3.5.0rc1: Input shaping causes layer shifts!?
Beta Firmware
19
196
15.3k
    T3P3Tony administrators @NeoDue
    @NeoDue
    Github issue:
    https://github.com/Duet3D/RepRapFirmware/issues/945
    T3P3 created this issue 15 Jan 2024, 11:54 in Duet3D/RepRapFirmware
    closed IS triggered Layer shifts in 3.5rc1+ #945
      dc42 administrators @NeoDue
      @NeoDue and @skrotz please can you both try the firmware at https://www.dropbox.com/scl/fo/8mwsfwo61tacbyxsu39j9/h?rlkey=zwyd8luhpj7hnanldm4rzm5om&dl=0. If you encounter any layer shifts, then to help me track down the cause please report the following:
      • A M122 report taken after layer shifts have occurred. Don't run M122 more than once unless further layer shifts occur, because each time M122 is run it clears the data it reports, and I want the data that may relate to a layer shift.
      • Your config.g file
      • What M593 input shaping command you were using, if it isn't in the config.g file
      • What height the layer shift(s) occurred at
      • A link to the GCode file you were printing.
      Also please verify that you don't get layer shifts if you do the same print with input shaping disabled (i.e. M593 P"none").
      undefined undefined 5 Replies Last reply 15 Jan 2024, 22:55 Reply Quote 0
        NeoDue @dc42
        @dc42 thanks! I might only be able to do that the coming weekend, but I definitely will as soon as I can!
          vaike_peeter @dc42
          Made test print with your rc2+ firmware. Layer shifted at 16,05mm
          I didn't get M122 directly after layer shift, I did it when I disovered it.
          M122 toolhead
          M122 B121
          Diagnostics for board 121:
          Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51)
          Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
          All averaging filters OK
          Never used RAM 2672, free system stack 89 words
          Tasks: Move(3,nWait,1.6%,71) HEAT(2,nWait,6.4%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.6%,77) CanClock(5,nWait,0.4%,67) ACCEL(3,nWait,0.0%,17) TMC(2,nWait,61.9%,57) MAIN(1,running,86.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,92.7%,114), total 249.8%
          Last reset 21:44:27 ago, cause: software
          Last software reset time unknown, reason: OutOfMemory, available RAM 16088, slot 0
          Software reset code 0x01c0 ICSR 0x00000000 SP 0x20002770 Task MAIN Freestk 784 ok
          Stack: 00004000 00005e8b 00004000 000041cf a5a5a5a5 00004000 a5a5a5a5 a5a5a5a5 a5a5a5a5 0001d199 a5a5a5a5 0001d1b5 a5a5a5a5 00005a4f a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
          Driver 0: pos 0, 617.6 steps/mm, ok, SG min 0, read errors 2, write errors 1, ifcnt 144, reads 54569, writes 16, timeouts 140, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 15440450
          Moves scheduled 261208, completed 261207, in progress 1, hiccups 4282, segs 40, step errors 0, maxLate 1 maxPrep 564, maxOverdue 5374, maxInc 2158, mcErrs 0, gcmErrs 0, ebfmin -1.00 max 1.00
          Peak sync jitter -6/8, peak Rx sync delay 260, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 24.2, current 24.4, max 29.8
          MCU temperature: min 28.9C, current 75.1C, max 75.2C
          Last sensors broadcast 0x00001002 found 2 241 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 1568794, send timeouts 6, received 969293, lost 0, errs 34187, boc 0, free buffers 18, min 17, error reg 110000
          Last cancelled message type 4525 dest 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 420, adv 35575/74660
          Accelerometer: LIS3DH, status: 00
          Inductive sensor: not found
          I2C bus errors 0, naks 6, contentions 0, other errors 0
          M122 Mainboard
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2+ (2024-01-15 11:56:10) running on Duet 3 Mini5plus Ethernet (standalone mode)
          Board ID: KHLQ8-GU8LU-F65J0-409N2-1313Z-H6T1G
          Used output buffers: 8 of 40 (32 max)
          Static ram: 103168
          Dynamic ram: 116132 of which 16 recycled
          Never used RAM 18404, free system stack 128 words
          Tasks: NETWORK(1,ready,23.0%,173) ETHERNET(5,nWait 7,0.2%,569) HEAT(3,nWait 6,0.7%,326) Move(4,nWait 6,6.8%,241) CanReceiv(6,nWait 1,1.0%,774) CanSender(5,nWait 7,0.2%,327) CanClock(7,delaying,0.1%,348) TMC(4,nWait 6,15.4%,66) MAIN(1,running,35.8%,667) IDLE(0,ready,0.0%,30) AIN(4,delaying,16.6%,256), total 100.0%
          Owned mutexes:
