    Dockable Probe Configurator Macro
    Gcode meta commands
    1.0k
      jay_s_uk @mher
      @mher you should be able to call M401 manually before the first call of G30 and then it should remain undocked until you send a final M402
      mherundefined 2 Replies Last reply Reply Quote 1
      • mherundefined
        mher @jay_s_uk
        @jay_s_uk I'll do some testing tonight and potentially change the script to output the results into the retract/deploy macros. Only thing I'm slightly worried about is that it'd be overwriting any settings someone already has in there. Then again that might be a good thing
        • mherundefined
          mher @jay_s_uk
          @jay_s_uk as promised I looked into it and I've updated the script accordingly in the start post
          • izemanundefined
            izeman @mher
            @mher Thanks for this great macro. I tried it, and most of it worked for me, but I don't see what type of probe it expects.
            I configured the Klicky as z-probe switch connected to z-endstop.
            I can pick it up, detach, attach etc, but after the final test is always says:
            M292 The probe wasnt detached, please start again
            This is M558:
            m558
            Z Probe 0: type 5, input pin zstop, output pin nil, dive height 5.0mm, probe speeds 120,120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @izeman
              @izeman
              It looks to me like the two M564 commands are indented too far.
              Try aligning them with the "abort" commands
              izemanundefined 1 Reply Last reply Reply Quote 0
              • izemanundefined
                izeman @OwenD
                @OwenD said in Dockable Probe Configurator Macro:
                @izeman
                There's several M564: Line #14,30,48,53,60,76,81. Which ones do you mean?
                • OwenDundefined
                  OwenD @izeman
                  @izeman
                  All the ones in the if conditions which precede an abort command
                  if sensors.probes[0].value[0] = 1000
                      M291 P"Make sure the klicky probe is mounted on the toolhead" S3
                  		M564 H1	; Don't allow movement without homing
                          abort "The probe doesn't seem to be attached, please attach before starting the configuration again"
                  Should be
                  • izemanundefined
                    izeman @OwenD
                    @OwenD Thanks. It seems though that this was somehow auto-formated already. They all look like you said. Once you copy it here it changes the format?!
                    • izemanundefined
                      izeman @izeman
                      Reconfigured the probe now - seems it was wrong somehow.
                      Now I get:
                      M292
                      Error: in file macro line 270 column 7: meta command: expected string expression
                      • OwenDundefined
                        OwenD @izeman
                        @izeman
                        The first warning is a it says.
                        Review Klicky.g with a text editor set to show spaces and tabs.
                        You can see tabs before the M564 and spaces everywhere else
                        The second error is in a much bigger file.
                        Either your print file, or maybe daemon.g
                        Shouldn't be many files longer than 270 lines.
                        It'll be something like an echo or other command that doesn't have a quoted string after it.
                        • izemanundefined
                          izeman @OwenD
                          @OwenD I will check the file with another editor. Thanks!
                          But for the error in macro line 270: There is no daemon.g anywhere on the SD-card, and I'm not printing anything. I'm just calling the macro to generate deployprobe.g and retractprobe.g.
                          This must be some internal file that's called?!
                          Got all the tabs removed now, and RRF doesn't complain anymore. Now everything runs fine, and in the end it throws this error:
                          M292
                          Error: in file macro line 490 column 7: meta command: expected string expression
                          Same error, different location ... If I knew where to search for it ...
                          • OwenDundefined
                            OwenD @izeman
                            @izeman
                            I'm guessing the version of RRF and/or DWC you're using is miscounting the line feeds or carriage returns that your editor is using.
                            I think the actual error is caused because there were spaces in the file between "echo >" and the filename
                            echo > {var.deployFile} "; The deploy command for Z when using a dockable probe" ; Let's create the probe loading code file for dockable probes
                            echo >> {var.deployFile} "if sensors.probes[0].value[0] != 0"
                            Should be
                            echo >{var.deployFile} "; The deploy command for Z when using a dockable probe" ; Let's create the probe loading code file for dockable probes
                            echo >>{var.deployFile} "if sensors.probes[0].value[0] != 0"
                            See the documentation here
                            There must be no spaces between the > or >> symbol and <filename>. The default folder for the file is /sys.
                            Try the attached file without editing it.
                            Rename it to whatever you wish
                            klicky_setup.g
                            • izemanundefined
                              izeman @OwenD
                              @OwenD Thanks for your tremendous effort, but the problem still exists.
                              izemanundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                              • izemanundefined
                                izeman @izeman
                                I now just went to the code, and I guess I could see what it's meant to do, and basically it's not needed to be run as a macro. I can just determine the positions per hand, and then c&p the to be generated code (the last two blocks) into the .g files. I will try that.
                                • izemanundefined
                                  izeman @izeman
                                  Just in case someone else is looking for a deployprobe.g and retractprobe.g for a klicky probe, and got the same issues as I got. Just use the tool to determine the values, or do it manually, and c&p it into those two files:
                                      var originX = {move.axes[0].userPosition} ; Store the X position before grabbing the probe.
                                      var originY = {move.axes[1].userPosition} ; Store the Y position before grabbing the probe.
                                      G1 X238.6 Y55 F999999 ; Move tool in front of dock
                                      G1 X238.6 Y25 F999999 ; Move tool in position where probe is mounted
                                      if var.originX > 238.6 || var.originY > 55 ; Move the toolhead back to the position we came from
                                         G1 X{var.originX} Y{var.originY} F999999
                                      M400
                                      abort ""Error probe not attached - aborting""
                                  ; The retract command for Z when using a dockable probe
                                  ; Let's create the docking code file for dockable probes
                                  if sensors.probes[0].value[0] != 1000
                                      G90
                                      M400
                                      G1 X188.6 Y25 F999999 ; Move tool to detach probe
                                      M400
                                      abort ""Error probe not docked - aborting""
                                  • OwenDundefined
                                    OwenD @izeman
                                    @izeman
                                    I'm afraid that error is my fault. (control character in string)
                                    In my haste, I did a search and replace to change all the spaces to tabs to fix the first error you were having.
                                    I did not notice that it also put tabs in the echo command (which must have only spaces)
                                    I do not have a klicky probe, so cannot fully test this, but I have tested everything except checking the probe status and it should now work as the OP intended.
                                    Amended file attached
                                    klicky_setup.g
                                    BTW, you also appear to have some errors in config.g
                                    You should run M98 P"config.g" and investigate
                                    • izemanundefined
                                      izeman @OwenD
                                      @OwenD WORKS GREAT now!! Thanks a lot!!!
                                      • mherundefined mher referenced this topic
