    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    9.5k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
      @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 after it next resets.
      Will do!
      ClockWatchdogundefined 1 Reply Last reply Reply Quote 0
      • ClockWatchdogundefined
        ClockWatchdog @Exerqtor
        @Exerqtor I had the same errors with 3.4.5 - 3.4.6 and 3.5 Rc 1 with a duet 2 wifi.
        I never had this kind of errors, it started to happen when i used a smartphone as a router. I suspected from the beginning, that the error was caused due to the continuous connect/reconnect. I "solved" (it is a workaround not a fix) using a PC as an Hotspot instead the phone and the crash never happened again. Later i inspected a bit, and with almost every phone or pad i used as an hotspot will cause connection-disconnection-reconnection continously and crashes.
          dc42 administrators @ClockWatchdog
          @ClockWatchdog thanks, that's useful information. We know that the crash happens when something goes wrong during a transaction between the Duet and the WiFi module, but we haven't pinned it down yet.
          Exerqtorundefined ClockWatchdogundefined 2 Replies Last reply Reply Quote 1
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 new crash!
            RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-20 10:16:40) running on Duet 3 Mini5plus WiFi (standalone mode)
            Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
            Used output buffers: 1 of 40 (40 max)
            Static ram: 102844
            Dynamic ram: 123844 of which 0 recycled
            Never used RAM 11872, free system stack 186 words
            Tasks: NETWORK(1,ready,17.4%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 01:06:22 ago, cause: software
            Last software reset at 2023-11-21 16:39, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 0
            Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
            Stack: 00000905 000af288 0002ddb7 2002bed4 2002be01 000001a8 2002c100 20030c10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030c1c 00000800 00000002 2002c100 00000002 2002bf9d 20018668 2001e888 0003002f 00000000 00000000
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 3983208, completed 3983208, timed out 0, errs 0
            MCU temperature: min 34.8, current 35.3, max 38.2
            Supply voltage: min 22.9, current 24.1, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1400/964, gc cycles 185
            Events: 1 queued, 1 completed
            Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: standstill, SG min 246, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 218, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
            Driver 5: not present
            Driver 6: not present
            Date/time: 2023-11-21 17:45:13
            Slowest loop: 15.72ms; fastest: 0.14ms
            === Storage ===
            Free file entries: 18
            SD card longest read time 6.1ms, write time 4.5ms, max retries 0
            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
            no step interrupt scheduled
            Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
            === DDARing 0 ===
            === DDARing 1 ===
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is doing "G4 S1" in state(s) 0 0, running macro
            Aux2 is idle in state(s) 0
            File2 is idle in state(s) 0
            Queue2 is idle in state(s) 0
            Q0 segments left 0, axes/extruders owned 0x0000803
            Code queue 0 is empty
            Code queue 1 is empty
            === Filament sensors ===
            in 0 notIn 0
            Extruder 0 sensor: no filament
            === CAN ===
            Messages queued 35855, received 81685, lost 0, errs 0, boc 0
            Longest wait 2ms for reply type 6053, peak Tx sync delay 264, free buffers 26 (min 25), ts 19914/19913/0
            Tx timeouts 0,0,0,0,0,0
            === Network ===
            Slowest loop: 6.22ms; fastest: 0.00ms
            Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            HTTP sessions: 1 of 8
            === WiFi ===
            Interface state: active
            Module is connected to access point
            Failed messages: pending 0, notrdy 0, noresp 0
            Firmware version 2.1beta4
            MAC address c4:5b:be:ce:91:93
            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41332
            WiFi IP address 192.168.10.x
            Signal strength -55dBm, channel 6, mode 802.11n, reconnections 0
            Clock register 00002001
              ClockWatchdog @dc42
              @dc42 I wondered, is it possible that the error is not exactly an error? I mean, when this disconnection-reconnection routine starts, is the number of interactions it performs too high and too concentrated? What if we reduced the speed of reconnection attempts and the number of attempts?
              • NeoDueundefined
                NeoDue
                Hm. Reading through all this what your effort yielded, I wonder if whatever @dc42 might find here could also affect the (much smaller) issues I have on my Duet 3 6HC with wifi module
                • dwell of about 5...10s required during boot prior to activating the module, otherwise the the module takes up to 10...15min to connect to the Wifi network
                • random disconnects and
                • very infrequent spontaneous reboots which I did not post here since I could not find anything useful about them yet.
                I blamed the latter two on the web server and the firmware being beta in general - but who knows...?
                  dc42 administrators @Exerqtor
                  @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/9hum0skl7rew21go56q7z/h?rlkey=mh1wx7mi72oz0dmk86c7uf4un&dl=0.
