mfs12undefined mfs12 referenced this topic
                    • mfs12undefined
                      mfs12
                      Hey @Mike3D,
                      thanks for providing the dutch translation. It took a while, but finally I integrated it.
                      Meanwhile there were some other changes, perhaps you could review and update if needed.
                      Please check the linked file.
                      dutch-translation-0.2.txt
                      • mfs12undefined mfs12 unpinned this topic
