    Duet 3 Scanning Z probe
    88
    6.0k
    • oozeBotundefined
      oozeBot @T3P3Tony
      @T3P3Tony what's the upper temp limitations on this initial version and is there any opportunity to use the build plate's temp within RRF to average at higher temps? Or will that only be available on future versions with a built-in thermistor to the probe? Also, is it possible to set actual z-height with the probe? Or just scan the surface once z-height has been set. Thanks!
      • jens55undefined
        jens55 @T3P3Tony
        @T3P3Tony , just to confirm - this probe does not work with a glass surface ? .... and presumably doesn't work with any other non-metal surface such as PEI, gerolite etc etc?
        Thank you for mentioning the increased number of probing points available for the 6HC, I was unaware.
        • fcwiltundefined
          fcwilt @T3P3Tony
          @T3P3Tony
          And if it works like I hope I have printers running on v2 hardware that will need to be updated.
          So clearly this is a clever plan to sell more v3 hardware. 😀
          • R4ffersundefined
            R4ffers
            I definitely want to give this a go
            Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
              A Former User @fcwilt
              @fcwilt I'll wait a bit and see if they combine this with the tool board. A 1LC+ would be awesome!
              fcwiltundefined o_lampeundefined 2 Replies Last reply Reply Quote 2
              • fcwiltundefined
                fcwilt @A Former User
                @KenW
                That would be good.
                I have a few 1LC boards but have never gotten around to trying them out on one of my existing printers.
                Though I have re-designed my E3D Hemera XS mount that I have on my E3D MS/TC printer with the idea of trying them.
                Too much to do and too little time. 😖
                  @fcwilt Figure since they included the accelerometer and it has the CAN-FD hardware adding it to a toolboard would seem to be an option.
                  Replace the JST-ZH with a larger connector and keep the 3 and 4 pin fans and other IO and I would definitely reduce the wire count on my printers.
                  • o_lampeundefined
                    o_lampe @A Former User
                    @KenW said in Duet 3 Scanning Z probe:
                    Didn't take long to fulfill your wish 😁
                      A Former User @o_lampe
                      @o_lampe
                      Now I get to wait until some make it across the ocean blue.
                      Documentation to make sure it can be made to work is needed too.
                      I see it has 3 pin fans so the 4 pin 12v 4010's I finally found are not usable but the 3 pin 12v blowers might be. The ZH connector is history, several others are beefier and all appear to be easier for an old dude to crimp.
                      I'll pause my work on the rebuild of the printer and the eventual updating of the other 2 to see . The Roto looks interesting too. And might solve the width issue I am having with the IDEX conversion idea. As well as weight.
                      • zaptaundefined
                        zapta @T3P3Tony
                        Duet3D keeps innovating. 😉 This is very good.
                        I guess that with this fast scanner, it's more feasible to run bed mesh before each print.
                        • Notepadundefined
                          Notepad
                          Really excited to try this. If it can do the auto calibration for sensitivity, it may be able to remove the issue that plagues regular inductive probes because of ambient temperature drift.
                          The real bamboo printer manufacturer
                          droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            droftarts administrators @Notepad
                            @Notepad yes, it does an auto-calibration before scanning. The probe board also has a thermistor, an accelerometer and CAN connector. It should be possible to compensate for temperature using the thermistor, or use the thermistor to check that the temperature is the same for each scan. So it could theoretically be used as a Z probe, but we currently recommend a more reliable bed surface probe; our demo machine uses Voron tap, but any other Z probe should be fine.
                            The probe scans the top-most metal surface, in the case of the Voron Tridex at the show, this is the spring steel backing of the PEI sheet. We found we could put a business card between the PEI sheet and the aluminium bed, and it would show as a large deviation in the bed! If it was in the right place you could see the rectangular outline of the card. I forgot to take a picture of it, but it showed the bed mesh was being updated each time it was scanned, ie not a faked show display!
                            A Former User? 1 Reply Last reply Reply Quote 2
                              dc42 administrators @Notepad
                              @Notepad the auto calibration is only possible if you have another way of establishing Z=0 first. This could be another type of Z probe such as a BLTouch, or manual probing.
                              We haven't yet tried using the scanning probe as the only Z probe. To do this you would need to do the following:
                              • Set an accurate Z=0 reference, run the calibration command, and save the results in config.g
                              • At several different temperatures, measure the Z height that produces the reference output value from the probe, and use these measurements to set up suitable temperature compensation in the M558 command.
                              Notepadundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                              • Notepadundefined
                                Notepad @dc42
                                @dc42 said in Duet 3 Scanning Z probe:
                                Ahh, so reference point first, then it can scan the entire bed.
                                Ill definitely be testing this out once I get mine, as a bit of pain calibrating it initially will mean I don't have to constantly carry a inductive/BLTouch on the toolhead.
                                • fcwiltundefined
                                  fcwilt @dc42
                                  That is a bit of bad news.
                                  It makes the product less appealing.
                                  I need to think on this a bit.
                                  Notepadundefined droftartsundefined 2 Replies Last reply Reply Quote 1
                                  • zaptaundefined
                                    zapta
                                    If I got it correctly, this is the third Duet3D Z sensor, each with a very different technology. The quest for the ultimate Z sensor continues. 😉
                                      A Former User @droftarts
                                      This post is deleted!
                                      • Notepadundefined
                                        Notepad @fcwilt
                                        @fcwilt said in reference to @dc42 Duet 3 Scanning Z probe:
                                        It definitely makes the switch over not as simple of a choice. Hopefully if I can figure out a test cycle or homing regime to use it as the only Z probe, Ill share that to everyone.
                                        If it cant be used stand alone. The main selling point of fast and compact bed scanning looses the compact aspect as there would need to be a redundant probe just for initial offset measurements.
                                        • zaptaundefined
                                          zapta @A Former User
                                          @Herve_Smith, what the scanner provides is similar to what the inductive probe provides with Voron 2.4 but at an order of magnitude faster. That is, height measurement relative to a known zero, which is provided by the 'tap' end switch or similar.
                                          In other words, it takes a z=0 point at a given (x,y) and quickly provide zero points on the entire bed surface. The alternative is to use an absolute Z probe (e.g. BL Touch or Cliky) and slowly probe the entire bed, or wait until a fast absolute Z probe will be invented.
                                          Wether this product has value to your application it's up to you.
                                          • fcwiltundefined
                                            fcwilt @Notepad
                                            @Notepad said in Duet 3 Scanning Z probe:
                                            And the speed would allow creating a new height map for every print which would be nice for me since I use a variety of printing surfaces.
                                            For me the speed is the real benefit. The 8mm inductive sensors I use take up very little space.
                                            Notepadundefined 1 Reply Last reply Reply Quote 0
