1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
Beta Firmware
9
147
8.7k
    Exerqtor
    Starting up a new post about this since this issue (1 & 2) apparently isn't fully patched out (or have been re-introduced in rc1).
    I started mentioning this in the "random reboot/crash thread", but for the sake of trying to keep that thread on track that I've moved this issue over to this thread.
    HW/SW setup: Duet Mini 5+ v1.02, Duet 1LC v1.2 running RRF 3.5.0-rc1+ in standalone mode, FW retraction, Pressure advance & Input shaping enabled
    @Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
    Had something interesting just happen, while running a print on that new build you gave me earlier today (with the WiFi module disabled), I suddenly got what seems to be the same toolboard bug that was intruduced and patched out a whille back where it stops extruding and ends up retracting instead!
    I ran a M122 & M122 B121 while this was happening before i canceled the print:
    M122
    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode)
    Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
    Used output buffers: 1 of 40 (40 max)
    Static ram: 102844
    Dynamic ram: 128036 of which 0 recycled
    Never used RAM 5752, free system stack 118 words
    Tasks: NETWORK(1,ready,77.5%,195) HEAT(3,nWait,0.2%,328) Move(4,nWait,11.5%,241) CanReceiv(6,nWait,0.4%,774) CanSender(5,nWait,0.3%,327) CanClock(7,delaying,0.1%,350) TMC(4,nWait,5.7%,74) MAIN(1,running,150.3%,580) IDLE(0,ready,0.7%,29) AIN(4,delaying,6.6%,264), total 253.2%
    Owned mutexes: WiFi(NETWORK)
    Last reset 07:24:04 ago, cause: software
    Last software reset at 2023-12-07 06:59, reason: AssertionFailed, Gcodes spinning, available RAM 13540, slot 0
    Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
    Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001a8 2002c100 20031d28 2002c118 2001e888 a5a5a5a5 a5a5a5a5 362e303d 00000000 00000000 00000000 20031d34 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
    Error status: 0x04
    Aux0 errors 0,1,0
    MCU revision 3, ADC conversions started 26644948, completed 26644948, timed out 0, errs 0
    MCU temperature: min 39.5, current 46.2, max 47.0
    Supply voltage: min 5.1, current 24.0, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
    Heap OK, handles allocated/used 198/34, heap memory allocated/used/recyclable 2048/1260/776, gc cycles 1354
    Events: 1 queued, 1 completed
    Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 76, reads 25633, writes 82, timeouts 0, DMA errors 0, CC errors 0
    Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 76, reads 25632, writes 83, timeouts 0, DMA errors 0, CC errors 0
    Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 192, reads 25677, writes 38, timeouts 0, DMA errors 0, CC errors 0
    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 192, reads 25677, writes 37, timeouts 0, DMA errors 0, CC errors 0
    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 189, reads 25678, writes 37, timeouts 0, DMA errors 0, CC errors 0
    Driver 5: not present
    Driver 6: not present
    Date/time: 2023-12-07 18:33:40
    Slowest loop: 235.32ms; fastest: 0.09ms
    === Storage ===
    Free file entries: 16
    SD card longest read time 10.0ms, write time 30.2ms, max retries 0
    DMs created 83, segments created 47, maxWait 2831509ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
    next step interrupt due in 17 ticks, enabled
    Moves shaped first try 37104, on retry 9435, too short 18092, wrong shape 217112, maybepossible 5892
    === DDARing 0 ===
    Scheduled moves 72372, completed 72332, hiccups 0, stepErrors 0, LaErrors 1446, Underruns [0, 0, 2], CDDA state 3
    === DDARing 1 ===
    Heater 0 is on, I-accum = 0.4
    Heater 1 is on, I-accum = 0.0
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is doing "G1 X175.056 Y124.432 E.01578" in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is doing "G4 S1" in state(s) 0 0, running macro
    Aux2 is idle in state(s) 0
    File2 is idle in state(s) 0, sync state 1
    Queue2 is idle in state(s) 0
    Q0 segments left 1, axes/extruders owned 0x0000807
    Queue 0 has 'M106 S255' for move 72370
    Code queue 1 is empty
    === Filament sensors ===
    in 0 notIn 0
