    Duet3D announces new tool board at FormNext
    107
    8.8k
      We are pleased to announce our new Revo Roto Tool board (TOOL1RR). We designed this to match the new Revo Roto lightweight extruder from E3D but there is nothing to stop you using it with other extruders. Features include:
      • Compact size to fit on small tool heads
      • One TMC2240 stepper driver
      • Hot end heater output and sensor input
      • Cold end temperature sensor input
      • Accelerometer
      • Scanning Z probe with thermistor for temperature compensation
      • Addional I/O for fans, other Z probes, endstops, docking switches, filament monitoring etc.
      See https://www.duet3d.com/Duet3RotoToolboard for photo. Documentation to follow.
      o_lampeundefined Surgikillundefined 2 Replies Last reply Reply Quote 9
      • o_lampeundefined o_lampe referenced this topic
      • o_lampeundefined
        o_lampe @dc42
        @dc42 The TMC2240 can handle 36V.
        Is the toolboard ready for it and does the Revo Roto come with a matching heater cartridge and fan?
        elmoretundefined 1 Reply Last reply Reply Quote 0
        • elmoretundefined
          elmoret @o_lampe
          @o_lampe Roto uses regular Revo heatercores, so 12v/24v. You could optionally use a Hemera heatbreak or their Revo HT heaterblock to use a regular heater cartridge.
          Fan is 5v.
          nikschaundefined 1 Reply Last reply Reply Quote 0
            A Former User
            This post is deleted!
            fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @A Former User
              @Herve_Smith
              You consider the prices to be an issue?
              The money I spend on hardware is dwarfed by the money I spend on filament.
              A Former User? Surgikillundefined 2 Replies Last reply Reply Quote 1
                A Former User @A Former User
                @Herve_Smith
                Lets see, nearest competitor is the BD sensor, runs around $30 plus many weeks delay to get shipped here. And a toolboard, either the Ebb36 or fly run around $45+. Then I would get to integrate it into the controller board/Raspberry Pi ecosystem ( Pi boards are dropping in price but still expensive ) that is needed along with the work needed to control all the parts. Make sure you RTFM before you ask any questions if you get stuck. And praise Klipper to high heaven on any post.
                So a Duet setup Toolboard/Scanning sensor that does not use the Pi will be cheaper and much easier to setup.
                But you will get the Klipper Smug factor to throw around if you go that route 😉
                I bought a PandaPi BDsensor awhile back to play with and installed it on an Ender 3 running Marlin that was later donated . Its actually a decent device and works well but did involve a few ( many ) curse words.. I imagine the Duet board will be much easier to set up .
                  A Former User @fcwilt
                  • Surgikillundefined
                    Surgikill @fcwilt
                    @fcwilt said in Duet3D announces new tool board at FormNext:
                    @Herve_Smith
                    Toolboards are primarily made for tool changer setups, so multiply your cost difference by the number of toolheads. I'm currently building a tool changer, and each toolhead is going to run me close to $400. At some point, cost becomes a favor. When my toolhead alone is over double the cost of an ender 3 you have to take a step back and reevaluate.
                    fcwiltundefined o_lampeundefined edspedundefined 3 Replies Last reply Reply Quote 1
                    • fcwiltundefined
                      @Herve_Smith
                      Makes sense.
                      But if the cost of filament is passed along to customers surely the cost of maintaining the equipment is also passed along.
                        Surgikill @dc42
                        @dc42 can you give us the exterior dimensions of the board? I'm trying to see how it will fit in my printer.
                        Surgikillundefined 1 Reply Last reply Reply Quote 0
                        • fcwiltundefined
                          fcwilt @Surgikill
                          @Surgikill
                          Very true.
                          But comparing a custom made 4 tool printer to a "mass produced" Ender 3 made in China is really comparing apples to aardvarks.
                          Not the same thing at all.
                          Good luck with the printer.
                          I've only installed 2 of the tools on my E3D MS/TC.
                            • fcwiltundefined
                              @Herve_Smith said in Duet3D announces new tool board at FormNext:
                              upto a point, i only print for money to allow me to offset the cost printing for myself.
                              Ah, I was thinking that printing for customers was your primary business. Understand now.