                  @NeoDue if you get any more spontaneous reboots of the Duet, please run M122 and post the output here.
                  Exerqtorundefined 3 Replies Last reply Reply Quote 1
                  • Exerqtorundefined
                    Exerqtor @dc42
                    @dc42 New binaries installed, saw you did some changes to the WiFi interface in this fork.
                    Guess that means you're on to something? wishfull thinking 🙈
                    Just a little feedback after running the fw above for a while i've tried running a couple prints with a couple DWC instances open, and so far it haven't crashed at least. I'll try to have the printer printing for as many hours i can today with a bunch of DWC instances open to see if anything happens.
                    • Exerqtorundefined
                      Exerqtor @dc42
                      @dc42 There she came, new crash:
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-24 09:09:58) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Used output buffers: 10 of 40 (40 max)
                      Static ram: 102844
                      Dynamic ram: 124692 of which 12 recycled
                      Never used RAM 10388, free system stack 138 words
                      Tasks: NETWORK(2,nWait,17.0%,221) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,244) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,341) TMC(4,delaying,0.7%,80) MAIN(1,running,80.8%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                      Last reset 00:08:14 ago, cause: software
                      Last software reset at 2023-11-25 16:29, reason: AssertionFailed, Gcodes spinning, available RAM 5228, slot 0
                      Software reset code 0x4923 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                      Stack: 00000907 000af288 0002dde9 2002bed4 2002be01 000001ae 2002c100 200303e0 2002c118 2001e888 0d362e30 a5a5a5a5 0a0d312e 00000000 00000000 00000000 200303ec 00000800 20035928 2002c100 20018668 2002bf9d 20018668 2001e888 0003007b 00000000 00000000
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 494787, completed 494785, timed out 0, errs 0
                      MCU temperature: min 45.3, current 45.3, max 45.8
                      Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/34, heap memory allocated/used/recyclable 2048/520/64, gc cycles 28
                      Events: 0 queued, 0 completed
                      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 2, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 2, read errors 0, write errors 0, ifcnt 26, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-11-25 16:37:43
                      Cache data hit count 846895387
                      Slowest loop: 10.63ms; fastest: 0.14ms
                      === Storage ===
                      SD card longest read time 3.6ms, write time 4.0ms, max retries 0
                      DMs created 83, segments created 26, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                      === DDARing 0 ===
                      Scheduled moves 43, completed 43, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                      === DDARing 1 ===
                      Heater 1 is on, I-accum = 0.0
                      Q0 segments left 0, axes/extruders owned 0x0000807
                      in 0 notIn 0
                      === CAN ===
                      Messages queued 147, received 333, lost 0, errs 0, boc 0
                      Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 82/82/0
                      === Network ===
                      Slowest loop: 20.10ms; fastest: 0.07ms
                      HTTP sessions: 2 of 8
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968
                      Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
                      EDIT 28.11.2023:
                      Was it any helpfull info in the M122 report @dc42? The printer has been idle since that crash, without any new ones.
                      • Exerqtorundefined
                        Exerqtor @dc42
                        @dc42 New crash:
                        M122
                        Static ram: 102844
                        Dynamic ram: 123356 of which 0 recycled
                        Never used RAM 12360, free system stack 188 words
                        Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,348) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.5%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                        Last reset 00:29:56 ago, cause: software
                        Last software reset at 2023-11-29 18:54, reason: HardFault imprec, Gcodes spinning, available RAM 10104, slot 1
                        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fe8 Task NETW Freestk 506 ok
                        Stack: 2002c118 20030c48 200014e8 00000000 20032e7d 0002fef5 0002ffb4 610ff200 00034731 2002bed0 2002bed0 00000004 0002f635 200014e8 e000e000 00000020 0009fc25 00000000 20034fa8 00000000 20034fa8 00000000 df0bd10a e000e000 2001e888 a5a5a5a5 a5a5a5a5
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 1796796, completed 1796794, timed out 0, errs 0
                        MCU temperature: min 32.9, current 33.3, max 36.5
                        Supply voltage: min 22.0, current 24.1, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/456/20, gc cycles 84
                        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29005, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2023-11-29 19:24:40
                        Cache data hit count 3045378646
                        Slowest loop: 12.84ms; fastest: 0.13ms
                        === Storage ===
                        SD card longest read time 6.7ms, write time 4.5ms, max retries 0
                        === DDARing 0 ===
                        === DDARing 1 ===
                        in 0 notIn 0
                        === CAN ===
                        Messages queued 16181, received 36876, lost 0, errs 1, boc 0
                        Longest wait 2ms for reply type 6053, peak Tx sync delay 357, free buffers 26 (min 25), ts 8984/8983/0
                        === Network ===
                        Slowest loop: 6.04ms; fastest: 0.00ms
                        === WiFi ===
                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42796
                        Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
                        MaxGyverundefined 1 Reply Last reply Reply Quote 0
                        • MaxGyverundefined
                          MaxGyver @Exerqtor
                          @Exerqtor @dc42
                          I can contribute some crash reports as well. My printer just rebooted mid print, this has never happend in one of the previous 3.5 betas.
