    Multiply issues with new 6HC
    661
    • yagodajmundefined
      yagodajm
      Good afternoon, I got a new 6HC the other day with the WiFi module add-on. I just got everything wired up and the configuration created. I have two Z motors, 2 Y motors, 1 X, and 1E. I have the two motors for Z and Y tied to each other. The first issue is it will not upgrade to firmware 3.5.0, it is stuck on 3.4.5. The DWC is on 3.5.0. I have tried several times to install it, and it acts like it is installing and restarts the board and it is still 3.4.5.
      The second issue is that I can not get the WiFi setup, I have tried several times and it still will not connect. I can connect over ethernet with no issues.
      The final issue is that I can not get anything to home correctly. The motors will move very little and just stop and act like they are homed. This is my second DUET, I have a Maestro on my other printer, which has been very good. I am not sure where I am going wrong.
      Here is what I have for a configure file so far.
      ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Mon Dec 25 2023 19:24:20 GMT-0600 (Central Standard Time)
      ; General
      M550 P"Duet 3" ; set hostname
      M552 P0.0.0.0 S1 ; configure Ethernet adapter
      M586 P0 S1 ; configure HTTP
      M551 P"reprap"     ; set password (used when you connect Duet Web Control or via FTP)
      M552 S1            ; enable WiFi (Use DHCP or set IP address with M587)
      M586 P0 S1         ; enable HTTP
      M586 P1 S0         ; disable FTP
      M586 P2 S0         ; disable Telnet
      M587 S"Network" P"PASSWORD" I192.168.1.150  ; connect to access point "Apple Network" using WPA2-PSK authentication
      ; Smart Drivers
      M569 P0.0 S0 D3 V2000 ; driver 0.0 goes backwards (Z axis)
      M569 P0.1 S0 D3 V2000 ; driver 0.1 goes backwards (U axis)
      M569 P0.2 S0 D3 V2000 ; driver 0.2 goes backwasrds (X axis)
      M569 P0.3 S1 D3 V2000 ; driver 0.3 goes forwards (extruder 0)
      M569 P0.4 S0 D3 V2000 ; driver 0.4 goes backwards (Y axis)
      M569 P0.5 S0 D3 V2000 ; driver 0.5 goes backwards (V axis)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.2 Y0.4:0.5 Z0.0:0.1 ; set axis mapping
      M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation
      M906 X1000 Y1000 Z1000 U1000 V1000 ; set axis driver currents
      M92 X80 Y80 Z400 U400 V80 ; configure steps per mm
      M208 X0:200 Y0:200 Z0:200 U0:200 V0:200 ; set minimum and maximum axis limits
      M566 X900 Y900 Z12 U900 V900 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 U6000 V6000 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z20 U500 V500 ; set accelerations (mm/s^2)
      ; Extruders
      M584 E0.3 ; set extruder mapping
      M350 E16 I1 ; configure microstepping with interpolation
      M906 E1000 ; set extruder driver currents
      M92 E420 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E3600 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K0 ; configure Cartesian kinematics
      ; Probes
      M558 K0 P9 C"""io2.in""" H5 F120 T6000 ; configure BLTouch probe via slot #0
      G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
      M950 S0 Cio4.out ; create servo #0 for BLtouch
      M574 X1 P"io0.in" S1 ; configure X axis endstop
      M574 Y1 P"io1.in" S1 ; configure Y axis endstop
      M574 Z1 S2 ; configure Z axis endstop
      ; Mesh Bed Compensation
      M557 X25:300 Y25:300 S40:40 ; define grid for mesh bed compensation
      ; Sensors
      M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
      M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
      M950 H0 C"out0" T0 ; create heater #0
      M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
      M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
      M950 H1 C"out1" T1 ; create heater #1
      M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
      M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
      ; Heated beds
      M140 P0 H0 ; configure heated bed #0
      M950 F0 C"out3" ; create fan #0
      M106 P0 S0 L0 X1 B0.1 ; configure fan #0
      M950 F1 C"out4" ; create fan #1
      M106 P1 S0 B0.1 H1 T45 ; configure fan #1
      M563 P0 D0 H1 F0 ; create tool #0
      M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
      Any help would be greatly appreciated.
      Thanks,
      Justin
      yagodajmundefined 1 Reply Last reply Reply Quote 0
      • yagodajmundefined
        yagodajm @yagodajm
        @yagodajm Update, finally got the firmware to update, so I am at 3.5.0 RC 2 on the HC and the DWC. I am getting an error on start up of the WiFi card being disabled, which is strange since I have it enabled. I am still unable to get the axises to home at all. I am also using OUT0 for my bed and I am not getting 24 V from that output when I turn on the bed heater.
