    reference the X-axis on both rails
    Using Duet Controllers
    2.5k
      droftarts administrators @axiom
      @axiom for displaying code in posts, please use the code tags. It’s the </> icon on the toolbar above where you type in your post. It should put 3 tick marks at the beginning and end of your code. It makes it much more readable for people trying to help you. Single tick marks either side of text make that text inline code, like this.
      • fcwiltundefined
        fcwilt @axiom
        @axiom
        What expansion board are you using?
        On my 3 Z stepper printer I am using Duet 2 boards: Duet WiFi and a Duex5.
        My M574 for the Z endstops looks like this:
        M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop" ; configure active-high endstop for low  end on Z
        The Z endstop sensors are connected to the Duex5 and I included the duex. prefix. I recall that it was necessary.
        droftartsundefined 1 Reply Last reply Reply Quote 1
          Phaedrux Moderator @axiom
          @axiom said in reference the X-axis on both rails:
          M574 Z1 S1 P"e2stop + e3stop + e4stop + e5stop"
          If you send M98 P"config.g" you'll probably get an error saying invalid pin or something like that for that line.
            droftarts administrators @fcwilt
            @fcwilt as @Phaedrux says, the pin names are wrong. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
            Should be duex.e2stop etc.
            axiomundefined 1 Reply Last reply Reply Quote 0
            • axiomundefined
              axiom @droftarts
              @droftarts
              I have now adjusted the names, but the endstops are still not accepted. Here is the message from the m119 command and the M98 P"config.g" command. And below again my adapted code
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is enabled on port 21
              TELNET is enabled on port 23
              Error: in file macro line 50 column 65: M574: string too long
              Warning: Macro file config-override.g not found
              16.11.2023, 15:50:48
              m119
              Endstops - X: at min stop, Y: not stopped, Z: no endstop, Z probe: not stopped
              All control LEDs respond...The 4 motors on the expansion board react and can be controlled
              I think it's not a hardware error it is a DueX5 xspansionboard
              again my adapted code:
              ; Configuration file for Duet WiFi (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit)
              M550 P"DUKA1300" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S1 ; enable Telnet
              ;M569 P4 R-1 ; Treiber 4 deaktivieren
              ;M569 P3 R-1 ; Treiber 4 deaktivieren
              M569 P4 S0 ; physical drive 3 goes forwards
              M569 P5 S1 ; physical drive 3 goes forwards Expansionboard
              M569 P6 S1 ; physical drive 3 goes forwards Expansionboard
              M569 P7 S1 ; physical drive 3 goes forwards Expansionboard
              M569 P8 S1 ; physical drive 3 goes forwards Expansionboard
              ;M584 X0 Z2 E1 ; set drive mapping
              ;M584 X0:4 Y1 Z2 E3 ; set drive mapping
              M584 X0:4 Y1 Z5:6:7:8 E3 ; set drive mapping
              M92 X80.00 Y80.00 Z640 E322.58 ; set steps per mm
              M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
              ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
              M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
              M906 X1800 Y1800 Z1700 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X100 Y0 Z0 S1 ; set axis minima
              M208 X750 Y640 Z1220 S0 ; set axis maxima
              M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S1 P"duex.e2stop + duex.e3stop + duex.e4stop + duex.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              ;M558 K0 P1 C"e1stop" ;H5 F120 T6000
              M558 K0 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
              ;M557 X0:735 Y-27:573 S35 ; define mesh grid
              ; Z-Probe two of them
              ;M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
              ;M558 K1 P8 A2 S0.2 C"!zstop" H5 F80 T3000
              ;G31 P1000 K0 X-1 Y-61 Z0.484 ; set Z probe trigger value, offset and trigger height (Kapazitiver Sensor)
              ;G31 P1000 K1 X0 Y0 Z12.664 ; Second Z-offset
              ; Bed
              ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
              ;M307 H2 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
              M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S280 ; set temperature limit for heater 0 to 120C
              ;Hotend
              M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
              M143 H1 S400 ; set temperature limit for heater 1 to 400C
              M950 F2 C"fan2" Q350 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1 T60 ; set fan 2 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0 ; define tool 1
              G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
              G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
              ; Filamentsensor
              ;M591 D0 P1 C"zstop" S1 ;R40:120 E3.0 S1 Filament Sensor
              ;Auto Z-Offset
              M501
              fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @axiom
                @axiom
                Did you try shortening the line? I believe the comment is included when it comes to being too long.