                          Duet 3 6HC with SBC on RRF 3.5-rc.1
                          2.12.2023, 17:11:57: Verbindung zu duet3.local hergestellt
                          2.12.2023, 17:12:14: M201: Accelerations (mm/sec^2): X: 20000.0, Y: 20000.0, Z: 250.0, E: 20000.0
                          2.12.2023, 17:20:49: : Warning: SPI connection has been reset
                          2.12.2023, 17:20:51: : Error: Expansion board 123 reconnected
                          2.12.2023, 17:20:51: : Error: Expansion board 124 reconnected
                          2.12.2023, 17:20:52: : Error: Expansion board 126 reconnected
                          2.12.2023, 17:20:52: : Error: Expansion board 125 reconnected
                          2.12.2023, 17:20:55: : Warning: M307: Heater 0 predicted maximum temperature at full power is 321°C
                          2.12.2023, 17:20:55: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
                          2.12.2023, 17:20:56: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
                          2.12.2023, 17:21:07: M122: === Diagnostics ===
                          RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
                          Board ID: 08DJM-956L2-G43S8-6J1F2-3SN6N-1U0LG
                          Used output buffers: 1 of 40 (18 max)
                          Static ram: 154852
                          Dynamic ram: 87280 of which 0 recycled
                          Never used RAM 3604, free system stack 204 words
                          Tasks: SBC(2,ready,1.7%,441) HEAT(3,nWait,0.0%,363) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,796) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,7.9%,61) MAIN(2,running,87.3%,137) IDLE(0,ready,3.1%,30), total 100.0%
                          Owned mutexes: HTTP(MAIN)
                          Last reset 00:00:17 ago, cause: software
                          Last software reset at 2023-12-02 16:20, reason: OutOfMemory, Gcodes spinning, available RAM 4, slot 0
                          Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x20421688 Task Move Freestk 319 ok
                          Stack: 2041808c 00419f11 00000000 00000000 2045d0e0 0044a07d 204216f8 00442d47 2045d0e0 00000001 2045d0fc 00445b09 00000000 2045a200 204322a4 204296b6 204251bc 204296b8 00000000 00000002 00000000 20425cbc 00000001 00000001 20432418 00000000 00000001
                          Error status: 0x00
                          MCU temperature: min 34.5, current 34.8, max 35.2
                          Supply voltage: min 3.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 0.9, current 12.1, max 12.2, under voltage events: 0
                          Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/120/0, gc cycles 0
                          Events: 4 queued, 4 completed
                          Driver 0: standstill, SG min 0, mspos 8, reads 27152, writes 16 timeouts 0
                          Driver 1: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                          Driver 2: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                          Driver 3: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                          Driver 4: standstill, SG min 0, mspos 8, reads 27151, writes 18 timeouts 0
                          Driver 5: standstill, SG min 0, mspos 8, reads 27158, writes 11 timeouts 0
                          Date/time: 2023-12-02 16:21:05
                          Slowest loop: 1.71ms; fastest: 0.07ms
                          === Storage ===
                          Free file entries: 20
                          DMs created 250, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                          === DDARing 0 ===
                          === DDARing 1 ===
                          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                          Daemon is idle in state(s) 0
                          Q0 segments left 0, axes/extruders owned 0x80000003
                          === CAN ===
                          Messages queued 166, received 566, lost 0, boc 0
                          Longest wait 56ms for reply type 6041, peak Tx sync delay 38032, free buffers 50 (min 49), ts 90/86/0
                          Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127
                          === SBC interface ===
                          Transfer state: 5, failed transfers: 0, checksum errors: 0
                          RX/TX seq numbers: 24333/3400
                          SPI underruns 0, overruns 0
                          State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98
                          Buffer RX/TX: 0/0-0, open files: 0
                          === Duet Control Server ===
                          Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31)
                          Code buffer space: 4096
                          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2
                          Full transfers per second: 49.12, max time between full transfers: 303.3ms, max pin wait times: 280.8ms/15.6ms
                          Codes per second: 65.98
                          Maximum length of RX/TX data transfers: 4456/1680
                            dc42 administrators @MaxGyver
                            @MaxGyver please can you take regular M122 reports next tike you.run this print. An out of memory error on a 6HC is very unusual and suggests that your print may be doing something that is triggering a memory leak in RRF.