    Extruder 0 sensor: no filament
    === CAN ===
    Messages queued 581746, received 549305, lost 0, errs 1, boc 0
    Longest wait 3ms for reply type 6029, peak Tx sync delay 533, free buffers 26 (min 24), ts 133223/133222/0
    Tx timeouts 0,0,0,0,0,0
    === Network ===
    Slowest loop: 205.33ms; fastest: 0.00ms
    Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 2 of 8
    === WiFi ===
    Interface state: active
    Module is connected to access point
    Failed messages: pending 0, notrdy 0, noresp 0
    Firmware version 2.1beta4
    MAC address c4:5b:be:ce:91:93
    Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 42960
    WiFi IP address 192.168.10.x
    Signal strength -58dBm, channel 6, mode 802.11n, reconnections 0
    Clock register 00002001
    M122 B121
    Diagnostics for board 121:
    Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1+ (2023-11-21 09:48:16)
    Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
    All averaging filters OK
    Never used RAM 2364, free system stack 89 words
    Tasks: Move(3,nWait,2.3%,71) HEAT(2,nWait,2.6%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.6%,77) CanClock(5,nWait,0.1%,67) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,22.2%,57) MAIN(1,running,37.1%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,35.0%,114), total 100.0%
    Last reset 07:24:21 ago, cause: software
    Last software reset data not available
    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 4, write errors 1, ifcnt 94, reads 57047, writes 26, timeouts 10, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 39783642
    Moves scheduled 283066, completed 283066, in progress 0, hiccups 839, segs 51, step errors 0, maxPrep 1124, maxOverdue 5537, maxInc 1554, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
    Peak sync jitter -3/15, peak Rx sync delay 267, resyncs 0/0, no timer interrupt scheduled
    VIN voltage: min 6.3, current 24.0, max 34.7
    MCU temperature: min 53.8C, current 76.8C, max 78.8C
    Last sensors broadcast 0x00000012 found 2 57 ticks ago, 0 ordering errs, loop time 0
    CAN messages queued 549472, send timeouts 7, received 582102, lost 0, errs 40685, boc 0, free buffers 18, min 17, error reg 110000
    Last cancelled message type 4519 dest 0
    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 396, adv 31230/74659
    Accelerometer: LIS3DH, status: 00
    Inductive sensor: not found
    I2C bus errors 0, naks 6, contentions 0, other errors 0
    Interrupt 5726621 to 0us, poll 4 to 2846us
    Driver 0: ok
    I tried pausing, manually extruding while paused via PanelDue which did work, resumed and it still wouldn't extrude while printing (did this 2-3 times before canceling).
    @Exerqtor said in Reboots crashes - RRF 3.5.0-rc1:
    I just tried the same print again, and the extruder going backwards issue is 100% back with the newest build you gave me. This time it "stopped" extruding at a totally different time (earlier) than before.
    EDIT 1: I've reverted to this build now. Trying the same print another time to see if it completes on that.
    EDIT 2: Turns out it shits the bed on that build to.
    Here is some M122 reports while the print is going with the issue ongoing:
    M122
    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-06 12:09:26) running on Duet 3 Mini5plus WiFi (standalone mode)
    Used output buffers: 14 of 40 (40 max)
    Static ram: 102844
    Dynamic ram: 128692 of which 0 recycled
    Never used RAM 5312, free system stack 122 words
    Tasks: NETWORK(2,nWait,23.3%,173) HEAT(3,nWait,0.0%,328) Move(4,nWait,2.6%,243) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.1%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.8%,74) MAIN(1,running,68.0%,601) IDLE(0,ready,4.2%,29) AIN(4,delaying,1.0%,264), total 100.0%
    Last reset 00:16:32 ago, cause: software
    Last software reset at 2023-12-08 10:42, reason: User, Gcodes spinning, available RAM 13108, slot 0
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
    Error status: 0x04
    Aux0 errors 0,0,0
    MCU revision 3, ADC conversions started 992190, completed 992188, timed out 0, errs 0
    MCU temperature: min 46.0, current 46.2, max 46.7
    Supply voltage: min 23.7, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/1144/744, gc cycles 1563
    Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 245, reads 6087, writes 0, timeouts 0, DMA errors 0, CC errors 0
    Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 245, reads 6087, writes 0, timeouts 0, DMA errors 0, CC errors 0
    Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 42, reads 6087, writes 0, timeouts 0, DMA errors 0, CC errors 0
    Driver 3: ok, SG min 0, read errors 0, write e ok, SG min 0, read errors 0, write errors 0, ifcnt 42, reads 6086, writes 0, timeouts 0rrors 0, ifcnt 45, reads 6087, writes 0, timeouts 0, DMA errors 0, CC errors 0
    Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 42, reads 6086, writes 0, timeouts 0, DMA errors 0, CC errors 0
    Date/time: 2023-12-08 13:45:36
    Cache data hit count 1628047615
    Slowest loop: 40.69ms; fastest: 0.11ms
    === Storage ===
    SD card longest read time 11.2ms, write time 1.2ms, max retries 0
    DMs created 83, segments created 38, maxWait 247ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
    next step interrupt due in 15 ticks, enabled
    Moves shaped first try 409, on retry 93, too short 65, wrong shape 1839, maybepossible 55
    === DDARing 0 ===
    Scheduled moves 9177, completed 9137, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
    === DDARing 1 ===
    File is doing "G2 X168.376 Y211.552 I-.644 J-.16 E.01687" in state(s) 0
    Daemon is doing "G4 P10" in state(s) 0 0, running macro
    Q0 segments left 0, axes/extruders owned 0x0000807
    Code queue 0 is empty
    in 0 notIn 0
    === CAN ===
    Messages queued 3948, received 2408, lost 0, errs 0, boc 0
    Longest wait 7ms for reply type 6024, peak Tx sync delay 141, free buffers 26 (min 24), ts 578/578/0
    === Network ===
    Slowest loop: 19.83ms; fastest: 0.07ms
    Responder states: MQTT(0) HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 3 of 8
    === WiFi ===
    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39540
    Signal strength -51dBm, channel
    M122 B121
    Never used RAM 2748, free system stack 89 words
    Tasks: Move(3,nWait,0.7%,71) HEAT(2,nWait,0.4%,95) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.2%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,90.9%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.8%,114), total 100.0%
    Last reset 00:16:49 ago, cause: software
    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 148, reads 59435, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 41820
    Moves scheduled 3953, completed 3953, in progress 0, hiccups 1, segs 35, step errors 0, maxPrep 888, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
    Peak sync jitter 0/10, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
    VIN voltage: min 23.9, current 24.1, max 24.4
    MCU temperature: min 55.1C, current 66.5C, max 66.5C
    Last sensors broadcast 0x00000012 found 2 123 ticks ago, 0 ordering errs, loop time 0
    CAN messages queued 2484, send timeouts 0, received 4020, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 327, adv 36161/74646
    I2C bus errors 0, naks 0, contentions 0, other errors 0
    Interrupt 5726621 to 0us, poll 9 to 1276us
    Driver 0: ok
    And here is the print file for good meassure.
    Since the issue wasn't related to the last build I have installed the one you suplied yesterday again btw.
    Here is a link to the print job that's reproduced the issue the 3 times I've tried running it (happens on different layers each time).
    undefined 1 Reply Last reply 9 Dec 2023, 16:36 Reply Quote 0
    • undefined Exerqtor marked this topic as a question 8 Dec 2023, 19:00
    • undefined Exerqtor referenced this topic 8 Dec 2023, 19:03
    • undefined Exerqtor referenced this topic 8 Dec 2023, 19:04
    • undefined Exerqtor referenced this topic 8 Dec 2023, 19:23
      Exerqtor @Exerqtor
      I've been trying several other prints now as well, and the bug is for sure back! The last print it happened in, I let the print "complete" and it ended up fully unloading the hotend/extruder.
      Just like "last time" (3.5.0 pre beta 4) it happens seemingly at random.
      undefined 1 Reply Last reply 10 Dec 2023, 12:20 Reply Quote 0
        Exerqtor @Exerqtor
        I've now regressed back to this "release" who is the first 3.5.0-rc1+ as far as i know of, and the issue is still present.