                              as you dont need to create a levelling mesh map very often ( you only need to ask @deckingman to beat that drum)
                              His machines are impressive. If I tried to build a printer like that I might find myself single again, as the wife would be most upset. 😁
                                deckingman @fcwilt
                                ............................ If I tried to build a printer like that I might find myself single again, as the wife would be most upset. 😁
                                I saw my name mentioned so...............
                                Actually the latest iteration of my machine has a larger print area in X and Y but less in Z and with just a single reel of filament the overall "envelope" is smaller. And being fully enclosed it's near silent outside of the room that it sits in so " 'er in doors" is reasonably content.
                                But yeah, who needs a scanning bed probe when, if the machine is built correctly (which is neither difficult nor expensive to do) all one needs to do is home Z? 🙂
                                • fcwiltundefined
                                  fcwilt @deckingman
                                  @deckingman said in Duet3D announces new tool board at FormNext:
                                  Is there a link to any pictures or videos?
                                  How do you cope with bed irregularities? On my three most used printers the bed flatness varies by appx 0.25mm. That is in excess of two layers when layer height is 0.1mm. I have not found an alternative to using mesh bed compensation.
                                    deckingman @fcwilt
                                    I documented the entire build from design to completion on my YT channel and even created a play list of the 14 videos which were spread over about 3 months. I took somewhere between 200 and 300 pictures and the videos contain most of those still images. My YT channel is linked in my signature.
                                    You've done something wrong then. Either you haven't used cast machined tooling plate, or you've mounted it in such a way as to distort it, or you haven't got the XY gantry "tram" with the plane of the bed. Watch part 7 of my build https://www.youtube.com/watch?v=XLLdK7Bu464. With a DTI fixed in place of the print head, after levelling the bed and "tramming" the gantry the results showed a maximum deviation of 0.03mm over the entire 400mm x 400mm surface of the bed. I've done numerous near edge to edge prints ever since and never yet had a first layer that wasn't perfect.
                                    fcwiltundefined 2 Replies Last reply Reply Quote -1
                                    • fcwiltundefined
                                      fcwilt @deckingman
                                      The flatness of typically available plate is appx 0.40mm for plate less than 12mm thick. For 12mm or thicker it drops to appx 0.14.
                                      So what did you use to obtain 0.03?
                                      My machinist has nothing as flat as that.
                                      Surgikillundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                        Surgikill @fcwilt
                                        @fcwilt Just to add onto this, here is the spec sheet for ATP-5 where they list the flatness tolerance. >1/2" is 0.127mm, <=1/2" is 0.381mm.
                                        https://www.midweststeelsupply.com/store/ATP5Flyer.pdf
                                        • fcwiltundefined
                                          fcwilt @Surgikill
                                          @Surgikill said in Duet3D announces new tool board at FormNext:
                                          Thanks. Those values are similar. Perhaps it depends on the manufacture of the plate.
                                          I had a bed custom made and it measured out as flat within 0.09 but the add-on build surface product spoiled it and, overall, it ended up flat within appx 0.25.
                                          Now mesh bed compensation makes the printer work just fine.
                                          I wonder how d-man achieved 0.03 flatness over 400mm by 400mm, my machinist was pleased with the 0.09 figure over 250mm by 250mm
                                            Surgikill @fcwilt
                                            @fcwilt I watched the video that was linked. I don't think the entire bed was measured. I saw 5 dial indicator test points, one at bed center, and then one at each corner of the bed. Maximum measurement was 0.04mm, minimum was -0.03, so total flatness from those 5 points would be 0.07mm (Flatness is defined as two parallel planes on either side of the flat surface as the tolerance zone for the surface. All the points on the specified surface must lie between these two planes.)
                                            I'm not sure if the entire bed was measured in a grid to determine any high spots, but you can't really determine the flatness of a material by measuring 5 points and then assuming the rest of the bed falls within that tolerance.
                                            On the other hand, I believe the tooling plate comes in 6'x12' stock sizes, and I believe that flatness tolerance is for the entire 6'x12' stock, so you might get a tighter tolerance than specified seeing as we are only using a small portion of that large stock size, but I wouldn't bet money on it.