                And you can remove the M501 at the end if you wish to silence the error about config-override.g being missing.
                  @axiom What firmware version are you on? This has come up before, and it's because the string for the endstops is too long. See https://forum.duet3d.com/topic/32954/duet-2-wifi-voron-2-4-multiple-z-endstops-query
                  This was fixed in RRF 3.4.6, with an increase from 50 to 61.
                  However, I think you just need to take out the spaces in yours to get under the 50 character limit, ie
                  M574 Z1 S1 P"duex.e2stop+duex.e3stop+duex.e4stop+duex.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                  That's 47 characters.
                  axiomundefined 1 Reply Last reply Reply Quote 1
                  • axiomundefined
                    axiom @droftarts
                    @droftarts Deleting the spaces was the solution...it no longer gives an error
                    dfe0d5e9-eef0-4361-947d-47d8479584c3-grafik.png message and the g1 h1 z0 command works and the bed stops at the endstops...now I can continue researching! Thank you so much!!!!
                      @axiom What firmware version? Send M115 in the console and post response, please.
                      • axiomundefined
                        axiom @droftarts
                          @axiom You'll probably find it easier if you update to RRF 3.4.6, the current release. You shouldn't have to change your configuration.
                          • axiomundefined
                            axiom @droftarts
                            @droftarts said in reference the X-axis on both rails:
                            Can I just click on it here, or do I have to prepare something?
                              @axiom download "Duet2and3Firmware-3.4.6.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.6 without unzipping it, then upload it to the Duet. It will unpack it and install the firmware update.
                              There's a whole wiki page on firmware updates: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware
                              • axiomundefined
                                axiom @droftarts
                                @droftarts Is there something to update for the Due5 expansion board...or is that okay?5d5f7a8d-0e0f-48c6-9e71-6da9b72fbfb8-grafik.png
                                  The Duex does not have it's own firmware.
                                  • axiomundefined
                                    axiom
                                    @fcwiltI have now adapted the home files according to your stage directions (see below) and removed the homeall.g as you said. when I click the reference button on the user interface 925b48d8-d775-4e9c-a5ee-7cd39c479064-grafik.png , the error message comes up:
                                    Now I don't know what homeall.g should look like?
                                    Here are my new homing files:
                                    ; homex.g
                                    ; called to home the X axis
                                    G91 ; relative positioning
                                    G1 H1 Z5 F6000 ; lift Z relative to current position
                                    G1 H1 X-755 F6000 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H1 X10 ; go back a few mm
                                    G1 H1 X-10 F600 ; move slowly to X axis endstop once more (second pass)
                                    G1 H1 Z-5 F6000 ; lower Z again
                                    G92 X0 ; where ### is the actual axis position when the motion stopped - usually determined by testing
                                    ; homey.g
                                    ; called to home the Y axis
                                    G1 H1 Y-643 F6000 ; move quickly to Y axis endstop and stop there (first pass)
                                    G1 H2 Y10 ; go back a few mm
                                    G1 H1 Y-10 F600 ; move slowly to Y axis endstop once more (second pass)
                                    G1 H2 Z-5 F6000 ; lower Z again
                                    G92 Y0 ;where ### is the actual axis position when the motion stopped - usually determined by testing
                                    ; homez.g
                                    ; called to home the Z axis
                                    G1 H1 Z-1230 F6000 ; lift Z relative to current position
                                    G1 Z20 ; back off a bit
                                    G1 H1 Z-20 F300 ; slow move to min endstop
                                    G92 Z7,1 ; home Z by probing the bed
                                    fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @axiom
                                      @axiom
                                      I don't recall saying to remove the homeALL.g file.
