    USB CNC Pendant project
    CNC
    8
    27
    3.8k
    • IlI_Cncundefined
      IlI_Cnc
      I was thinking in getting one of those pendants, but I don't know a lot of the duet3d programming yet. Can you tell me how to get it to work? like, where do I put the files or what I need to do? I kinda need a crash course in the duet environment to be honest.
      Also Aliexpress is running Summer sale so you could get the pendant easily
      If I get one I can maybe help test stuff if I'm available too
      oliofundefined hurzhurzundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @IlI_Cnc
        @IlI_Cnc the only thing you would need on the Duet side is to enable the serial connection (if you use a paneldue that's already happened). You do this by adding M575 P1 B57600 S1 to your config.g
        • hurzhurzundefined
          hurzhurz @IlI_Cnc
          @IlI_Cnc For the Duet side, the most important part is to enable the PanelDue port via M575, like @oliof already said.
          In addition, you may want to create macro files to define what should happen when you press on the various buttons of the pendant.
          If you press a button, you should be able to see in the console in the Duet Web Control which file it tried to execute und you have to create, to give that button a function.
          And to flash the Raspberry Pico, you can simply take the compiled firmware.uf2 file from my GitHub repository.
          You need to connect the Pico via USB to your computer. But while plugging it in, you have to press the BOOTSEL button.
          There should then appear a new drive. Just copy firmware.uf2 on that drive.
          chimaeraghundefined 1 Reply Last reply Reply Quote 0
          • Hannahundefined
            Hannah
            THX, I'll build this instead of the old wired version
            • chimaeraghundefined
              chimaeragh @hurzhurz
              @hurzhurz Will this work with the 4 axis version, WHB04B-4? I don't need to control that many axes and it seems to be half the cost of the 6-axis on AliExpress
              WHB04B-4
              Duet 2 Wifi, Ooznest Workbee CNC 1510
              hurzhurzundefined 1 Reply Last reply Reply Quote 0
              • oliofundefined
                oliof
                Great work @hurzhurz. It would be cool to see if you (or anyone else) could adopt the FluidNC M5Dial Pendant as well.
                • hurzhurzundefined
                  hurzhurz @chimaeragh
                  @chimaeragh said in USB CNC Pendant project:
                  I can't tell for sure, but I think the chances are good that the 4 axis version works as well.
                  For the most part, I used the protocol description from the LinuxCNC driver: https://github.com/LinuxCNC/linuxcnc/tree/master/src/hal/user_comps/xhc-whb04b-6
                  I think I read a comment somewhere that the WHB04B-4 was used successful with the LinuxCNC WHB04B-6 driver by someone.
                  And I can't imagine that there would be a difference needed in the protocol.
                  Though it could be that the dongle of the 4 axis version has a different USB PID. But that would be trivial to fix.
                  • hurzhurzundefined
                    hurzhurz @oliof
                    @oliof said in USB CNC Pendant project:
                    Thanks!
                    The FluidNC M5Dial Pendant looks like another neat solution!
                    And as it is already made to communicate via serial / G-code commands, it should probably be not that hard to adapt.
                    Most work should be needed for the part with the status display for coordinates etc.
                    • IlI_Cncundefined
                      IlI_Cnc
                      I'm waiting for parts and the pendant now, when they arrive and I'll try to get everything working and post if everything works fine.
                      Thanks for the help
                      • IlI_Cncundefined
                        IlI_Cnc
                        In case i want to connect with a IO port what should i do with the activation part?
                        Also, since in my board (Duet 3 6XD) seems to have a different panel due pinout what should i wire the usb to?panel.png
                        • hurzhurzundefined
                          hurzhurz @IlI_Cnc
                          @IlI_Cnc You actually have two ports on your board where a PanelDue can be connected, the 10-pin "PANEL DUE" connector and the 5-pin IO_0 connector.
                          Both share the same serial interface (that you can enable with M575 P1 B57600 S1).
                          The 10-pin connector is used if you want to use the SD card slot on the PanelDue.
                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue
                          I would suggest using the IO_0 connector like shown in my wiring diagramm on GitHub.
                          • ajmartinsundefined
                            ajmartins
                            Hi, just start to saying amazing project, and thanks for sharing ;), now one little problem... i tried to use continuous mode, but im getting some errors.
                            Error: Failed to read code from macro daemon.g: Failed to evaluate "global.run_daemon": unknown value 'global.run_daemon'
                            If i take that part, then i get another error when trying to use Continuous mode, another thing, how do i get the values to appear on the WHB04B-6?
                            Error: Failed to read code from macro pendant-continuous-run.g: Failed to evaluate "{exists(param.A)} && {exists(param.F)} && {exists(param.D)}": unknown value 'param.A'
                            Error: Failed to read code from macro pendant-continuous-loop.g: Failed to evaluate "global.pendant_continuous_ttl>0": unknown value 'global.pendant_conti'
                            • hurzhurzundefined
                              hurzhurz @ajmartins
                              @ajmartins The errors look like these two lines might be missing in your config.g, can you check that?:
                              M98 P"pendant-continuous-init.g"
                              global run_daemon=true
                              Or you can run them manually in the console once for testing.
                              And about your other question, doesn't your WHB04B-6 show the coordinates on the LCD?
                              It should work automatically...
                                ajmartins
                                Yes, i added both lines to config.g, i tried manully running and i get the other error i sent.
                                If i run M98 P"pendant-continuous-init.g", the system just stalls and i need to reset the board.
                                Should i put both lines in the end of config file?
                                ajmartinsundefined 1 Reply Last reply Reply Quote 0
                                  ajmartins @ajmartins
                                  @ajmartins Well more tests, added both lines to the end of config file, and now at least i dont get any errors when restarting the board.
                                  But when trying to make a continuous move, i still get the error:
                                  • hurzhurzundefined
                                    hurzhurz @ajmartins
                                    @ajmartins Which version of RepRapFirmware have you installed?
                                    I'm wondering if the macro parameters or the exists() function for them is "too new".
                                    On my machine I'm running 3.4.6. And from the changelog I guess that at least 3.3 could be required.
                                      ajmartins @hurzhurz
                                      @hurzhurz Im running the same, 3.4.6.
                                      • hurzhurzundefined
                                        hurzhurz @ajmartins
                                        @ajmartins It looks like the Duet Software Framework (DSF) is version 3.4.6 (you are using the Duet together with a Raspberry Pi, I guess?), but the Firmware on the Duet is just 3.1.1
                                          ajmartins @hurzhurz
                                          @hurzhurz Yes, you are right 😕 since i dowloaded the PI image yesterday i suposed that was already with last version.
                                          I will try again.
                                          Thanks
                                            ajmartins
                                            Its now working perfectly 😉
                                            Thanks
