    Duet3D announces new tool board at FormNext
    107
    9.0k
    • fcwiltundefined
      fcwilt @A Former User
      @Herve_Smith
      You consider the prices to be an issue?
      The money I spend on hardware is dwarfed by the money I spend on filament.
      A Former User? Surgikillundefined 2 Replies Last reply Reply Quote 1
        A Former User @A Former User
        @Herve_Smith
        Lets see, nearest competitor is the BD sensor, runs around $30 plus many weeks delay to get shipped here. And a toolboard, either the Ebb36 or fly run around $45+. Then I would get to integrate it into the controller board/Raspberry Pi ecosystem ( Pi boards are dropping in price but still expensive ) that is needed along with the work needed to control all the parts. Make sure you RTFM before you ask any questions if you get stuck. And praise Klipper to high heaven on any post.
        So a Duet setup Toolboard/Scanning sensor that does not use the Pi will be cheaper and much easier to setup.
        But you will get the Klipper Smug factor to throw around if you go that route 😉
        I bought a PandaPi BDsensor awhile back to play with and installed it on an Ender 3 running Marlin that was later donated . Its actually a decent device and works well but did involve a few ( many ) curse words.. I imagine the Duet board will be much easier to set up .
          A Former User @fcwilt
          This post is deleted!
          • Surgikillundefined
            Surgikill @fcwilt
            @fcwilt said in Duet3D announces new tool board at FormNext:
            @Herve_Smith
            Toolboards are primarily made for tool changer setups, so multiply your cost difference by the number of toolheads. I'm currently building a tool changer, and each toolhead is going to run me close to $400. At some point, cost becomes a favor. When my toolhead alone is over double the cost of an ender 3 you have to take a step back and reevaluate.
            fcwiltundefined o_lampeundefined edspedundefined 3 Replies Last reply Reply Quote 1
            • fcwiltundefined
              @Herve_Smith
              Makes sense.
              But if the cost of filament is passed along to customers surely the cost of maintaining the equipment is also passed along.
                Surgikill @dc42
                @dc42 can you give us the exterior dimensions of the board? I'm trying to see how it will fit in my printer.
                Surgikillundefined 1 Reply Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @Surgikill
                  @Surgikill
                  Very true.
                  But comparing a custom made 4 tool printer to a "mass produced" Ender 3 made in China is really comparing apples to aardvarks.
                  Not the same thing at all.
                  Good luck with the printer.
                  I've only installed 2 of the tools on my E3D MS/TC.
                    • fcwiltundefined
                      @Herve_Smith said in Duet3D announces new tool board at FormNext:
                      upto a point, i only print for money to allow me to offset the cost printing for myself.
                      Ah, I was thinking that printing for customers was your primary business. Understand now.
                      as you dont need to create a levelling mesh map very often ( you only need to ask @deckingman to beat that drum)
                      His machines are impressive. If I tried to build a printer like that I might find myself single again, as the wife would be most upset. 😁
                        deckingman @fcwilt
                        ............................ If I tried to build a printer like that I might find myself single again, as the wife would be most upset. 😁
                        I saw my name mentioned so...............
                        Actually the latest iteration of my machine has a larger print area in X and Y but less in Z and with just a single reel of filament the overall "envelope" is smaller. And being fully enclosed it's near silent outside of the room that it sits in so " 'er in doors" is reasonably content.
                        But yeah, who needs a scanning bed probe when, if the machine is built correctly (which is neither difficult nor expensive to do) all one needs to do is home Z? 🙂
                        • fcwiltundefined
                          fcwilt @deckingman
                          @deckingman said in Duet3D announces new tool board at FormNext:
                          Is there a link to any pictures or videos?
                          How do you cope with bed irregularities? On my three most used printers the bed flatness varies by appx 0.25mm. That is in excess of two layers when layer height is 0.1mm. I have not found an alternative to using mesh bed compensation.
                            deckingman @fcwilt
                            I documented the entire build from design to completion on my YT channel and even created a play list of the 14 videos which were spread over about 3 months. I took somewhere between 200 and 300 pictures and the videos contain most of those still images. My YT channel is linked in my signature.