        Sorry for all the questions, I never had this many issues with the other board. I have read over so many of the documents on the website and can't figure out where I am going wrong.
        Thanks,
        Justin
          Can you send M122 and M98 P"config.g" in the gcode console and share the results here?
          • yagodajmundefined
            yagodajm @Phaedrux
            @Phaedrux Good Morning, here is the requested information.
            M122
            12/28/2023, 7:44:02 AM	M122
            RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.2 (2023-12-14 10:32:22) running on Duet 3 MB6HC v1.02 or later (standalone mode)
            Board ID: 0JD4M-958L1-M2NSW-6JTD4-3S46S-T0KPW
            Used output buffers: 1 of 40 (18 max)
            Error in macro line 13 while starting up: Failed to add SSID to remembered list: WiFi module is disabled
            Static ram: 154844
            Dynamic ram: 120660 of which 12 recycled
            Never used RAM 67620, free system stack 200 words
            Tasks: NETWORK(1,ready,39.0%,161) ETHERNET(5,nWait,0.1%,321) HEAT(3,nWait,0.0%,328) Move(4,nWait,0.0%,339) CanReceiv(6,nWait,0.0%,942) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,343) TMC(4,nWait,7.7%,59) MAIN(1,running,52.9%,103) IDLE(0,ready,0.1%,30), total 100.0%
            Owned mutexes:
            Last reset 00:01:51 ago, cause: power up
            Last software reset at 2023-12-27 19:22, reason: User, Gcodes spinning, available RAM 67620, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            MCU temperature: min 14.4, current 26.4, max 26.4
            Supply voltage: min 24.4, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.2, max 12.4, under voltage events: 0
            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/76/0, gc cycles 0
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Driver 1: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Driver 2: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Driver 3: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Driver 4: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Driver 5: standstill, SG min n/a, mspos 8, reads 26989, writes 17 timeouts 0
            Date/time: 2023-12-28 07:44:00
            Slowest loop: 10.29ms; fastest: 0.07ms
            === Storage ===
            Free file entries: 20
            SD card longest read time 5.6ms, write time 0.0ms, max retries 0
            DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
            no step interrupt scheduled
            Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
            === DDARing 0 ===
            === DDARing 1 ===
            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            File2 is idle in state(s) 0
            Queue2 is idle in state(s) 0
            Q0 segments left 0, axes/extruders owned 0x0000000
            Code queue 0 is empty
            Code queue 1 is empty
            === CAN ===
            Messages queued 1000, received 0, lost 0, errs 523778, boc 0
            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 557/0/0
            Tx timeouts 0,0,556,0,0,442 last cancelled message type 30 dest 127
            === Network ===
            Slowest loop: 10.64ms; fastest: 0.03ms
            Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 2 of 8
            = Ethernet =
            Interface state: active
            Error counts: 0 0 0 1 0 0
            === WiFi ===
            Interface state: disabled
            Module is disabled
            Failed messages: pending 0, notrdy 0, noresp 0
            === Multicast handler ===
            Responder is inactive, messages received 0, responses 0
            M98
            12/28/2023, 7:46:20 AM	M98 P"config.g"
            HTTP is enabled on port 80
            Error: Failed to add SSID to remembered list: WiFi module is disabled
            FTP is disabled
            TELNET is disabled
            Error: Unknown pin name '"io2.in"'
            Error: invalid Z probe index
            Error: in file macro line 58 column 10: M950: expected a string expression
            Warning: Heater 0 predicted maximum temperature at full power is 321°C
            I was able to get the heated bed working, so right now it is just the WiFi and homing the axises.
            Thanks,
            Justin
            • yagodajmundefined
              yagodajm @yagodajm
              Ok so I am still having issues with the WiFI and getting anything to home properly.
              First the WiFi, I worked on this all day today. I have the Module and server firmware installed. I keep getting an error that the WiFi is disabled. I ran a M552 I1 S0 and got a green box saying it was accepted. I then ran a M552 I1 S1 and also got a green box saying it was accepted. Under Machine-Specific it shows the server version, but I still can get it to connect to my network. I ended up wiping the board and reloading all the firmware, I read this may fix the issue. However, after reinstalling the firmware, I am still having the same issues. Should there be any indicator LEDs on the module? I read something about green and blue but did not see when these should happen. I see a quick LED flicker green when I first boot the board, but that is the only time I see the light. I am at a complete loss.