                                      What I think I said was I don't duplicate homing code so my homeALL.g file looks something like this:
                                      M98 P"homeZ.g"
                                      M98 P"homeX.g"
                                      M98 P"homeY.g"
                                      The results are the same but there is no actual "homing" code in homeALL.g.
                                      • fcwiltundefined
                                        fcwilt @axiom
                                        @axiom
                                        And since you now have Z endstops you don't need to use the type of homing code the configuration tool generates.
                                        I also suggest you work towards not using the configuration tool and learn how to create your own code.
                                        Your code will likely be better and fixing code related problems will be easier since you fully understand what you coded.
                                        Didn't I post examples of what your basic homing files would look like?
                                        Basically you do:
                                        • a fast G1 H1 move toward the endstop
                                        • a short fast move G1 move away from the endstop
                                        • a slow G1 H1 move toward the endstop
                                        • a possible G92 to set the logical position of the axis being homed to match the physical position
                                        Assume a printer where the X endstop is at the min end of the X axis and the axis has a range of motion of 300mm:
                                        G1 H1 X-310 F6000
                                        G1 X20
                                        G1 H1 X-25 F600
                                        G92 X=nnn ; where nnn is actual position of the X axis after the 3 moves above
                                        Frederocl
                                        • axiomundefined
                                          axiom @fcwilt
                                          I'm just stuck...if my z-endstops are set to 4 and I want to reference...but the bed is already above the end stops, e.g. 2...then the bed moves into the head. So I currently have to move the bed below the endstops before referencing...how can I correct this in the z-home. Here are my files again:
                                          ; homez.g
                                          G1 H1 Z-1225 F4000 ; lift Z relative to current position
                                          G1 Z10 ; back off a bit
                                          G1 H1 Z-10 F300; slow move to min endstop
                                          G92 Z4 ; home Z by probing the bed
                                          ; homex.g
                                          G1 H1 Z5 F4000 ; lift Z relative to current position
                                          G1 H1 X-755 F4000 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 H1 X-10 F300 ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Z-5 F4000 ; lower Z again
                                          G1 x10
                                          ; homey.g
                                          G1 H1 Y-643 F4000 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 H1 Y-10 F300 ; move slowly to Y axis endstop once more (second pass)
                                          G1 H2 Z-5 F64000 ; lower Z again
                                          G1 y10
                                          and homeall:
                                          M98 P"homeY.g"
                                          M98 P"homeX.g"
                                          M98 P"homeZ.g"
                                          M208 X750 Y643 Z1220 S0 ; set axis maxima
                                          M558 K1 P8 A2 S7 C"duex.e6stop" H5 F80 T3000
                                          G31 P1000 K0 X0 Y-25 Z0.817 ; set Z probe trigger value, offset and trigger height (Kapazitiver Sensor)
                                          M557 X0:735 Y-25:573 S35 ; define mesh grid
                                          ; Bed
                                          ;Hotend
                                          M950 F2 C"fan1" Q350 ; create fan 2 on pin fan2 and set its frequency
                                          ; Filamentsensor
                                          M591 D0 P1 C"e1stop" S1 ;R40:120 E3.0 S1 Filament Sensor
                                          ;Auto Z-Offset
                                          M501
                                          • fcwiltundefined
                                            fcwilt @axiom
                                            @axiom
                                            You have to design the mounting of the endstops so they are triggered to the very end of travel.
                                            Here you can see part of the Z axis setup on my tripple Z stepper printer. The endstop switch is activated by the side of that bracket that is supporting the ball stud. The bracket travels along the linear rail. The endstop switch is first activated well before the end of Z travel but remains activated to the very end of travel.
                                            So you cannot move "past" the endstop.
                                            Let's suppose you use a typical bit of homing code like below:
                                            G91
                                            G1 H1 Z-300 F1200
                                            G1 Z50
                                            G1 H1 Z-55 F300
                                            If you start with endstop already activated the first G1 move doesn't actually move and the code continues doing the backup move and then the slow move to endstop.
                                            Some folks include a test to see if the homing code starts out with the endstop activated and if it is the code backs off enough to insure the endstop should no longer be activated and if it is still activated they abort the homing and display and error message.
                                            That "safety" check is a pretty good idea.