                            You've done something wrong then. Either you haven't used cast machined tooling plate, or you've mounted it in such a way as to distort it, or you haven't got the XY gantry "tram" with the plane of the bed. Watch part 7 of my build https://www.youtube.com/watch?v=XLLdK7Bu464. With a DTI fixed in place of the print head, after levelling the bed and "tramming" the gantry the results showed a maximum deviation of 0.03mm over the entire 400mm x 400mm surface of the bed. I've done numerous near edge to edge prints ever since and never yet had a first layer that wasn't perfect.
                            fcwiltundefined 2 Replies Last reply Reply Quote -1
                            • fcwiltundefined
                              fcwilt @deckingman
                              The flatness of typically available plate is appx 0.40mm for plate less than 12mm thick. For 12mm or thicker it drops to appx 0.14.
                              So what did you use to obtain 0.03?
                              My machinist has nothing as flat as that.
                              Surgikillundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                Surgikill @fcwilt
                                @fcwilt Just to add onto this, here is the spec sheet for ATP-5 where they list the flatness tolerance. >1/2" is 0.127mm, <=1/2" is 0.381mm.
                                https://www.midweststeelsupply.com/store/ATP5Flyer.pdf
                                • fcwiltundefined
                                  fcwilt @Surgikill
                                  @Surgikill said in Duet3D announces new tool board at FormNext:
                                  Thanks. Those values are similar. Perhaps it depends on the manufacture of the plate.
                                  I had a bed custom made and it measured out as flat within 0.09 but the add-on build surface product spoiled it and, overall, it ended up flat within appx 0.25.
                                  Now mesh bed compensation makes the printer work just fine.
                                  I wonder how d-man achieved 0.03 flatness over 400mm by 400mm, my machinist was pleased with the 0.09 figure over 250mm by 250mm
                                    Surgikill @fcwilt
                                    @fcwilt I watched the video that was linked. I don't think the entire bed was measured. I saw 5 dial indicator test points, one at bed center, and then one at each corner of the bed. Maximum measurement was 0.04mm, minimum was -0.03, so total flatness from those 5 points would be 0.07mm (Flatness is defined as two parallel planes on either side of the flat surface as the tolerance zone for the surface. All the points on the specified surface must lie between these two planes.)
                                    I'm not sure if the entire bed was measured in a grid to determine any high spots, but you can't really determine the flatness of a material by measuring 5 points and then assuming the rest of the bed falls within that tolerance.
                                    On the other hand, I believe the tooling plate comes in 6'x12' stock sizes, and I believe that flatness tolerance is for the entire 6'x12' stock, so you might get a tighter tolerance than specified seeing as we are only using a small portion of that large stock size, but I wouldn't bet money on it.
                                    • fcwiltundefined
                                      fcwilt @Surgikill
                                      @Surgikill
                                      I haven't seen the video.
                                      I will have to call Midwest and see if they can clarify the issue with regards to the size of the piece.
                                      And when they cut a piece do they perhaps deform it in the process?
                                      The custom bed I had made was measured by the machinist and it was, as I mentioned, flat with 0.09. I did not ask him how he measured that. I should.
                                      I have another bed on order being made from a stainless steel which the machinist says will produce the best results. Time will tell on that.
                                      Thanks much.
                                        Surgikill @fcwilt
                                        @fcwilt That guaranteed flatness is before and after sawing. They are most likely giving themselves some buffer in that number. I would imagine that your machinist probably used a surface plate, something like this setup. https://www.youtube.com/watch?v=WwUqPiQ9JAQ
                                        • fcwiltundefined
                                          fcwilt @Surgikill
                                          @Surgikill
                                          Thanks for the video. It was very interesting and educational.
                                            deckingman
                                            It matters not a jot to me whether you believe me or not because I know for a fact that my bed is both flat and level within +- 0.03mm at any point over the entire surface, and that I can print edge to edge with no firmware compensation of any kind.
                                            Except that maybe you are calling me a liar to which I object very strongly.
                                            This video was shot many years ago using the exact same build plate and before mesh compensation had been added to the firmware. Also, I use a single motor and continuous belt driving 3 lead screws so automatic bed leveling is not possible.
                                            https://youtu.be/U733PMTou7M?si=cgGvQHLgwxZdXike
                                            How do you explain that if I'm the liar that you are implying that I am?
                                            Surgikillundefined 1 Reply Last reply Reply Quote -1
