G32 doesnt save after True Bed Leveling
2.6k
    fcwilt @johny
    @johny said in G32 doesnt save after True Bed Leveling:
    set the M208 Z-1 but the outcome its the same ๐Ÿ˜ž
    You did use the correct syntax - not just what you posted?
    What is the current setting in G31 for the Z Trigger Height?
      droftarts administrators @johny
      I set the M208 Z-1
      My mistake. I've checked with @dc42, and this isn't necessary. Bed mesh compensation is applied after the limits have been checked, so the nozzle is capable of going below Z0 when bed mesh compensation is enabled.
      Are you sure bed mesh compensation was enabled? Was the first layer exactly as it was before?
      Have you confirmed with a straight edge that your bed is actually the same shape as the mesh is showing? It is still possible this is a measurement error of the Z probe; for example if the weight of the extruder is causing the X axis to deflect, and either bend in the middle or rotate around the X axis. That would also give a bed mesh of this shape, though it would be an extreme example.
      Perhaps you could post a picture of the X axis setup of your printer.
      Another option, though slightly tedious, is to do a manual bed mesh. Set the probe to type 0, and choose a 4x4 bed mesh, then run a new bed mesh (save the old one with a name first, with G29 S3 P"mesh_name.csv"). This will probe the bed, but for each point it will ask you to jog the nozzle down until it touches the bed (or grips a piece of paper). This should help confirm if the bed shape is the same or different from what the Z probe sees. Something like:
      M561            ; clear any bed transform
      G28             ; home as normal
      M558 K1 P0 H5 F300 T8000 ; create a new manual probe
      M557 X25:275 Y90:320 P4  ; define a 4x4 bed mesh
      G29 K1 S0  ; probe the bed with the manual probe and enable compensation
      G28        ; home to adjust bed mesh to Z0
      undefined 1 Reply Last reply 6 Dec 2023, 14:40 Reply Quote 1
        johny @droftarts
        @droftarts Yes, he bed compensation is enabled with the M375 P"heightmap.csv"
        Is the superpinda correctly defined?
        M558 P5 C"^zprobe.in" H5 F300 T8000 A3 S0.03 ; set z probe to SuperPINDA\
        Maybe i need to get a glass and try it out, with glass or mirror the flatness must be perfect.
        undefined undefined 2 Replies Last reply 6 Dec 2023, 15:14 Reply Quote 0
          @johny As far as I can tell the SuperPinda configuration is correct.
          If the bed is not flat, the aluminium plate will pull the glass over it; the glass won't pull the aluminium flat.
          If you do the manual probe procedure I outlined above, it will show if the bed is warped, or if the problem lies somewhere else. It will only take 5-10 minutes.
          undefined 1 Reply Last reply 6 Dec 2023, 21:56 Reply Quote 0
            fcwilt @johny
            @johny
            If you ever want to verify that mesh compensation is actually doing something you can load this heightmap for testing:
            mesh_comp_test_heightmap.csv
            It's strictly for testing. It is a 9 point 200x200 map, with 0,0 at bed center, with the left most 3 points and the right most 3 points set to 0 with the middle 3 points set to 10. The greatly exaggerated values make Z axis motion very obvious as you move X from -100 to 100.
              johny @droftarts
              @droftarts ![alt
              The picture of the axis
              Since i don't use mesh.g maybe its a good idea to try it?
              I tried to manually do the mesh but with G29 k1 but didn't find in the documentation how can i validate each position
              undefined undefined 2 Replies Last reply 6 Dec 2023, 23:50 Reply Quote 0
                fcwilt @johny
                @johny
                As I think I mentioned G32 runs bed.g which is where you put the code to level the bed, either manually or automatically.
                And G29 runs mesh.g which is where you put the code to create the height map needed to use mesh bed compensation.
                It seems the config utility doesn't adhere to the intended use of these two files and may put the code that should be in mesh.g into bed.g as well.
                In any case you have been using G32 to do automatic bed leveling using the two Z steppers.
                But in the pictures I think I see thumb-screws. Are they for leveling the bed by hand?
                If that is the case you can use G32 to help with that.
                Let me know I can explain how.
                undefined 1 Reply Last reply 8 Dec 2023, 13:03 Reply Quote 0
                  Just use a piece of paper under the nozzle at each point. Move the Z down until it just grabs the paper. Click OK to move on to the next point.
                  Is the green arrow where the SuperPINDA is installed on your X carriage? Which side of the linear rail is it on? It really looks like the whole carriage is very front heavy, and any deflection caused by this makes the probe measure a very different distance from the bed than the nozzle. I think that is more likely to be your problem. I also don't think your G31 X and Y probe offsets from the nozzle are correct; the probe is offset a long way in Y. It is much better to place your probe next to your nozzle in the X axis, so it has no Y offset, then it will move around the same as the nozzle.
                    johny
                    @fcwilt said in G32 doesnt save after True Bed Leveling:
                    I don't have mesh.g can you share it please?
                    undefined 1 Reply Last reply 8 Dec 2023, 14:45 Reply Quote 0
                      droftarts administrators @fcwilt
                      The config utility can't create an axis with multiple motors, so it can't produce a bed.g for independent levelling. So it creates a bed.g with the commands to do bed mesh levelling. I generally use bed.g for mesh levelling, and have macros for 2-point gantry levelling and 3-point manual bed levelling (using levelling screws, see https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_manual_levelling). mesh.g was introduced with RRF 3.2. I've updated the Gcode page to make mesh.g a bit clearer: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#meshg
                      @johny example mesh.g
                      G28                ; home all
                      G29 S0             ; probe the bed and enable compensation
                      G1 X160 Y160 F6000 ; move to bed centre
                      G28 Z              ; home Z to set Z datum
                      undefined 1 Reply Last reply 11 Dec 2023, 22:40 Reply Quote 0
                        fcwilt @johny
                        I can provide an example mesh.g file for creating the height map used for Mesh Compensation, using G29.