        Reports from a ongoing print with the issue going on:
        M122
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-03 17:18:21) running on Duet 3 Mini5plus WiFi (standalone mode)
        Used output buffers: 15 of 40 (31 max)
        Static ram: 102812
        Dynamic ram: 126708 of which 12 recycled
        Never used RAM 7244, free system stack 128 words
        Tasks: NETWORK(2,nWait,12.2%,197) HEAT(3,nWait,0.0%,343) Move(4,nWait,0.7%,243) CanReceiv(6,nWait,0.1%,566) CanSender(5,nWait,0.0%,327) CanClock(7,delaying,0.0%,341) TMC(4,nWait,0.7%,74) MAIN(1,running,85.3%,601) IDLE(0,ready,0.1%,29) AIN(4,delaying,0.8%,264), total 100.0%
        Owned mutexes:
        Last reset 00:25:25 ago, cause: software
        Last software reset at 2023-12-09 15:05, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 6040, slot 2
        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x362e303d SP 0x20011f60 Task NETW Freestk 472 ok
        Stack: 362e303d 20032cfd 00000047 362e303c 20032ebc 0002dd33 00004434 210f0000 0002dce5 2002bed4 2002be01 000001c0 2002c100 200314b0 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0002ff41 00000000 00000000 00000000 362e303d 00000800 200359c8 2002c100 20018678
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 1525075, completed 1525075, timed out 0, errs 0
        MCU temperature: min 35.7, current 46.2, max 46.6
        Supply voltage: min 4.5, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 198/23, heap memory allocated/used/recyclable 2048/1952/1612, gc cycles 8
        Events: 2 queued, 2 completed
        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 51, reads 14667, writes 34, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 49, reads 14667, writes 34, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 244, reads 14677, writes 24, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 246, reads 14678, writes 23, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 242, reads 14678, writes 23, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2023-12-10 13:16:52
        Cache data hit count 2401483401
        Slowest loop: 224.04ms; fastest: 0.09ms
        === Storage ===
        SD card longest read time 8.0ms, write time 27.9ms, max retries 0
        DMs created 83, segments created 41, maxWait 909187ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        next step interrupt due in 44 ticks, enabled
        Moves shaped first try 516, on retry 378, too short 179, wrong shape 4761, maybepossible 134
        === DDARing 0 ===
        Scheduled moves 7935, completed 7895, hiccups 0, stepErrors 0, LaErrors 8, Underruns [0, 0, 0], CDDA state 3
        === DDARing 1 ===
        Movement locks held by File, null
        File is doing "G11" in state(s) 0
        Daemon is doing "G4 S10000" in state(s) 0 0, running macro
        in 0 notIn 0
        === CAN ===
        Messages queued 23320, received 31266, lost 0, errs 12789, boc 0
        Longest wait 2ms for reply type 6031, peak Tx sync delay 35722, free buffers 26 (min 25), ts 7626/7613/0
        Tx timeouts 0,0,12,0,0,7 last cancelled message type 30 dest 127
        === Network ===
        Slowest loop: 50.37ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        === WiFi ===
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42964
        Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
        M122 B121
        Never used RAM 2628, free system stack 89 words
        Tasks: Move(3,nWait,0.2%,71) HEAT(2,nWait,0.3%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.1%,57) MAIN(1,running,91.6%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.8%,114), total 100.0%
        Last reset 00:19:55 ago, cause: software
        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 25, reads 7287, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 438346
        Moves scheduled 2995, completed 2995, in progress 0, hiccups 4, segs 40, step errors 0, maxPrep 900, maxOverdue 59, maxInc 59, mcErrs 0, gcmErrs 0, ebfmin -0.97 max inf
        Peak sync jitter -2/11, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 23.3, current 24.1, max 24.4
        MCU temperature: min 44.1C, current 62.3C, max 62.3C
        Last sensors broadcast 0x00000012 found 2 130 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 24647, send timeouts 0, received 18188, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 354, adv 35968/74648
        Interrupt 5726621 to 0us, poll 4 to 1416us
        Driver 0: ok
        Moving back to 3.5.0-rc1 now to see if that issue follows there as well.
