    Scara based CNC plasma cutter?
    Using Duet Controllers
    1.2k
    • Exerqtorundefined
      Exerqtor
      I've been looking into building a CNC plasma for a while, but the potential machine footprint's been holding me back.
      Now Arcdroid has rewamped my interest, being a scara based platform it has a (relatively) tiny footprint:
      And with the new M23CL steppers I got thinking about if this could be something one would be able to DIY with a Duet controller and RRF in some way. The machine it self i can't see any other obticles with than mechanical engineering(relative ease), the "simple trace" funcinality of the Arcdroid however i'm a little more "worried" about if would be possible to implement in a elegant way.
      I guess the data would be readily avalible from the encoders in the M23CL, but the software part of it, is it something we could make work in RRF? Just for referance the Arcdroid apparently runs on a Marlin fork.
      TLDR: Would it be relatively doable to make a DIY scara CNC plasma robot with the same features as a Arcdroid using Duet3D hardware and RRF?
      droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Exerqtor
        @Exerqtor Looks interesting! I've always wanted a plasma CNC...
        This video shows the inside quite well https://youtu.be/qIk-UxMZ0U4?si=gMgWM8EIeHTX0FW0&t=191. I like how both motors are in the base, and it uses a linkage for the distal arm movement. I'm not sure if that makes it a SCARA or some other kinematic; @JoergS5 would know!
        I'd think a Duet and 2x M23CL motors would work well. You would have to ask @dc42 if we could plot the position with the motors.
        There's another thread about building a plasma cutter, and possible problems with EMI: https://forum.duet3d.com/topic/34164/pantograph-help-against-emi-from-plasma-cutter-or-arc-welder
        @o_lampe might be interested in this too.
        o_lampeundefined JoergS5undefined Exerqtorundefined 3 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @droftarts
          @droftarts Interesting video. It doesn't show much about the internals but it confirms my findings so far:
          • shielded housing
          • EMI filtered Mains socket
          What I don't like is the small working area of a SCARA with regards to the weight of the plasmagun and stiffness of the airtube. You'd spend a fortune for decent bearings.
          I've seen other plasma tables with PLA-printed H-bot frames. IMHO they will disintegrate in no time due to the intense UV-light.
          I'm not even sure if one should use silicone-rubber belts?
          Maybe I'm overthinking things: the plasma flame is mostly below the metall sheet.
          With a dark colored water tank underneath the cutting table, we should be safe. (although I like the hinged cutting table, it won't have a water tank)
          • JoergS5undefined
            JoergS5 @droftarts
            @droftarts said in Scara based CNC plasma cutter?:
            Dear Ian, this is a serial scara with one axis being parallelogram-based in the middle. The parallelogram makes sure that axes stay parallel between begin and end of the construction (and the orientation, ie the XY rotational angle too). It is very similar to the 4 axis palletized robot type.
            Looking at it at a different position (YT at 8:03) at seems to be the 5 bar parallel scara type, with the two actuator starting points being at the same position and the endpoint being cantilevered.
            • o_lampeundefined
              o_lampe @Exerqtor
              @Exerqtor I think the hardest part rearding RRF-conversion would be the manual tracing option. But that's just a feature, you won't need it.
              Maybe there are options to run it on an SBC? All you need is to store each positional data on a button-click.
              Can this be done with Duets CL steppers?
              • Exerqtorundefined
                Exerqtor @droftarts
                Same thing here, but being short on space has held me back. But potentionally being able to build one with this small off a footprint using a ecosystem i'm used to would make me start doing it.
                I figgure we would maybe need motors, since we would need a way to actuate the "Z-axis" lifting mechanism as well. I do suspect it would need to be writen a plugin or something like that to i interpret the motor position together with the kinematic matrix to get a idea of where the arm is in real life or something like that.
                @o_lampe said in Scara based CNC plasma cutter?:
                • shielded housing
                EMI filtered mains socket is best practice to use anyways imo, and shielding the housing seems quite straight forrward (don't look like it's any "special sauce" inside the Arcdroid based on the video in that regard either lol).
                I hear you, and if one have the room for a "convetnional" plasma table that would ofcourse be the way to go, but for me doing automotive and mainly smaller jobs i think the SCARA is more shop and usecase friendly.
