    Please help understanding coordinated (bed, nozzle, ABl, ....)
    541
    • fcwiltundefined
      fcwilt @izeman
      EDIT: Reading more on the topic I get more confused, but it seems I was WRONG. M208 uses TOTAL PHYSICAL movement for the first parameter and the second then defines where the BED's left front corner is located - in relation to the physical 0/0. This correct? 😉
      No.
      The simplest way, to me, is to use this syntax...
      M208 Xaaa:bbb Yccc:ddd Zeee:fff
      where aaa is X min and bbb is X max and so forth.
      For example, on all my printers I place 0,0 at the center of the bed, so for my printer with a bed size of 300 x 200 this would be:
      M208 X-150:150 Y-100:100
      izemanundefined 1 Reply Last reply Reply Quote 0
      • izemanundefined
        izeman @fcwilt
        @fcwilt tbh this makes it even more confusing. And what I miss in all documention I‘ve seen is the reference system.
        My head can always move to the endswitches. So in your case that would mean i have to use 0/0 as minimum. But that can’t be true.
        • fcwiltundefined
          fcwilt @izeman
          @izeman said in Please help understanding coordinated (bed, nozzle, ABl, ....):
          Sorry, I thought it might help. I don't want to confuse you.
          As I mentioned I like to have X=0 Y=0 at the center of the bed. The endstop sensors can be at either end of an axis. What type of sensor is used and where they are located is set my M574.
          With regards to endstops, M208 merely determines what value is assigned to the logical axis position when the endstop sensor is triggered.
          If the endstop sensor is at the low end of the axis the min value specified in M208 is used. Likewise, if the endstop sensor is at the high end of the axis the max value specified in M208 is used.
          • izemanundefined
            izeman @fcwilt
            @fcwilt said in Please help understanding coordinated (bed, nozzle, ABl, ....):
            All good! Not your fault that I'm confused. I just got issues when it comes to this kind of things. I'm better in other things 😉
            Ok. So my endswitches are in the back right corner. So all HIGH/MAX. So basically I can check what total movement I can have in X&Y and set this like:
            M208 X0:total movement Y0:total movement
            and then use G10 for axis offset to set the nozzle to the front left corner for 0/0?
            • Mr Yodundefined
              Mr Yod @dc42
              Aren't those just rotated axis? 🤔
              If you rotate the image 180° you'll get the axis that are normally used.
              Now, if I think about mirroring the image along X and then do the same along Y I'll get the same as rotating it 180°. 🤔
              @izeman
              Did you set some tool's offset?
              Bercause You have to consider those, too, for the coordinates.
              But basically the movement is considered from (0, 0), then it can go to negative coordinates; so, let's say (20, 20), is 20mm X and 20mm Y from where you set your (0, 0)
              izemanundefined 2 Replies Last reply Reply Quote 0
              • izemanundefined
                izeman @Mr Yod
                @Mr-Yod said in Please help understanding coordinated (bed, nozzle, ABl, ....):
                I think you are correct. If you change ONE axis from front/back or left/right then it get's mirrored. If you change both it get rotated.
                • izemanundefined
                  izeman @Mr Yod
                  @izeman
                  No tool's offset yet. I just try to get the axis/bed configured correctly first. At least that was what I was hoping for. I now have tool homed at 250/250, but can't move away from there, as moving the head to 0-249 makes it go to 250+. Direction of the axes is reversed. Even though they home correctly.
                  • fcwiltundefined
                    fcwilt @izeman
                    No need for G10 assuming your M574 specifies that endstop sensors are at the high end of each axis.
                    With back/right being Xmax/Ymax then front/left will be Xmin/Ymin.
                    • izemanundefined
                      izeman @fcwilt
                      I'm totally GAGA. There must be some knot in my brain. Sorry to act that stupidly.
                      I now updated my config to move 0/0 to left/front. Bed is 235/235. The head can move 250 in both directions. What would I set my config to?
                      fcwiltundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @izeman
                        @izeman
                        Well the diagram is clear enough.
                        Ignoring Z for now, your M208 would be
                        M208 X0:250 Y0:250
                        Your M574 would be something like below, since I have no idea what pins you are using for your endstop sensors.
                        M574 X2 S1 P"pin_name_for_x_endstop"
                        M574 Y2 S1 P"pin_name_for_y_endstop"
                        • DIY-O-Sphereundefined
                          DIY-O-Sphere @izeman
                          @izeman
                          Please note:
                          The homing files have to be adapted as well.
                          Otherwise the print head will move in the wrong direction during the homing process
                          (UTC+1)
                          • izemanundefined
                            izeman @DIY-O-Sphere
                            @DIY-O-Sphere said in Please help understanding coordinated (bed, nozzle, ABl, ....):
                            @izeman
                            Please note:
                            Yeah. Just noted that 🙂 It seems to work now. I guess ... Just running a full ABL with 20mm grid.
                            I just seems that my 0/0 now is like 10mm to the left and 15mm to the front of the print bed. Looks good. But when I move to the center of the bed 117/117 it moves to that number away from the real 0/0 (movement maximum) and not to the real center which should be 117+10/117+15.
                            • fcwiltundefined
                              fcwilt @izeman
                              That is likely due to the endstop sensors not triggering at exactly 250. That is common.
                              Two ways to deal with it.
                              • Change the M208 settings so the max values correspond to the actual physical position when the endstop sensor is triggered
                              • Use G92 to adjust the logical X and/or Y position so the position at the center is correct. Put the G92 in the homing file of X and/or Y with the values needed to obtain the correct center position. One way to do this is have a G1 command at the end of the homing file with the value needed to move to the center and then have a G92 command with 0 as its value to set the logical position to 0, thus matching the physical position. For example in homeX.g you might have: G90 G1 Xnnn G92 X0
                              • izemanundefined
                                izeman @fcwilt
                                Two issues with that:
                                So instead of saying I can move 250/250 I tell the printer it can only move 250-10/250-15? It's not easy to find the "real" 0/0 when you're homing at some random 250/250 (which in reality could be 248/251 or something else) and then re-iterate from there where your real "0/0" is. Isn't it?
                                When I use G92 to move the working coordinates I have the issue that it can't pick up the klicky probe after homing again as it's location has change then ...