          Last reset 21:45:00 ago, cause: software
          Last software reset at 2024-01-15 21:55, reason: User, Gcodes spinning, available RAM 27976, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 78301312, completed 78301310, timed out 0, errs 0
          MCU temperature: min 17.7, current 33.9, max 34.4
          Supply voltage: min 23.7, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/1296/1220, gc cycles 0
          Events: 1 queued, 1 completed
          Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 57358, writes 25, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 57358, writes 25, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 57352, writes 30, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 38, reads 57352, writes 30, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 37, reads 57353, writes 30, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: not present
          Driver 6: not present
          Date/time: 2024-01-16 19:51:08
          Slowest loop: 258.21ms; fastest: 0.11ms
          === Storage ===
          Free file entries: 18
          SD card longest read time 4.8ms, write time 10.9ms, max retries 0
          DMs created 83, segments created 35, maxWait 68167851ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 35 ticks, enabled
          Moves shaped first try 9805, on retry 12276, too short 53284, wrong shape 153332, maybepossible 8084
          === DDARing 0 ===
          Scheduled moves 281191, completed 281158, hiccups 0, stepErrors 0, LaErrors 211, Underruns [0, 0, 5], CDDA state 3
          === DDARing 1 ===
          Bed heaters 0 -1 -1 -1, chamber heaters 9 -1 -1 -1, ordering errs 0
          Heater 0 is on, I-accum = 0.5
          Heater 1 is on, I-accum = 0.0
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is doing "G1 X220.349 Y71.367 E.00382" in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          File2 is doing "M0" in state(s) 0, sync state 1
          Queue2 is idle in state(s) 0
          Q0 segments left 1, axes/extruders owned 0x0000807
          Code queue 0 is empty
          Code queue 1 is empty
          === CAN ===
          Messages queued 970855, received 1569669, lost 0, errs 1, boc 0
          Longest wait 5ms for reply type 4014, peak Tx sync delay 420, free buffers 26 (min 24), ts 391502/391501/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 230.49ms; fastest: 0.03ms
          Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          = Ethernet =
          Interface state: active
          Error counts: 0 0 9158 0 0 0
          Socket states: 5 2 2 2 2 2 0 0
          config.g
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.5)
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Nov 23 2023 20:11:54 GMT+0200 (Eastern European Standard Time)
          M550 P"VT1011" ; set printer name
          M669 K1 ; select CoreXY mode
          ; Wait a moment for the CAN expansion boards to start
          G4 S2
          M552 P192.168.90.200 S1 ; enable network and set IP address
          M553 P255.255.255.0 ; set netmask
          M554 P192.168.90.1 ; set gateway
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S0 ; disable Telnet
          ; --- Drive map ---
          ; (While looking at the printer top down)
          ; 0.0-----0.1
          ; | 0.2 |
          ; |0.3|0.4|
          ; Front
          ; Drives for X & Y
          M569 P0.0 S1 D2 ; physical drive 0.0 goes forwards
          M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards
          ; Drives for Z
          M569 P0.2 S0 D3 ; physical drive 0.2 goes backwards Stealthchop | Z1
          M569 P0.3 S0 D3 ; physical drive 0.3 goes backwards Stealthchop | Z0
          M569 P0.4 S0 D3 ; physical drive 0.4 goes backwards Stealthchop | Z2
          ; Drive for Extruder
          M569 P121.0 S0 D2 ; physical drive 121.0 goes backwards
          ; Motor mapping and steps per mm
          M584 X0.0 Y0.1 Z0.3:0.2:0.4 E121.0 ; set drive mapping
          M92 X160 Y160 Z800 ; set steps per mm
          M92 E617.6470588 ; galileo 2 steps per mm
          ; Drive currents
          M906 X1700 Y1700 Z1000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 X Y Z E0 S30 ; Set idle timeout
          ; Axis accelerations and speeds
          M566 X500 Y500 Z120 E300 P1 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z900 E7200 ; set maximum speeds (mm/min)
          M201 X8000 Y8000.00 Z350 E2000 ; set accelerations (mm/s^2)