                That being mentioned, comming from the automotive industry myself my first thought for a "hub" for the SCARA arm(s) was to use some off the shelf "bolted" wheel bearings. They aren't too-too expensive, easy to mount and should be plenty stiff.
                @JoergS5 said in Scara based CNC plasma cutter?:
                So this means the kinematics should be doable and configured as the "Cantilevered arm 2" in the docs, if i'm getting things right?
                That's what i'm currently and inseptionally view as the biggest hurdle too. My idea was to use a SBC to add some computing power and maybe a PanelDue i7 equivalent screen as an handheld.
                The "simple trace" isn't something i think I would use too-too often, but the ability to move the machine Zera position around on the steel sheet by pushing the arm around manually to position it seems really valuable.
                • JoergS5undefined
                  JoergS5 @Exerqtor
                  @Exerqtor said in Scara based CNC plasma cutter?:
                  I am not sure where the actuators are located. If they are both at the starting point, then yes. If the second one is located at the left big hinge (of the video at 8:03) in the middle of the parallelogram, then one needs to think about whether the angles are the same, then maybe not.
                  It would help to see the red box below the arms opened. My guess is that both actuators are located there, because the parallelogram construction helps to place the heavy actuators away from the moving parts. An actuators placed inside the hinge would counter this idea.
                  The very tall arms the big hinge will result in high Z precision, this person knows IMHO how to make a good design.
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @JoergS5
                    I took some time and grabbed some screenshots of the video where the dude changes out the mainboard in a Arcdroid, here you go 🙂
                    Seems like it's pretty straight forward to me, 2 Nema23's with encoders to drive the kinematics and a standard Nema17 for the "z-axis" from the looks of it:
                    Imgur
                      Looks like the Z axis works on a flex-drive. Keeps the weight off the arm, which is sensible. Looking at a couple of other videos, it taps off before starting each cut, but that doesn't strike the arc. I guess the same thing could be done to create a 'bed mesh'.
                      I don't know if the closed loop motors continuously track position, and update the Object Model, even when the motor is disabled; I don't see why they couldn't be, but I've asked @dc42. If they do, it would be quite straight forward to query the object model for the X and Y position as you move the arms around, for manual tracing.
                      Exerqtorundefined 1 Reply Last reply Reply Quote 2
                      • Exerqtorundefined
                        Exerqtor @droftarts
                        @droftarts
                        Yeah I've seen that too, i was thinking about maybe using the tip itself as a "switch", and have a beefy NO relay that physically breaks the connection between the controllboard and both sides of the "probe wires" when ain't doing a "bed probe" so that the board don't get fried when striking an arc.
                        I'm interested in hearing what thoughts he have on it!
                        Having looked at couple reviews of the Arcdroid i'm not so sure it uses a flex drive to lift the tourch anymore tbh! It looks more like it's just a wire pulling up and depending on gravity and that small spring to aid it going down.
                        Look at this clip for instance, I can't see any threads to acuate the "head" up/down, just seems like a wire.
                        This video also gives a little bit of a tear down view of the machine from about 3:30.
                        "ArcDroid Troubleshoot Followup"
                        • o_lampeundefined
                          o_lampe @Exerqtor
                          Same here, i guess it's a short leadscrew-stepper or similar.
                          Using a pilot-arc (pilot-spark?) to start the torch is a common way to extend life of the nozzle. Then tapping the base is used to set Z=0 only.
                          That pilot arc also works on rusty or painted surfaces.
                          Something you have to keep in mind when using the nozzle as endstop is: there is no guarantee for an electric contact from touching the surface.
                          Using a waterbed has some benefits to consider:
                          • it collects the dust (no mess in the workplace and toxic gases are less of a problem)
                          • it eliminates almost all the sparks (sparks can fly upto 10 meters in all directions and they are very hot)
                          • it keeps thin sheets from warping
                          droftartsundefined 1 Reply Last reply Reply Quote 1
                            droftarts administrators @o_lampe
                            @o_lampe
                            That makes more sense. Looks like a short motor with a longer box above it, so space for a leadscrew, to pull on a cable that goes through the tube to the tool head.
                            • o_lampeundefined
                              o_lampe
                              @Exerqtor
                              I just had the idea to make a bed-slinger plasma table where the torch only does x-motions and the bed is the metal-sheet.
                              That way the waterbed could be very small and the bed frame could be hinged or foldable.
