    define an analog input?
    • Zsevenundefined
      Zseven
      Hello ,
      I have a question. How can I define an analog input? For example, it should switch when 3.2 volts are reached?
      Is there a solution ?
      • o_lampeundefined
        o_lampe @Zseven
        @Zseven AD conversion uses lots of interrupts and can disturb the printers main tasks.
        I recommend using a separate AD-converter (e.g. ESP32) and communicate via digital trigger input with the Duet.
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @o_lampe
          @o_lampe
          Hello ,
          but is that basically possible ?
            droftarts administrators @Zseven
            @Zseven Which Duet board? The capabilities of each pin are listed in the wiki page for each board. I think you have a Duet 3 mainboard 6XD? If so, see: https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6XD_Hardware_Overview#inputoutput-port-capabilities
            From that, you can see analogue input is supported on io3.in to io8.in. The inputs will tolerate up to 30V and have 10K series resistors. You also have differential signal, opto-isolated inputs for io5.in to io8.in, rated to 30V. Use M950 with the J parameter to define an input, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#configuration-examples-and-notes
            Once the signal is connected to the Duet, what do you want to do with it? If you want it to trigger on a high input, you can set up a trigger to do this. See https://docs.duet3d.com/en/User_manual/Tuning/Triggers
