screen and bltouch problem with the 3.4.6 release
Hi there everyone!
i have a duet2 board and i just uploaded the 3.4.6 firmware.
After doing so, my screen doesn´t show any info, and i can´t access to the gcodes stored on it using the screen.
The machine connects perfectly to the wifi and i can connect to the printer using the computer but definately the screen doesn´t work. i can´t even move any axys, and is not showing any temp info either.
i also now have an issue with the bltouch after the upload of the firmware. if i send a job using the computer, the bltouch goes crazy deploying the probe, starts a non stop cicle, in and out while heating the extruder.
i´m going to add my config.g
thanks in advance. -
If you copy-and-paste your code using the <> tags then everyone can see the code without having to download it.
Also, what "screen" are you talking about?
Hi there @fcwilt
the Screen is panel due7 touchscreen.
And the code is:Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 31 2020 09:39:11 GMT+0100 (hora estándar de Europa central); General preferences
M550 P"Muxar 2.1" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z420.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z480.00 E12000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z500.00 E2000.00 ; set accelerations (mm/s^2)
M906 X800 Y1000 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y10 Z0 S1 ; set axis minima
M208 X320 Y340 Z360 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zprobe.mod" H4 F200 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X15 Y25 Z1 ; set Z probe trigger value, offset and trigger height(CUANTO MAS NEGATIVO ESTE VALOR,MAS SE SEPARA EL EXTRUSOR)
M557 X20:310 Y35:340 S96 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 R0.900 K0.388:0.000 D2.59 E1.35 S1.00 B0; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 R2.664 K0.489:0.000 D3.64 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit; Fans
T0 ; select first tool -
@ander add this to config.g:
M575 P1 S1 B57600
See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#firmware-configuration
Hi @ander,
Just for future reference this is what happens when you copy-and-past using the <> tags, which you can select from just above the text box.
Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 31 2020 09:39:11 GMT+0100 (hora estándar de Europa central) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Muxar 2.1" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm M566 X1200.00 Y1200.00 Z420.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z480.00 E12000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z500.00 E2000.00 ; set accelerations (mm/s^2) M906 X800 Y1000 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y10 Z0 S1 ; set axis minima M208 X320 Y340 Z360 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"zprobe.in+zprobe.mod" H4 F200 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X15 Y25 Z1 ; set Z probe trigger value, offset and trigger height(CUANTO MAS NEGATIVO ESTE VALOR,MAS SE SEPARA EL EXTRUSOR) M557 X20:310 Y35:340 S96 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 R0.900 K0.388:0.000 D2.59 E1.35 S1.00 B0; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 R2.664 K0.489:0.000 D3.64 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory T0 ; select first tool -
Hi @droftarts
It worked beautifly! thanks!
The bltouch seems ok too....i don´t know if has to do something with the screen but hey, it´s working!