                        The only thing "special" about bed.g and mesh.g is that there is the command G32 which runs bed.g and G29 which runs mesh.g (if it exists).
                        I recommend using them as intended which keeps the DWC interface "in sync" with your code.
                        You could put the code for bed leveling or height map creation in any file at all - they simply won't be run using G32 or G29.
                        Would you like the example mesh.g file?
                          johny @droftarts
                          @droftarts This mesh.g is a non-ending loop ๐Ÿ˜ง
                          I am in a death end ๐Ÿ˜ž
                          I don't know what to do next, get a new bed? the firmware should compensate the difference on a 130mm cube its not even on the entire bed, its on a small 130mm cube ๐Ÿ’€
                          I still believe there is something wrong with software, its not hardware
                          undefined 1 Reply Last reply 11 Dec 2023, 22:44 Reply Quote 0
                            @johny Ooops! Sorry, the line should be
                            Not just G29, because
                            In RRF 3.2 and later, if G29 is commanded with no S parameter, then file sys/mesh.g is run if it exists.
                            If you emergency stop, you should be able to get control back, then change the macro
                              @johny Did you ever do a mesh by hand? You might believe it's software, but many, many users use bed mesh without problems. I think the problem is the distance the probe is from the nozzle, and they are measuring different things. Probably your bed is flatter than the probe is reporting. You didn't answer my question earlier about the position of the probe, or if you had checked the bed with a straight edge, like a ruler.
                              undefined 1 Reply Last reply 12 Dec 2023, 17:12 Reply Quote 1
                                johny @droftarts
                                @droftarts
                                As i understood to make the mesh manually the nozzle will travel to the first position then it waits for me to jog the Z and then I should click somewhere or send some command right? i tried to look for this and didn't found.
                                I have 3D printers since 2011 and i followed the innovations closely. I have a Cartesian (duet) with BLtouch that works fine, i don't touch the bed for years.
                                Maybe I need to flash the duet again?
                                undefined undefined 2 Replies Last reply 12 Dec 2023, 19:15 Reply Quote 0
                                  fcwilt @johny
                                  @johny
                                  You have a Z probe and it seems to be working. No point in creating a height map by hand when you have a Z probe.
                                  Refresh my memory - did you ever verify that the Z trigger height setting in the G31 was correct?
                                  You won't get a good height map if that setting is wrong.
                                    @johny can you take a couple more pictures of your X carriage, ie from the side?
                                    Have you put a straight edge across your bed?
                                    Either the bed is warped, or thereโ€™s a difference between what the probe is measuring and how fat the nozzle is from the bed, dependant on the position on the axis.
                                    As I said earlier, for the manual bed probe, use a piece of paper under the nozzle at each point. Move the Z down until it just grabs the paper. Click OK to move on to the next point.
                                    @fcwilt you have missed the point. The probed bed mesh doesnโ€™t match what the nozzle is doing. Getting a manual bed mesh, the comparing it to a probe bed mesh, should show what the difference is. I think the bed is very likely has less deviation than 0.65mm, and the problem is caused by the gantry twisting under the weight of the hotend. Because I think the probe is offset in the Y direction (though the config does not reflect this) it is mismeasuring the mesh.
                                    undefined undefined 2 Replies Last reply 12 Dec 2023, 20:00 Reply Quote 0
                                      fcwilt @droftarts
                                      @droftarts
                                      I understand your point. I simply don't agree with your theory as to what is wrong.
                                      Getting past "operator error" can be tricky. ๐Ÿ˜‡
                                        johny @droftarts
                                        @droftarts Sorry for the late reply, with the end of the year/vacations, etc I didn't have the proper time to reply and work on this printer problem. Bellow the pictures asked.
                                        The bed is warped (I used a light source below the ruler to see it better but the bed compensation should compensate for that no?)
                                        oliofundefined 1 Reply Last reply 29 Dec 2023, 08:06 Reply Quote 0
                                        • oliofundefined
                                          oliof @johny
                                          @johny with the wrong Y offset of the probe, the compensation applied is wrong.
                                          An exaggerated example: If your Y offset is 40mm physically but you defined your Y offset as 0 in your config, the printer will compensate for what it measured 40mm away
                                          In addition, the further away the probe is from the nozzle, the higher the risk for imperfections in the carriage and probe mount skewing results further.
                                          The recommendations are
                                          a) verify and adjust your Y offset
                                          b) try to reduce the distance between nozzle and probe (verifying and adjusting probe offsets after)
                                          In addition, I recommend to have the Z probe location match a point of your axis alignment and a point of your bed mesh, so you have a physical fix point between the three measurements that should not be further out than your probe repeatability.
                                          undefined 1 Reply Last reply 29 Dec 2023, 12:44 Reply Quote 0