              I am also still having issues getting anything to home correctly. I even went back and did the whole config setup in the older version of RRF. I was thinking maybe some of the settings were not correct. That still did not work.
              Any help would be greatly appreciated, I am pulling my hair out.
              Thanks,
              Justin
              jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @yagodajm
                @yagodajm which wifi server version are you running? Have you tried 2.1b6?
                  droftarts administrators @yagodajm
                  @yagodajm did you follow the instructions here? https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#wifi-module-installation-and-setup
                  Particularly:
                  Note that the wifi module is the second network interface on the 6HC (the ethernet interface is the first one) so all M552 commands need to contain "I1" to indicate they are for the wifi module interface.
                  So make sure you have M552 I1 S1 in your config.g, the config you posted earlier only has M552 S1. Also remove M587 in your config.g; you do not need to keep setting WiFi SSID and password.
                  Post your current config and homing macros. What motors do you have on the axes?
                  • yagodajmundefined
                    yagodajm @jay_s_uk
                    @jay_s_uk Good evening, Yes, I am using 2.1b6. I am using the one from this repository. https://github.com/Duet3D/WiFiSocketServerRTOS/releases DuetWiFiServer_32S3.bin
                    Thanks,
                    Justin
                    • yagodajmundefined
                      yagodajm @droftarts
                      @droftarts Good Evening, Here are my current config and homing files. I am using StepperOnline motors. I have these on my other printer and they work great. They are Bipolar 2.0 A. I added the line in my config for the WiFi, I just don't think the server is starting up automatically like it should, If I do a M552 I1 S1 and look on the Machine_ specific page it shows the firmware number. I still never get any lights on the wifi module itself.
                      Thanks,
                      Justin
                      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:37 GMT-0600 (Central Standard Time)
                      ; General
                      M552 I1 S1
                      ; Smart Drivers
                      M569 P0.0 S1 D3 V2000 ; driver 0.0 goes forwards (X axis)
                      M569 P0.1 S0 D3 V2000 ; driver 0.1 goes backwards (Y axis)
                      M569 P0.2 S1 D3 V2000 ; driver 0.2 goes forwards (Z axis)
                      M569 P0.3 S1 D3 V2000 ; driver 0.3 goes forwards (Z2 axis)
                      M569 P0.4 S1 D3 V2000 ; driver 0.4 goes forwards (Y2 axis)
                      M569 P0.5 S0 D3 V2000 ; driver 0.5 goes backwards (extruder 0)
                      ; Axes
                      M584 X0.0 Y0.1:0.3 Z0.2:0.3 ; set axis mapping
                      M906 X1000 Y1000 Z1000  ; set axis driver currents
                      M92 X80 Y80 Z400  ; configure steps per mm
                      M208 X0:300 Y0:300 Z0:300  ; set minimum and maximum axis limits
                      M566 X900 Y900 Z12  ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000 Y6000 Z180  ; set maximum speeds (mm/min)
                      M201 X500 Y500 Z20  ; set accelerations (mm/s^2)
                      ; Extruders
                      M584 E0.5 ; set extruder mapping
                      ; Kinematics
                      ; Probes
                      M950 S0 Cio2.out ; create servo #0 for BLtouch
                      M557 X25:275 Y25:275 S40:40 ; define grid for mesh bed compensation
                      ; Sensors
                      ; Heated beds
                      M563 P0 D0 H1 F1 ; create tool #0
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:41 GMT-0600 (Central Standard Time)
                      ; lift Z
                      G91 ; relative positioning
                      G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed
                      G90 ; absolute positioning
                      ; home XY
                      var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                      var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                      G1 H1 X{-var.xTravel} Y{-var.yTravel} F600 ; coarse home in the -X and -Y directions
                      G1 H2 X5 Y5 F6000 ; move back 5mm
                      G1 H1 X{-var.xTravel} Y{-var.yTravel} F300 ; fine home in the -X and -Y directions
                      ; home Z
                      var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
                      var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
                      G1 X{var.xCenter} Y{var.yCenter} F6000 ; go to bed centre
                      G30 ; probe the bed
                      M98 P"homeU.g" ; home U axis
                      M98 P"homeV.g" ; home V axis
                      ; homex.g
                      ; called to home the X axis
                      ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:42 GMT-0600 (Central Standard Time)
                      ; lift Z
                      G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
                      ; home X
                      var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                      G1 H1 X{-var.maxTravel} F600 ; coarse home in the -X direction
                      G1 H2 X5 F6000 ; move back 5mm
                      G1 H1 X{-var.maxTravel} F300 ; fine home in the -X direction
                      G1 H2 Z-5 F6000 ; lower Z again
                      ; homey.g
                      ; called to home the Y axis
                      ; lift Z
                      ; home Y
                      var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                      G1 H1 Y{-var.maxTravel} F600 ; coarse home in the -Y direction
                      G1 H2 Y5 F6000 ; move back 5mm
                      G1 H1 Y{-var.maxTravel} F300 ; fine home in the -Y direction
                      ; homez.g
                      ; called to home the Z axis
                      ; lift Z
                      ; home Z
                      G30 ; probe the bed
                      • yagodajmundefined
                        yagodajm @yagodajm
                        @yagodajm Good evening, Ok I got all the motors wired up and double-checked everything. I still can't get anything to home correctly with the home files above. When I do home all or home each one, it acts like it will home and just stops and the axis turns blue like it has been homed. I can move that axis, but only in one direction.
