    BLtouch not deploying / PID auto tune issues
    1.0k
    • Casugoundefined
      Casugo
      Hello again!!!
      This time I have two different issues that I could use some help with:
      1. I'm in the process of adding a BLTouch to my 3D printer (which is equipped with a Duet 3MB 6CH board). Initially, when I tested the BLTouch on its own without any other connections, it deployed and retracted without any problems. However, now that everything is connected, it doesn't seem to deploy or retract as it should.
      2. During the PID tuning process, I encountered an error message that reads, 'Auto tune cancelled because target temp not reached.' Just to provide some context, the first heater has a resistance of 10.3 ohms, the second heater has 8 ohms, the third has 8.3 ohms, and the power supply is maintaining a steady 23.25V.
      Any assistance or guidance would be greatly appreciated. Thank you!" 😊
      Here my different configurations
      confg.g
      ; Welcome to your configuration GigabotX_ Western_University
      M291 P "Welcome to your experence using the GigabotX_ Western_University" S1 T0
      M550 P"Gigabot X UWO edition" ; set printer name
      M552 P192.168.100.8 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.100.254 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      ; Drivers
      M569 P0.0 S2 ; physical drive 0.0 goes forwards X
      M569 P0.1 S1 ; physical drive 0.0 goes forwards YR
      M569 P0.2 S0 ; physical drive 0.0 goes Backwards YL
      M569 P0.3 S1 ; physical drive 0.3 goes forwards ZR n ZL
      M569 P0.4 S1 ; physical drive 0.4 goes forwards Extruder
      M569 P0.5 S1 ; physical drive 0.4 goes forwards Crammer
      M584 X0.0 Y0.1:0.2 Z0.3 E0.4:0.5 ; set drive mapping
      M350 X16 Y16:16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X53.335 Y59.26:59.26 Z2015.75 E 26.00:34.00 ; set steps per mm E extruder:crammer
      M201 X500.00 Y500.00 Z20.00 E900.00 ; TEST set accelerations (mm/s^2)
      M203 X10740.00 Y6810.00 Z480.00 E3600.00 ; TEST set maximum speeds (mm/min)
      M566 X900.00 Y900.00 Z60.00 E500.00 ; TEST set maximum instantaneous speed changes (mm/min)
      M204 P5100 T20000 ; set printing and travel accelerations (mm/s^2)
      M906 X2800 Y2000:2000 Z2000 E850:2000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M572 D1 S0.03 ; Set extruder pressure advance
      M84 S30 ; Set idle timeout
      M208 X600 Y760 Z890 S0 ; set axis maxima
      Endstops
      M574 X1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
      M574 Y1 S1 P"!io3.in+!io2.in" ; configure switch-type (e.g. microswitch) endstop for High end on YR and YL via pin io3.in + io2.in
      ;M574 Z1 S1 P"!io4.in" ; configure switch-type (e.g. microswitch) endstop for High end on ZR and ZL via pin io4.in
      ;Z-probe
      M950 S0 C"!io7.out" ; configure BLtouch Z in pin io7.in
      M558 P9 C"!io7.in" H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      ;M558 P5 C"!io5.in" H10 F120 T6000 ; configure switch-type (e.g. microswitch) endstop for High end on ZR and ZL via pin io5.in
      G31 X20 Y-10 Z1.6 P100
      M557 X50:600 Y50:754.5 S80 ; define mesh grid
      Heaters
      M308 S0 P"spi.cs0" Y"thermocouple-max31856" A"Bed" T "k" F 60 ; configure sensor 0 as thermocouple via CS pin spi.cs0
      M307 H0 B0 R0.367 C336.3 D2.47 S1.00 V23.2 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 S60 R50 ; heated bed "S" active temp "R" standby temp
      M140 S-273.1 ; switch off bed heater
      M143 H0 S110 ; Heated Bed Max temp
      M308 S1 P"spi.cs1" Y"thermocouple-max31856" A"Bottom" ;T "k" F 60 ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"out1" T1 ; create nozzle heater output on out0 and map it to sensor 1
      ;M301 P32.00 I4.00 D74.00
      M307 H1 B0 R0.10 C970 D20 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
      ;M307 H1 B0 R0.16 C3600 D60 S1.00 V23.9
      M143 H1 S280 ; set temperature limit for heater 1 to 300C
      M308 S2 P"spi.cs2" Y"thermocouple-max31856" A"Middle" T "k" F 60 ; configure sensor 2 as thermocouple via CS pin spi.cs2
      M950 H2 C"out2" T2 ; create nozzle heater output on out1 and map it to sensor 2
      M307 H2 B0 R0.20 C500 D20 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 1 to 280C
      M308 S3 P"spi.cs3" Y"thermocouple-max31856" A"Top" T "k" F 60 ; configure sensor 3 as thermocouple via CS pin spi.cs3
      M950 H3 C"out3" T3 ; create nozzle heater output on out2 and map it to sensor 3
      M307 H3 B0 R0.25 C2160 D70 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
      M143 H3 S280 ; set temperature limit for heater 3 to 280C
