    When a print is paused, Z is reduced by 0.03/0.04 mm on restart
    2.2k
    • jens55undefined
      jens55 @moth4017
      @moth4017, yes, my tools have different offsets but there is no tool change involved. If it is an issue of tool offset, why would the height continue to reduce for every pause cycle?
      I will see what happens when my z offsets are the same.
      moth4017undefined 1 Reply Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @jens55
        @jens55 may be there is an undisclosed design feature (bug) that's taking of the offset from one of the tools , did you try making all the offsets the same ?
        • jens55undefined
          jens55 @moth4017
          @moth4017, yes, just finished testing with all the same z offsets. Problem still exists.
          • moth4017undefined
            moth4017 @jens55
            @jens55 can you post your config
            • jens55undefined
              jens55 @moth4017
              @moth4017
              config.g
              • moth4017undefined
                moth4017 @jens55
                @jens55 in your config you are doing calculations instead of putting in the value, it may be a rounding issue , you could try putting in fixed values .
                • jens55undefined
                  jens55 @moth4017
                  @moth4017, what in specific are you referring to?
                  Yes, I calculate motor current but that has no bearing on the issue.
                  I calculate z steps but that is an even number (no rounding) and besides, we are not talking actual height error (if the steps per mm are wrong) but we are talking what DWC 'thinks' is the z height.
                  • jens55undefined
                    jens55
                    I just looked at the object model during a pause and the Z height is correct. It would appear that the printer goes back to the right position and then reduces Z height somehow. This is confirmed by the DWC Z height display where, during the resume, z height goes to 0.2 (first layer height) and then drops down to 0.16.
                    It sure looks like there is some macro someplace that somehow changes the height on resume .... but where would this happen ... is there something that automatically runs after pause.g has executed ????
                    • moth4017undefined
                      moth4017 @jens55
                      @jens55 just a question are you doing the pause from DWC or in the slicer software ? eg pause at height x "do something" then resume?
                      • jens55undefined
                        jens55
                        How does resurrect.g fit in the big picture? I thought it only applies when there was a power outage?
                        The reason I bring this up is because the resurrect.g file contains this line:
                        G92 X266.207 Y126.771 Z-0.036 U0.000
                        and the z-0.036 seems very much like the error I am seeing.
                        moth4017undefined 2 Replies Last reply Reply Quote 0
                        • moth4017undefined
                          moth4017 @jens55
                          @jens55 Any time you pause a print from SD card, the state of the print is saved to a special file on the SD card, sys/resurrect.g
                          • moth4017undefined
                            moth4017 @jens55
                            @jens55 set value to 0 sys/resurrect.g and test 🙂
                            • jens55undefined
                              jens55 @moth4017
                              @moth4017, I need a bit more than that .... resurrect.g has a whole bunch of lines. Are you suggesting to set the Z portion of the G92 line to 0? BTW, on the other two printers the Z portion of the G92 command is 0.2.
                              Also, when I enter M911, the printer reports that auto save is disabled .... why would resurrect.g be run if auto save is disabled?
                              • moth4017undefined
                                moth4017 @jens55
                                @jens55 just change this line G92 X266.207 Y126.771 Z0 U0.000
                                you will have to try and work out when it happens
                                you can add the :-
                                echo "this just happened"
                                in the *.g files to give you a pointer to when the move happens. and then monitor it in the DWC console
                                • jens55undefined
                                  jens55 @moth4017
                                  @moth4017, thanks for your help! I am giving up for today. I am pretty sure that the issue is related to the resurrect.g file but I have no clue why this file would be run when auto save is not enabled. The file is generated by the system and I do not know where it gets the Z offset value from.
                                  I am hoping that somebody with more knowledge can explain to me how resurrect.g is generated, where the Z offset in resurrect.g comes from and why the resurrect.g file would be run if no autosave is enabled.
                                  BTW, resurrect.g calls to execute resurrect-prologue.g but that file does not exist on this printer.
                                  moth4017undefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                                  • moth4017undefined
                                    moth4017 @jens55
                                    @jens55 hi, did a test when you press "pause" in DWC it does the following
                                    12/25/2023, 2:20:58 PM Printing paused at X153.7 Y153.2 Z2.7
                                    12/25/2023, 2:20:57 PM Resume state saved
                                    pause
                                    12/25/2023, 2:20:56 PM M25
                                    Resume state saved
                                    • jens55undefined
                                      jens55 @moth4017
                                      @moth4017, yes, my setup does the same thing .... everything works just like it should with the exception of DWC reporting a slightly lower Z (but only after it has gone to the correct Z)
                                      • moth4017undefined
                                        moth4017 @jens55
                                        @jens55 this is a long shot but i think worth doing, do the pause , but then run the resume.g lines of code one by one in the command line and see if this works correctly
                                        • o_lampeundefined
                                          o_lampe @jens55
                                          @jens55 said in When a print is paused, Z is reduced by 0.03/0.04 mm on restart:
                                          I thinks it's best to raise an official question in the beta firmware section.
                                          Now that you know what to look for, it would be helpful to test the various 3.5rc_ candidates first
                                          • jens55undefined
                                            jens55 @o_lampe
                                            @o_lampe, thanks for weighing in.
                                            I am wildly guessing at this point and grasping at straws. Although the height issue 'seems' to coincide with something in resurrect.g, that file shouldn't actually run according to what I believe.
                                            I did another test by modifying pause.g and resume.g with an M291at the end of each file. I could then see what the head position is at each stage. As it turns out, after resume.g has executed, the nozzle is exactly where it is supposed to be. After I dismiss the message, Z immediately changes from 0.2 to 0.17 (when printing first layer of 0.2 mm) and then it continues printing. I do not know if the nozzle position has actually changed at this point or if the Z display in DWC has just been reset for some reason or other.
                                            So what happens between resume.g finishing and the print process starting back up? Something is obviously telling Z to change.
                                            I checked to see if bed compensation somehow enters the picture but bed compensation, according to the height map, is in the 0.1 range in the area where all this is happening.