          ; Reduced accelerations
          ;M201.1 X500 Y500 Z80 E500 ; Set reduced acceleration for special move types (mm/s²)
          ; Printing and travel accelerations
          M204 P5000 T7000 ; Set printing acceleration and travel accelerations (mm/s²)
          M208 X0 Y0 Z0 S1 ; set axis minimal
          M208 X300 Y305 Z240 S0 ; set axis maximal
          M574 X2 S1 P"121.io1.in" ; configure sensorless endstop for high end on X
          M574 Y2 S1 P"io6.in" ; configure sensorless endstop for high end on Y
          ; Klicky
          M558 P8 C"^121.io2.in" T18000 F600:180 H2 A10 S0.01 ; set Z probe type to KLICKY and the dive height + speeds
          G31 P500 X0 Y28 Z4.80 ; 5,4 set Z probe trigger value, offset and trigger height(Z_offset - bigger number bed closer to nozzle)
          ; Bed leveling
          M671 X-50:150:350 Y18:348:18 S5 ; front left, back, front right
          M557 X15:285 Y30:285 P5 ; define grid for mesh bed compensation, bed mesh distance 83mm to get 4x4 square
          ; Accelerometer
          M955 P121.0 I10 ; Configure accelerometer
          M593 P"mzv" F25 S0.01 L0.15 ; disabled 3.5.0rc1 has layer shift issues when IS enabled
          ; Bed heater
          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Bed" ; 4138 configure sensor 0 as thermistor on pin temp0
          M143 H0 A2 C0 S120 ; Make sure bed heater stays below 120C
          M143 H0 A1 C0 S125 ; Make sure bed heater shuts down at 125C
          ; Hodend heater
          M308 S1 P"121.temp0" Y"pt1000" A"Hotend" ; configure sensor 1 as thermistor on pin 121.temp0
          M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
          M143 H1 S350 ; set temperature limit for heater 1 to 350C
          ; Chamber heater
          M308 S9 P"temp1" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8 ; Chamber thermistor conf - ATC Semitec 104NT-4-R025H42G
          M950 H9 C"io5.in" Q1 T9 ; dummy port used
          M307 H9 B0 S1.00
          M141 H9 ; fake chamber heater for reporting in DWC
          M143 H9 P0 S40 A2
          M143 H9 P1 S60
          ; Duet5+ mcu temp
          M308 S3 Y"mcu-temp" A"MCU" ; Configure sensor 2 as MCU temperature
          M912 P0 S-2.9 ; MCU temp calibration parameters
          ; toolhead temp
          M308 S12 Y"mcu-temp" P"121.dummy" A"1LC MCU"
          ;Part cooling
          M950 F0 C"121.out1" ; create fan 0 on pin 121.out1 and set its frequency
          M106 P0 S0 H-1 C"Part Cooling" ; set fan 0 value. Thermostatic control is turned off
          ;Hotend fan
          M950 F1 C"121.out2" ; create fan 1 on pin 121.out2 and set its frequency
          M106 P1 S1 H1 T45 C"Hotend Fan" ; set fan 1 value. Thermostatic control is turned on
          ; Bed fan
          M950 F2 C"out3" ; create fan 2 on pin out3 and set its frequency
          M106 P2 C"BEDF_12V" S0 H-1 ; set fan 2 value. Thermostatic control is turned on
          ; Exhaust fan
          M950 F3 C"out6" ; create fan 3 on pin out6 and set its frequency
          M106 P3 C"EXHAUSTF" S0 B0.1 H9 T45 ; set fan 3 value. Thermostatic control is turned on
          ; Nevermore filter
          M950 F4 C"out5" ; create fan 4 on pin out5 and set its frequency
          M106 P4 C"FILTER" S0 B0.1 H0 T90 ; set fan 4 value. Thermostatic control is turned on
          M563 P0 S"Mosquito Magnum" D0 H1 F0 ; define tool 0
          M950 P0 C"out1" ; Create output Port0 attached to out1 connector for LED lights
          T0 ; select first tool
          Print file 3DBenchy-Voron-Trident-300-0.4-nozzle-1011-ABS-Orange-Polymaker.gcode
          Active IS graph IS
          undefined undefined 2 Replies Last reply 16 Jan 2024, 19:45 Reply Quote 0
            oliof @vaike_peeter
            @vaike_peeter do you have a spec sheet of your stepper drivers at hand?
            undefined 1 Reply Last reply 16 Jan 2024, 20:39 Reply Quote 0
              vaike_peeter @oliof
              @oliof
              Z-motors - LDO-42STH40-1684L300E
              A and B(x,y) motors - LDO-42STH48-2004MAH
              I already checked current if you think that.
              undefined 1 Reply Last reply 17 Jan 2024, 05:42 Reply Quote 0
                oliof @vaike_peeter
                @vaike_peeter with your .9 degree steppers you hit like 48kHz step rate per axis on CoreXY with 16x microstepping. You should get fine prints dropping down to 8x microstepping and giving more headroom for additional computation like IS.