        undefined 1 Reply Last reply 10 Dec 2023, 12:30 Reply Quote 0
          Exerqtor @Exerqtor
          And so it does, same problem on 3.5.0-rc1:
          Ongoing print displaying the issue:
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1 (2023-08-31 16:16:56) running on Duet 3 Mini5plus WiFi (standalone mode)
          Used output buffers: 26 of 40 (29 max)
          Static ram: 102836
          Dynamic ram: 127244 of which 0 recycled
          Never used RAM 6720, free system stack 134 words
          Tasks: NETWORK(2,nWait,11.3%,197) HEAT(3,nWait,0.0%,352) Move(4,nWait,1.4%,244) CanReceiv(6,nWait,0.1%,796) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,0.7%,74) MAIN(1,running,85.5%,603) IDLE(0,ready,0.1%,29) AIN(4,delaying,0.9%,264), total 100.0%
          Last reset 00:08:25 ago, cause: software
          Last software reset at 2023-12-10 13:20, reason: User, Gcodes spinning, available RAM 13016, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 505809, completed 505809, timed out 0, errs 0
          MCU temperature: min 42.2, current 46.4, max 46.6
          Supply voltage: min 8.8, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 198/23, heap memory allocated/used/recyclable 2048/1696/1352, gc cycles 8
          Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 99, reads 26545, writes 31, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 26545, writes 31, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 25, reads 26555, writes 20, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 26555, writes 20, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 26555, writes 21, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2023-12-10 13:28:49
          Cache data hit count 741229810
          Slowest loop: 224.32ms; fastest: 0.09ms
          === Storage ===
          SD card longest read time 6.0ms, write time 4.5ms, max retries 0
          DMs created 83, segments created 40, maxWait 70761ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 48 ticks, enabled
          Moves shaped first try 284, on retry 120, too short 594, wrong shape 2189, maybepossible 201
          === DDARing 0 ===
          Scheduled moves 4585, completed 4545, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 0], CDDA state 3
          === DDARing 1 ===
          File is doing "G1 X187.663 Y162.47 E.19318" in state(s) 0
          === CAN ===
          Messages queued 8689, received 10558, lost 0, boc 0
          Longest wait 2ms for reply type 6034, peak Tx sync delay 252, free buffers 26 (min 25), ts 2528/2527/0
          === Network ===
          Slowest loop: 108.08ms; fastest: 0.00ms
          === WiFi ===
          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43128
          Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0
          M122 B121
          Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1 (2023-08-31 16:30:01)
          Never used RAM 2760, free system stack 89 words
          Tasks: Move(3,nWait,0.2%,71) HEAT(2,nWait,0.4%,91) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,0.1%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.1%,57) MAIN(1,running,91.2%,324) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
          Last reset 00:08:29 ago, cause: software
          Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 57570, writes 22, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 386243
          Moves scheduled 2792, completed 2792, in progress 0, hiccups 4, segs 38, step errors 0, maxPrep 862, maxOverdue 174, maxInc 140, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
          Peak sync jitter -1/10, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 9.0, current 24.1, max 24.6
          MCU temperature: min 58.6C, current 68.8C, max 68.8C
          Last sensors broadcast 0x00000012 found 2 7 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 10650, send timeouts 0, received 8816, lost 0, free buffers 18, min 18, error reg 110000
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 357, adv 35693/74648
          Interrupt 5726621 to 0us, poll 4 to 1440us
          Driver 0: ok
          undefined 1 Reply Last reply 10 Dec 2023, 12:53 Reply Quote 0
            gloomyandy @Exerqtor
            @Exerqtor Is there anything different about the prints or the setup you are now using? I seem to remember you have printed a lot of things using the various rc versions without hitting this problem.
            undefined 1 Reply Last reply 10 Dec 2023, 13:17 Reply Quote 0
              Exerqtor @gloomyandy
              @gloomyandy Nope, no difference anywhere other than the different FW versions (and changes to daemon.g I've been doing on request from @dc42, which shouldn't impact much).
              Haven't done any config changes in either the firmware or slicer. So what made this bug suddenly pop up is beyond me.
              I litlerlaly finished one printed job, sliced a new part (with the exact same settings), uploaded, started printing and 10minutes into the print i saw it wasn't extruding. So i thought it was either a clog or had ran out of filament.
              Paused the print, saw there was plenty with filament left, so i tried extruding manually through PanelDue which worked after it had finally loaded/primed the hotend again.
              So i canceled the print, and restarted it. This time it started acting up on layer 7-8 or something (way earlier than it had shit the bed last time I tried). Canceled and try again, now it didn't get to layer 3 even.
              undefined 1 Reply Last reply 10 Dec 2023, 13:36 Reply Quote 0
                @Exerqtor So just to be clear, is this a print that you have not printed before,or have you printed it successfully in the past?
                undefined 1 Reply Last reply 10 Dec 2023, 14:14 Reply Quote 0
                  @gloomyandy The prints I've tried now are prints that i haven't tried before.
                  I did first think that the issue with the file i linked here was that it has quite alot of retractions in quick sucession. So i sliced another job (same slicer settings and no fw changes), and that job did complete without issues. Then i sliced up the exact same stl that i had just sucessfully printed, only change was that i mirrored it over x-axis in the slicer since it's a right/left side model. Sliced that, uploaded and started printing it, but that failed on me.
                  So it's leads me to think the issue ain't the job/sliced files.