      M950 F0 C"out9" Q30 ;"Refroidissement de couche" create fan 0 on pin out5 and set its frequency
      M106 P2 S255 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500 ; create fan 1 on pin out3 and set its frequency
      M106 P1 S255 H-1 ; set fan 1 value. Thermostatic control is turned off
      ;M950 F2 C"1.out4" Q20 ; create fan 2 "vibrateur Motor" on pin out4 and set its frequency
      ;M106 P3 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Pellet extrudeur" D 0:1 H1:2:3 F0 ; define tool 0
      M567 P0 E1:1
      G10 P0 R140,0: 140,0 S140,0:140,0:140 ; set initial tool 0 active and standby temperatures to 0C
      ;Automatic power saving
      M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      Deployprobe.g
      M280 P0 S10
      Retractprobe.g
      M280 P0 S90
      Homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 01 2022 22:10:43 GMT+0100 (heure normale d’Europe centrale)
      G91 ; relative positioning
      G1 H2 Z8 F6000 ; lift Z relative to current position
      G1 H1 X-600 Y759.5 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y-5 F3000 ; go back a few mm
      G1 H1 X-600 Y759.5 F1000 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H2 Z8 F6000
      G30 ; home z by probing the bed
      G90 ; absolute positioning
      M400
      M913 A70
      M400
      Homez.g
      ; called to home the Z axis
      G91 ;relative positioning
      G30; Uses a Z probe to measure bed height at a single point
      ;G1 H1 Z-475 F1800 ; move Z down until the endstop is triggered
      ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      Thank youu!!
      Casugoundefined 1 Reply Last reply Reply Quote 0
      • Casugoundefined
        Casugo @Casugo
        And just to add, concerning the tuning issue, I've tried manually measuring the R, C, and D values by observing the rise and cooling rates as depicted in https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_tuning, but I haven't had much success. I even attempted adjusting the D value to a higher or lower number, but it still didn't resolve the problem.
        Also, here's my config-override.g:
        config-override.g
        ; config-override.g file generated in response to M500 at 2023-10-12 20:12
        ; Heater model parameters
        M307 H0 R0.367 C336.291:336.291 D2.47 S1.00 V23.2 B0 I0
        M307 H1 R0.10 C970:970 D20 S1.00 V23.9 B0 I0
        M307 H2 R0.20 C500:500 D20 S1.00 V23.9 B0 I0
        M307 H3 R0.25 C2160:2160 D40.4 S1.00 V23.9 B0 I0
        ; Workplace coordinates
        G10 L2 P1 X0.00 Y0.00 Z0.00
        G10 L2 P2 X0.00 Y0.00 Z0.00
        G10 L2 P3 X0.00 Y0.00 Z0.00
        G10 L2 P4 X0.00 Y0.00 Z0.00
        G10 L2 P5 X0.00 Y0.00 Z0.00
        G10 L2 P6 X0.00 Y0.00 Z0.00
        G10 L2 P7 X0.00 Y0.00 Z0.00
        G10 L2 P8 X0.00 Y0.00 Z0.00
        G10 L2 P9 X0.00 Y0.00 Z0.00
        Thanks!!!
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @Casugo
          @Casugo What target temperature did you set? What was the maximum temperature that you saw during the tuning process?
          • Casugoundefined
            Casugo @gloomyandy
            @gloomyandy
            My initial temperature target was set at 180°C, but I eventually intended to print at 270°C, keeping in mind that I have three heaters available. However, the maximum temperature I could achieve was around 160°C
              gloomyandy @Casugo
              @Casugo I would have thought that a 10Ohm heater (which I think is about 50W) should be able to go above 160. What does the hot end (or whatever it is) look like? Is there anything like a fan that might be cooling it?
              Casugoundefined 2 Replies Last reply Reply Quote 0
              • Casugoundefined
                Casugo @gloomyandy
                @gloomyandy
                I have three hotends, all of which are cartridge type. Two of them are rated at 24V and 80W, and the remaining one is 24V and 60W. While attempting to heat them up they do reach the desired 270°C, but
                during the tuning process, they stop and display the error message.
                • Casugoundefined
                  Casugo @gloomyandy
                  @gloomyandy Regarding the fan I haven't activated while doing the tuning
                    gloomyandy @Casugo
                    @Casugo That sounds very strange How long does it take them to reach 180 when you tried heating them? What command are you using to run the pid tune?
                    • Casugoundefined
                      Casugo @gloomyandy
                      @gloomyandy
                      I haven't measure how much it takes to go to 180°C but when I was doing the manual tunning takes around 40s - 60s per 10°C.