                There are some other considerations like maximum RPM and torque that you may be hitting with the 2004s. Check the back emf calculator and the TDS of your steppers for the physical stepper limits too. https://www.reprapfirmware.org/emf.html
                undefined 2 Replies Last reply 17 Jan 2024, 07:23 Reply Quote 0
                  vaike_peeter @oliof
                  @oliof
                  I will test this when I get back home👍
                    benecito
                    FYI had something similar happen this night on a machine running just closed loop motors.
                    Just installed the RC2+ and will see if it happens again.
                    Already sent this to @dc42 directly as well.
                      NeoDue @dc42
                      @dc42 just to make sure since I have no experience yet with the test firmware versions you provide: On my 6HC with no further addon electronics than the PanelDue (a clone, as already noted somewhere here in the forum, since the original PanelDue has too large footprint for this printer - I would have used the one I already own otherwise) and the Wifi module I just need to upload and install Duet3Firmware_MB6HC.bin - correct?
                      undefined 1 Reply Last reply 18 Jan 2024, 12:36 Reply Quote 0
                        droftarts administrators @NeoDue
                        @NeoDue said in 3.5.0rc1: Input shaping causes layer shifts!?:
                        Correct!
                        undefined 1 Reply Last reply 18 Jan 2024, 23:33 Reply Quote 0
                          vaike_peeter @oliof
                          @oliof That was really good hint. My test print came out without layer shift. Will continue testing but seems promising. Thank you.
                          Now X and Y motors are configured 8 microsteping with 80 steps per mm.
                            NeoDue @droftarts
                            @droftarts thanks! But I fear I need to report that did not work as intended at all - the last information I got from the DWC was that it was updating the board firmware... and now I am having a dead printer. I fear I need to work my way to the Duet in the printer and do a restore via USB this weekend instead of doing the test. Now where was the website explaining that process, it has been ages since I needed that...
                            undefined 1 Reply Last reply 18 Jan 2024, 23:40 Reply Quote 0
                              @NeoDue Oh dear, sorry! Maybe your iap file was out of date?
                              USB firmware flashing: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware
                              undefined 1 Reply Last reply 18 Jan 2024, 23:43 Reply Quote 0
                                NeoDue @droftarts
                                @droftarts The one that was in the Duet was suitable to update from 3.5.0 beta4 to rc1 and then to rc2. Do I need another one for the test version? There is none in the dropbox folder...
                                undefined 1 Reply Last reply 18 Jan 2024, 23:50 Reply Quote 0
                                  @NeoDue No, that was probably the latest. Looks like it hasn't been updated for a couple of years: https://github.com/Duet3D/DuetIAP
                                  Sorry, not sure why your update failed. Is the DIAG light glowing? See https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond for troubleshooting, just in case it is recoverable.
                                  undefined 2 Replies Last reply 18 Jan 2024, 23:53 Reply Quote 0
                                    NeoDue @droftarts
                                    @droftarts Thanks for the links! I will check that. But for now there is a little mechanical work needed - the Snapmaker J1 has its electronics compartment in the base, and I need to remove the housing windows and screw up the z axis before I can unscrew and lift the metal plate covering it... quite some screws before I can see the Duet again 😉
                                      NeoDue @droftarts
                                      @droftarts Edit: I just managed to catch a glimpse through an unused former USB port opening. If I saw correctly from the reflection, the four voltage LEDs are active, but that's about it. But as noted above, I need to take open the compartment to get a clear look.
                                        dc42 administrators @vaike_peeter
                                        @vaike_peeter thanks for the data. How confident are you that if you disable input shaping, you can do the same print at the same speed without getting any layer shifting?
                                        undefined 2 Replies Last reply 19 Jan 2024, 15:13 Reply Quote 0
                                          vaike_peeter @dc42
                                          @dc42 I will do teat print with IS disabled and then post results. I modified my config for x and y steppers and changed print external perimeter accel to 2000 because of ringing. Defaul accel is 5k. I’m off my printer right now.
                                          33 out of 196