                  And just for referance the WiFi module has been switched off before any of these print jobs have been started due to the crash issue i've been having. So it's nothing "external" doing nothing funny 😅
                  undefined 1 Reply Last reply 10 Dec 2023, 17:55 Reply Quote 0
                    NeoDue @Exerqtor
                    @Exerqtor I don't know which slicer you use, but did you check if there might be a bug in that slicer? I just recently upgraded my Prusaslicer, hence the question. Did you confirm that the gcode files are okay in the relevant area?
                    undefined 1 Reply Last reply 10 Dec 2023, 18:21 Reply Quote 0
                      Exerqtor @NeoDue
                      @NeoDue said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
                      I'm using Orca Slicer 1.8.1, and i was before this problem suddenly started manifesting as well.
                      And since it happens on different heights (on the same job file) every time i try iy out i can't fathom how it could be a slicer generated issue.
                      I've read through the parts of gcode where the problem seem to have happened, and it's nothing out of the ordinary.
                      If you look at the file i supplied a little bit farther up, it stopped extruding somewhere between layer 1 finishing up, and layer 2 being done one of the times (I at least haven't been able to find anything that stands out as wrong within that segment of code). And the first time that print failed the print came to about 12,6mm height before it stopped 🤷‍♂️
                      undefined 1 Reply Last reply 10 Dec 2023, 21:04 Reply Quote 0
                        NeoDue @Exerqtor
                        @Exerqtor that link you posted up there was too large, I could not see it 😆
                        The file seems okay though.
                        Just to have tried it and maybe narrow down the issue - did you try to switch to absolute extrusion instead of using relative extrusion (RRF default is absolute - thus, if this works, your printer might "forget" its relative mode which you can doublecheck then)?
                        Apart from that, two probably unrelated issues in your code: you set global.layer_number twice for each layer, and you do a G92 E0 for each layer change - that one does not make sense if you use relative extruder coordinates. I remember commenting all these out when I switched to using relative extruder coordinates because something went strange then... but it has been a while, so I do not remember what that was.
                        undefined 1 Reply Last reply 11 Dec 2023, 05:28 Reply Quote 1
                          Exerqtor @NeoDue
                          Haha, hidden in plain sight 🤣
                          Glad i'm not the only one not able to spot any clear mistakes 😅
                          Hmm, no I haven't tried that, I'll give it a try after work!
                          Hmm, i'll do that later too!
                          Weird of it to suddenly happen though, since i haven't done any changes in that for litlerlaly years 🤔
                          undefined 1 Reply Last reply 11 Dec 2023, 08:04 Reply Quote 0
                            @Exerqtor The Duet folks recommend the use of relative extrusion: https://docs.duet3d.com/User_manual/Reference/Slicing_recommendations#:~:text=All popular slicers support relative,you are using relative extrusion.
                            I suspect that is the mode that most folks are using.
                            It seems strange that there are no other reports of this issue from other folks. One thing that is perhaps a little unusual about your setup is that it looks like you have a filament sensor attached to the toolboard. Perhaps you could try disconnecting that (so that it no longer generates interrupts) and see if that makes any difference? Is there anything else about your toolboard setup that is unusual (so for instance do you have any neopixels running from it)? Are you using slicer or firmware retraction?
                            undefined 1 Reply Last reply 11 Dec 2023, 09:00 Reply Quote 0
                              @gloomyandy said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
                              Yeah that's exactly why i'm using it too 🤣
                              Thought most people ran at least one sensor these days lol, I can disable it in firmware and unplug it as well just to try.
                              The neopixels have wires ran all the way from the mainboard, since toolboard driven neopixels wasn't supported when i hooked it up 😅
                              I'm running firmware retraction, input shaping and pressure advance.
                              undefined 1 Reply Last reply 11 Dec 2023, 09:35 Reply Quote 0
                                dc42 administrators @Exerqtor
                                @Exerqtor please try the firmware binary at https://www.dropbox.com/scl/fo/uf8gsgetc2mfbh34hm3up/h?rlkey=bx1aavry6xplebwxhv5rx7xee&dl=0 and test it both for the WiFi resetting issue and the extruder reversal issue.
                                undefined 2 Replies Last reply 11 Dec 2023, 14:17 Reply Quote 1
                                  Exerqtor @dc42
                                  @dc42 said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
                                  Sweet, but continue to run the "regular" 1LC 3.5.0-rc1+ firmware?
                                    Exerqtor @dc42
                                    @dc42 Ok let's see, I've installed those last binaries and the "normal" 3.5.0rc1+ release on the 1LC.