                        I finally got the WiFi to connect. I was in the DWC and ran a M552 I1 S0, M552 I1 S1, and a M587 with the WiFi network and password. I got a green LED and it connected. Do I just have to add the M552 I1 S1 to the config file for it to connect every time?
                        I will continue to got through Home files to see what I am missing. One not, this printer is one where the bed raises up and down and the Y and X move back and forth. Do I have to do a different config? I also have two motors on Z on two separate axis, two motors on Y on two separate axis, and X by itself. Would it just be better to tie the two Z and two Y to one driver?
                        Thanks for all of you help so far.
                        Justin
                        • yagodajmundefined
                          yagodajm @yagodajm
                          @yagodajm Ok, I got X and Y to home correctly, I had to set the endstops to Low. Those now home properly. I am still having an issue with Z and the BL touch probe.
                          This is what the configurator tool created.
                          ; Probes
                          I get this error on start-up Error in start-up file macro line 49: Unknown pin name '"io2.in"'
                          My question is what are there 3 sets of " around the io2.in pin? And why are there now around io2.out?
                          If I remove the " from the io2.in and add a set to io2.out, then the on homing after x and Y home, the hotend will move to the center of the bed and I get this error. Error: line 12 column 135: meta command: array index out of bounds
                          Error: Failed to home axes Z
                          I looked through the documentation, but Can't find any answers.
                          Thanks,
                          Justin
                            jay_s_uk @yagodajm
                            @yagodajm you should have 1 set of " around the io pin
                            • yagodajmundefined
                              yagodajm @jay_s_uk
                              @jay_s_uk I tried that I still get this error, Error: line 12 column 135: meta command: array index out of bounds
                              Error: Failed to home axes Z. I have tried every combination so far. I also noticed that when I try and test my BLTouch nothing happens. When I first turn on my printer it does a double click and it is red, so I know it works.
                              • fcwiltundefined
                                fcwilt @yagodajm
                                @yagodajm said in Multiply issues with new 6HC:
                                Why are you trying to find xCenter, etc using move.compensation.probeGrid.mins[0] and so forth?
                                • yagodajmundefined
                                  yagodajm @fcwilt
                                  @fcwilt This is the file that the RRF Config tool made. I think everything is different with the 3.5 config tool now. My other printer is running on 3.4.6 so the files are all different. I can't use those files for a comparison.
                                  • fcwiltundefined
                                    fcwilt @yagodajm
                                    The error you mentioned suggests that the lines that are setting xCenter and yCenter are attempting to index into values that do not exist.
                                    As a test set xCenter and yCenter directly to values that you compute by hand and see if the error goes away.
                                    • yagodajmundefined
                                      yagodajm @fcwilt
                                      @fcwilt Good afternoon, Ok I finally got a chance to make changes to the home file. I just set X150 Y150. That worked, the error went away and the z axis homed. I am not sure why the RRF is making the home files like that now, it is very confusing.
                                      One last question, my hotend fan comes right on when I start up my printer. I changed that line every which way and can't get it to shut off. It should only come on when the hotend gets to 45c. It is just a regular 2 wire fan.
                                      I have it wired on out4 GND and V_outLC1.
                                      Any ideas?
                                      Thanks,
                                      Justin
                                      • fcwiltundefined
                                        fcwilt @yagodajm
                                        It's a very bad idea because it relies on values that may not be set when homing Z, as you have found.
                                        It should be wired to OUT4 instead of OUT4 GND.
                                        • yagodajmundefined
                                          yagodajm @fcwilt
                                          @fcwilt thank you, that worked. The part fan should be wired the same way, correct.
                                          Thanks,
                                          Justin
