Solved 3.5 B3 Toolboard stepper intermittently running backwards
@Exerqtor the dedicated LED port is known as "led" in the firmware. This needs to be added to the documentation.
@dc42 Then i bet a beer on the problem being solved for both me and @ctilley79 now that we know that. Thx!
This post is deleted! -
@Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
Does the M150 P parameter to work for you on this firmware build? I'm also using RGBW neopixels. The P parameter does nothing right now.
@ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
I don't use the
P
parameter, only the R/G/B/W component "amount", it should yeld the same result although you would have to play around with the values to get the same effect. -
@ctilley79 you are correct, the P parameter doesn't work for Neopixels. I will correct this before we release beta4.
@dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
May I know how to define M950 for Duet2Wifi? It can use M150 directly before, however it is failed and need definition first now. But not pin name found...
@hestiahuang said in 3.5 B3 Toolboard stepper intermittently running backwards:
Add the source code to confirm my finding.
so don't miss Duet2Wifi...
@hestiahuang thanks, this is now fixed ready for 3.5beta4.