                                    After that I tried one of the jobs that failed earlier, and it completed without reversing the extruder (or crashing).
                                    I'll try some of the other jobs that has failed too now and see of they also complete.
                                    Should i still leave the "stuff" we put in daemon.g be there for a while btw?
                                    (Copying this response to the other thread too, since it's refering to the same binaries)
                                    undefined 1 Reply Last reply 11 Dec 2023, 16:54 Reply Quote 0
                                      Exerqtor @Exerqtor
                                      @Exerqtor said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
                                      Well that didn't last long, the next print started reversing after the second layer completed, it's still going as i type this reply.
                                      So here is a few reports from when it's currently reversing:
                                      M122
                                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1++wdb (2023-12-11 09:30:48) running on Duet 3 Mini5plus WiFi (standalone mode)
                                      Used output buffers: 12 of 40 (40 max)
                                      Static ram: 102844
                                      Dynamic ram: 126732 of which 0 recycled
                                      Never used RAM 7128, free system stack 128 words
                                      Tasks: NETWORK(1,ready,143.3%,173) HEAT(3,nWait,0.2%,327) Move(4,nWait,6.2%,242) CanReceiv(6,nWait,0.4%,774) CanSender(5,nWait,0.2%,327) CanClock(7,delaying,0.1%,350) TMC(4,nWait,5.7%,74) MAIN(1,running,583.5%,584) IDLE(0,ready,0.9%,29) AIN(4,delaying,6.4%,264), total 746.8%
                                      Last reset 01:50:12 ago, cause: software
                                      Last software reset at 2023-12-11 16:03, reason: User, Gcodes spinning, available RAM 13548, slot 1
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                      Error status: 0x04
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 6612142, completed 6612142, timed out 0, errs 0
                                      MCU temperature: min 34.7, current 46.4, max 46.8
                                      Supply voltage: min 7.5, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 198/23, heap memory allocated/used/recyclable 2048/788/444, gc cycles 18
                                      Events: 0 queued, 0 completed
                                      Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 166, reads 20196, writes 50, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 164, reads 20196, writes 50, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 70, reads 20217, writes 28, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 72, reads 20217, writes 28, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 68, reads 20219, writes 27, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2023-12-11 17:54:00
                                      Slowest loop: 306.84ms; fastest: 0.09ms
                                      === Storage ===
                                      SD card longest read time 9.2ms, write time 6.2ms, max retries 0
                                      DMs created 83, segments created 44, maxWait 2843003ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                                      next step interrupt due in 63 ticks, enabled
                                      Moves shaped first try 2684, on retry 3142, too short 7967, wrong shape 32970, maybepossible 1754
                                      === DDARing 0 ===
                                      Scheduled moves 7910, completed 7871, hiccups 0, stepErrors 0, LaErrors 31, Underruns [0, 0, 0], CDDA state 3
                                      === DDARing 1 ===
                                      File is doing "G1 X170.601 Y152.656 E.00239" in state(s) 0
                                      in 0 notIn 0
                                      === CAN ===
                                      Messages queued 111977, received 136294, lost 0, errs 1, boc 0
                                      Longest wait 6ms for reply type 6029, peak Tx sync delay 340, free buffers 26 (min 24), ts 33061/33060/0
                                      === Network ===
                                      Slowest loop: 210.23ms; fastest: 0.00ms
                                      === WiFi ===
                                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948
                                      M122 B121
                                      Never used RAM 2556, free system stack 89 words
                                      Tasks: Move(3,nWait,1.4%,71) HEAT(2,nWait,2.5%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.4%,77) CanClock(5,nWait,0.1%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,22.2%,57) MAIN(1,running,38.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,35.0%,114), total 100.0%
                                      Last reset 01:50:46 ago, cause: software
                                      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 3, ifcnt 140, reads 40832, writes 24, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 4320865
                                      Moves scheduled 47946, completed 47946, in progress 0, hiccups 77, segs 43, step errors 0, maxPrep 887, maxOverdue 7251, maxInc 2966, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
                                      Peak sync jitter -2/11, peak Rx sync delay 279, resyncs 0/0, no timer interrupt scheduled
                                      VIN voltage: min 7.7, current 24.1, max 24.5
                                      MCU temperature: min 38.8C, current 66.5C, max 74.8C
                                      Last sensors broadcast 0x00000012 found 2 34 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 137004, send timeouts 0, received 112920, lost 0, errs 1213, boc 0, free buffers 18, min 18, error reg 110000
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 369, adv 35625/74652
                                      Interrupt 5726621 to 0us, poll 2 to 1966us
                                      Driver 0: ok
                                      undefined 1 Reply Last reply 11 Dec 2023, 17:55 Reply Quote 0
                                        @Exerqtor please use the 3.5.0-rc.1++ tool board/expansion board firmware from https://www.dropbox.com/scl/fo/gaxzegafmnmagaefo9mgc/h?rlkey=hk4wpttdje76oews8zkuh86q3&dl=0.