                              dc42 administrators @dc42
                              @Exerqtor are you using the USB port on that Duet 3 Mini?
                              dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/1r49rb2x3jsn1az0jdu1j/h?rlkey=xke2yefix0hyp5dioxa58pgtp&dl=0 and post a M122 after any crash.
                                Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                • Exerqtorundefined
                                  Exerqtor @dc42
                                  Nope the USB port haven't got anything plugged in.
                                  OK, i'll install it right away.
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    Hopefully this shines some more light on it:
                                    M122
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Static ram: 102844
                                    Dynamic ram: 123360 of which 0 recycled
                                    Never used RAM 12356, free system stack 188 words
                                    Tasks: NETWORK(1,ready,18.8%,239) HEAT(3,nWait,0.0%,336) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,79.3%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:26:31 ago, cause: software
                                    Last software reset at 2023-12-05 09:59, reason: HardFault imprec ibus, Gcodes spinning, available RAM 10968, slot 1
                                    Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000500 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f48 Task NETW Freestk 466 ok
                                    Stack: 0d362e30 20032dec 000001bf 00000001 0d362e30 20032dec 000043ae 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd0f 2002bed4 2002be01 000001bf 2002c138 20031db0 2002c150 2001e888 a5a5a5a5 a5a5a5a5 0002ff15 00000000 00000000
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 1591912, completed 1591912, timed out 0, errs 0
                                    MCU temperature: min 33.2, current 34.0, max 36.2
                                    Supply voltage: min 22.0, current 24.1, max 27.0, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1172/736, gc cycles 74
                                    Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 150, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18223, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2023-12-05 10:26:25
                                    Cache data hit count 2710632535
                                    Slowest loop: 9.77ms; fastest: 0.13ms
                                    === Storage ===
                                    SD card longest read time 7.1ms, write time 4.5ms, max retries 0
                                    === DDARing 0 ===
                                    === DDARing 1 ===
                                    in 0 notIn 0
                                    === CAN ===
                                    Messages queued 14337, received 32674, lost 0, errs 1, boc 0
                                    Longest wait 2ms for reply type 6053, peak Tx sync delay 260, free buffers 26 (min 25), ts 7960/7959/0
                                    === Network ===
                                    Slowest loop: 7.91ms; fastest: 0.00ms
                                    HTTP sessions: 3 of 8
                                    === WiFi ===
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
                                      @Exerqtor interesting, that one is a different sort of reset but in the same function. Please send M122 P500 S0, then wait for it to reset again and send the M122 report as usual.
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Here you go ( i did a print or two after sending M122 P500 S0, hope that don't mess anything up):
                                        Used output buffers: 6 of 40 (40 max)
                                        Static ram: 102844
                                        Never used RAM 12356, free system stack 196 words
                                        Tasks: NETWORK(1,ready,19.1%,239) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.0%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                        Last reset 01:09:12 ago, cause: software
                                        Last software reset at 2023-12-06 08:16, reason: AssertionFailed, Gcodes spinning, available RAM 5824, slot 2
                                        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                        Stack: 0000090f 000af3c8 0002de29 2002bed4 2002be01 000001b0 2002c100 20031550 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 2003155c 00000800 20035a68 2002c100 20018678 2002bf9d 20018678 2001e888 000300af 00000000 00000000
                                        Error status: 0x04
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 4152839, completed 4152837, timed out 0, errs 0
                                        MCU temperature: min 33.8, current 34.0, max 36.9
                                        Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1248/812, gc cycles 193
                                        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 89, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 248, read errors 0, write errors 1, ifcnt 88, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 52, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 50, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2023-12-06 09:25:54
                                        Slowest loop: 12.98ms; fastest: 0.13ms
                                        === Storage ===
                                        SD card longest read time 6.9ms, write time 4.8ms, max retries 0
                                        === DDARing 0 ===
                                        === DDARing 1 ===
                                        in 0 notIn 0
                                        === CAN ===
                                        Messages queued 37382, received 85164, lost 0, errs 1, boc 0
                                        Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 20763/20762/0
                                        === Network ===
                                        Slowest loop: 5.88ms; fastest: 0.00ms
                                        === WiFi ===
                                          @Exerqtor thanks, that's back to normal. Please install the firmware from https://www.dropbox.com/scl/fo/pj3pphcoi373dtlcbsrao/h?rlkey=w3hwi2n2l51bywl0773j9uo6a&dl=0 (ignore all the other files there, you only need the .uf2 file) and again send M122 P500 S0 after it starts up. That command will persist until the next reset, so no problem if you do several prints.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            "Normal" lol. Ok i'll install it once the current print finishes, and add M122 P500 S0 at the bottom of config.g.