                      I am using M303 H1 S180
                        gloomyandy @Casugo
                        @Casugo That seems pretty slow. Maybe capture a screenshot of the graph during tuning and post it here. Perhaps a picture of the heater and hotend setup would help as well.
                        Casugoundefined 4 Replies Last reply Reply Quote 0
                        • Casugoundefined
                          Casugo @gloomyandy
                          @gloomyandy Tomorrow I'll update everything 🙂
                          thanks!!
                          • Casugoundefined
                            Casugo @gloomyandy
                            @gloomyandy Sorry, but do you have any clue of what's happening to my BLtouch?
                              droftarts administrators @Casugo
                              @Casugo said in BLtouch not deploying / PID auto tune issues:
                              Do the lights come on on the BLTouch and it does a self test at start up? Are you sure it's plugged in to IO7?
                              Your config:
                              ;Z-probe
                              The io7.out and io7.in pins should NOT be inverted with !. See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#software-setup
                              Try:
                              ;Z-probe
                              M950 S0 C"io7.out" ; configure BLtouch Z in pin io7.in
                              M558 P9 C"io7.in" H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              Otherwise, see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#bltouch and https://docs.duet3d.com/User_manual/Troubleshooting/BLTouch_troubleshooting
                              • Casugoundefined
                                Casugo @droftarts
                                @droftarts
                                I'd removed the ! and is working now.
                                Thank you 🙂
                                • Casugoundefined
                                  Casugo @gloomyandy
                                  @gloomyandy
                                  Hello!!
                                  The machine in question is a Pellet extruder, which incorporates three barrels within the extruder assembly. Each of these barrels is equipped with a heating system. Two of them are fitted with 24V 80W heaters (as shown in Figure 1), while the remaining one is equipped with a 24V 60W heater (depicted in Figure 2).
                                  During the tuning process, I observed that all of them ceased functioning after precisely 7 minutes had elapsed. You can find visual representations of the diagrams below for reference.
                                  Tunning Heater 1
                                  Commencing at an initial temperature of 23°C (ambient)
                                  It stopped at 98°C after 7 min
                                  Tunning Heater 2
                                  Commencing at an initial temperature of 86°C, (achieved through induction heating, I aimed to verify whether the elapsed time was consistent across all). The process halted at a temperature of 158°C.
                                  Tunning Heater 3
                                  Commencing at an initial temperature of 27°C
                                  It stopped at 113°C after 7 min
                                  confg.g
                                  ; Drivers
                                  Endstops
                                  ;Z-probe
                                  G31 X20 Y-10 Z0 P100
                                  Heaters
                                  M307 H1 B0 R0.575 C791.0 D20.76 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
                                  M307 H2 B0 R0.768 C389.3 D15.78 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
                                  M307 H3 B0 R0.533 C588.3 D18.57 S1.00 V23.9 ; disable bang-bang mode for heater and set PWM limit
                                  M567 P0 E1:1
                                  Conf-override.g
                                  • Casugoundefined
                                    Casugo @gloomyandy
                                    @gloomyandy Hello!!
                                    I have updated the information and I still having the same issue 😭
                                    Could you please help me?
                                      gloomyandy @Casugo
                                      @Casugo Sorry I've really no idea, those heating rates seem very slow for the type of heater you are using, but they are not as slow as some bed heaters. Are you sure that they can ever reach the target temperatures you are trying to use? So for instance if you simply connect the heater cartridge directly to 24V and monitor the temperature using DWC how long does it take to reach your target temperature? Obviously make sure you do not leave this test set up running unattended!
                                      • Casugoundefined
                                        Casugo @gloomyandy
                                        @gloomyandy
                                        Yes, the heaters are capable of reaching the desired temperature as when I heat them they do it without problem. However, I am encountering difficulties with PID tuning. Also, when I attempt to initiate a print, the heaters initially reach the target temperature, but at the moment it start the printing process, they suddenly shut off, and all temperature readings show 2000. I'm uncertain whether this issue is pobably related to incomplete reception of the 24V power supply or if there's interference between the thermocouples and the stepper motors causing this problem.
                                          gloomyandy @Casugo
                                          @Casugo Can you post a screenshot of the temperature graph when heating "normally" so that we can see how the temperature rises and how long it takes to reach your target temperature of 180.
                                          • Casugoundefined
                                            Casugo @gloomyandy
                                            @gloomyandy
                                            Update:
                                            I simultaneously heated all three heaters, and the following are the results:
                                            Heater 3 displayed an error: "T0 Error: Heater 3 fault: temperature rising much more slowly than the expected 0.5°C/sec" (Fig 1).
                                            While the other heaters continued to heat up, they reached the desired temperature after approximately 14 minutes for heater 1 (Fig 2) and 13 minutes for heater 2 (Fig 3)."