                                        undefined 1 Reply Last reply 11 Dec 2023, 18:22 Reply Quote 0
                                          Exerqtor @dc42
                                          Aha, ok just moved over to it. I'll try the same job file again before hitting the bunk and report back✌️
                                          Just tried the same print with 3.5.0-c.1++ on the 1LC and it's the exact same behaviour:
                                          M122
                                          Used output buffers: 4 of 40 (40 max)
                                          Static ram: 102844
                                          Dynamic ram: 125540 of which 0 recycled
                                          Never used RAM 9168, free system stack 138 words
                                          Tasks: NETWORK(1,ready,16.8%,179) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.5%,244) CanReceiv(6,nWait,0.1%,774) CanSender(5,nWait,0.0%,327) CanClock(7,delaying,0.0%,350) TMC(4,delaying,0.7%,74) MAIN(1,running,80.9%,584) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                          Last reset 00:25:33 ago, cause: software
                                          Last software reset at 2023-12-11 19:17, reason: User, Gcodes spinning, available RAM 7056, slot 2
                                          Error status: 0x04
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 1533781, completed 1533780, timed out 0, errs 0
                                          MCU temperature: min 37.0, current 46.4, max 46.6
                                          Supply voltage: min 7.8, current 24.0, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1912/1572, gc cycles 7
                                          Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 201, reads 15125, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 199, reads 15124, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 93, reads 15136, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 96, reads 15135, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 91, reads 15137, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2023-12-11 19:43:28
                                          Cache data hit count 2492399296
                                          Slowest loop: 226.89ms; fastest: 0.09ms
                                          === Storage ===
                                          SD card longest read time 5.4ms, write time 5.1ms, max retries 0
                                          DMs created 83, segments created 42, maxWait 1083591ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                                          next step interrupt due in 30 ticks, enabled
                                          Moves shaped first try 265, on retry 158, too short 102, wrong shape 2987, maybepossible 63
                                          === DDARing 0 ===
                                          Scheduled moves 4562, completed 4522, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 0], CDDA state 3
                                          === DDARing 1 ===
                                          File is doing "G1 X187.692 Y162.442 Z1.35" in state(s) 0
                                          in 0 notIn 0
                                          === CAN ===
                                          Messages queued 17932, received 31633, lost 0, errs 0, boc 0
                                          Longest wait 3ms for reply type 6013, peak Tx sync delay 327, free buffers 26 (min 25), ts 7669/7668/0
                                          === Network ===
                                          Slowest loop: 208.78ms; fastest: 0.00ms
                                          === WiFi ===
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43112
                                          Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
                                          M122 B121
                                          Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1++ (2023-12-07 12:52:31)
                                          Tasks: Move(3,nWait,0.1%,71) HEAT(2,nWait,0.3%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.7%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.8%,114), total 100.0%
                                          Last reset 00:26:29 ago, cause: software
                                          Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 174, reads 7708, writes 22, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 401933
                                          Moves scheduled 2847, completed 2847, in progress 0, hiccups 1, segs 40, step errors 0, maxLate 1 maxPrep 900, maxOverdue 40, maxInc 40, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
                                          Peak sync jitter -2/9, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
                                          VIN voltage: min 8.1, current 24.1, max 24.7
                                          MCU temperature: min 45.6C, current 61.2C, max 61.2C
                                          Last sensors broadcast 0x00000012 found 2 228 ticks ago, 0 ordering errs, loop time 0
                                          CAN messages queued 32789, send timeouts 0, received 19593, lost 0, errs 1210, boc 0, free buffers 18, min 18, error reg 100000
                                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 354, adv 35712/74647
                                          Interrupt 5726621 to 0us, poll 2 to 1314us
                                          Driver 0: ok
                                          undefined 1 Reply Last reply 13 Dec 2023, 18:39 Reply Quote 0
                                          5 out of 147
