    cannot connect to duet 2 Wi-Fi or board
    5.5k
      Sorry for the bad info. I should probably hold off posting when on the cold meds. 😞
      • Blunt2007undefined
        Blunt2007 @droftarts
        @droftarts 17046641141096627655429811255665.jpg for my dual extruder can you check the wiring on this for the drivers I got two question marks . Can you help me with the wiring upper left of the picture in my writing lower right is the motherboard Hope you can help me to get my drivers up and running 2209 and the pin has been cut for you UART
          droftarts administrators @Blunt2007
          @Blunt2007 Sorry, I can't advise on how to wire this combination of boards. However, see this thread https://forum.duet3d.com/topic/34500/using-expansion-mini-2-on-duet-2-ethernet for someone who has done the same thing.
          Blunt2007undefined 1 Reply Last reply Reply Quote 0
            @droftarts okay thanks still working on it meanwhile I'm trying to get the 3D printer working turn on board and tried heating up bed and got this fail statement what's causing this can you help17047507529874951163259665302310.jpg still having problems trying to connect to it with Wi-Fi and it won't connect try using USB not working still having the same problems over and over
            With the Wi-Fi
            oliofundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            • oliofundefined
              oliof @Blunt2007
              @Blunt2007 for the bed heater error, you need to PID tune the bed to get rid of this error. Run M303 H0 S70 and save the PID tune values; see https://docs.duet3d.com/User_manual/Reference/Gcodes#m307-set-or-report-heating-process-parameters
                @Blunt2007 said in cannot connect to duet 2 Wi-Fi or board:
                With the Wi-Fi
                Okay, let's get this board exchanged under warranty. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                  @droftarts I got my new board and tried connecting with USB and it would not connect but when I push the reset button it connected but I but I'm not able to connect by Wi-Fi so I upload it (runonce.g) to the system file and I was able to connect to Wi-Fi and it comes up with my duet is it possible that I have the bog rate set wrong I have it set at 9600 can you tell me what you guys set the bug rate to by the factory maybe that's why I cannot connect by USB
                    @Blunt2007 Glad you got a new board, sorry you're still having problems.
                    Are you using YAT to try and connect, or something else? 9600 baud rate should be fine, it's what I use, see second step here https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-3-connect-to-duet
                    9600 baud (bits per second), 8 data bits, Parity none, Stop bits 1.
                    Is the WiFi working better this time? Does it stays connected, and reconnects, if you turn the Duet off and on?
                      @droftarts All my settings are correct and I still cannot connect USB to pontephase or yat. So far I'm able to to connect to the Wi-Fi hopefully sometime soon I'm going to upload a new profile to the new board I'll let you know if I lose Wi-Fi or not
                        Do you have another computer to try with?
                          Blunt2007 @Phaedrux
                          @Phaedrux Yes I tried it with another computer and I still couldn't connect by USB using yat or pronter face
                            @Blunt2007 One more thing to try; do you have a USB hub, either powered or not powered? If so, try connecting through that.
                            At least the WiFi is working on this one!
                              @droftarts I do not have a hub and I uploaded a profile to the board and it's disconnecting from Wi-Fi and then reconnecting and then disconnecting and then reconnecting and disconnecting where before I loaded the profile it wasn't doing that it was staying on Wi-Fi. And not everything is correct such as my fan for my hot end is not coming on and the printer is moving real real real real real slow do and when I load a model into the printer now when that has worked before that is even going even slower. On the tuning videos that I've been watching they use USB to type in code to be able to change our parameters by g-code My USB is not working with the printer what do you suggest
                                @Blunt2007 Okay, I think your problems are:
                                • WiFi disconnecting and reconnecting all the time
                                • Fan not coming on
                                • Printer moving slow
                                • Entering Gcode commands
                                • Still can't connect via USB
                                I'm going to need to see a full M122 output, as the Network/WiFi diagnostics are at the end. It could be one of a number of reasons, like poor WiFi signal, congested WiFi channel, aerial not connected, router band switching... there's lots of reasons. If you are not having to set the SSID and password each time with M587, then it is probably solvable.
                                When you can connect via DWC, click on the 'Console' menu option, and type M122 where it says 'Send code...' in the middle of the screen. You should get a response in the area below. Copy and paste that into your reply.
                                Also see this troubleshooting section: https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
                                Fan not coming on
                                This could be configuration, or wiring. Did it work before? Is it the hot end cooling fan or the part cooling fan? Post your config.g. Do this by going to the the System menu in DWC, right-clicking on config.g and either 'Edit' or 'Download' File. If you edit, copy and paste the contents of config.g into your reply. If you download it, you can drag and drop the file into your reply.
                                To check the wiring, you could plug it into the 'always on' fan header (see the wiring diagram here). If it works, great. If it doesn't work, check the fan fuse, which is the 1A blade fuse on the board.
                                Printer moving slow
                                If you've posted your config.g (see above), we can see what speeds you are using; these may just be too low. Slicing software has a bad habit of changing your settings. Open the Gcode file (in a text editor) and check the first 50 lines, and see if it sets any Gcodes for speed and acceleration. Look for any line that starts with Gcodes M201, M203, M566 or M204. If you find them, post that section of the Gcode, along with what slicer software you are using.
                                I'd fix the other problems first, particularly the 'moving slow' one. When you want to send commands, you can send them in DWC from the 'Console', like how you sent M122 for the WiFi problem. It does that same thing as sending them over USB.
                                I really don't know why this isn't connecting. Have you tried other USB leads? Many USB leads are just for charging, and don't have the wires inside for carrying data, so you may have to try a few. Look for cables that are a bit fatter, they may have 4 wires rather than 2. Otherwise, there's very little difference between them, just try all the USB cables you have!
                                Blunt2007undefined 2 Replies Last reply Reply Quote 0
                                  @droftarts
                                  1/23/2024, 8:52:22 AM	M122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.2 (2023-12-14 10:30:41) running on Duet WiFi 1.02 or later
                                  Board ID: 0JD0M-9P6B2-NJ4S4-6JTDG-3S46L-1V0YM
                                  Used output buffers: 1 of 26 (16 max)
                                  Static ram: 23084
                                  Dynamic ram: 74980 of which 12 recycled
                                  Never used RAM 15068, free system stack 170 words
                                  Tasks: NETWORK(1,ready,14.4%,221) HEAT(3,nWait,0.1%,328) Move(4,nWait,0.0%,363) MAIN(1,running,85.6%,743) IDLE(0,ready,0.0%,29), total 100.0%
                                  Owned mutexes: WiFi(NETWORK)
                                  Last reset 01:10:55 ago, cause: power up
                                  Last software reset at 2024-01-22 16:59, reason: User, Gcodes spinning, available RAM 14972, slot 1
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  MCU temperature: min 14.2, current 24.8, max 25.3
                                  Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                  Events: 0 queued, 0 completed
                                  Driver 0: standstill, SG min n/a
                                  Driver 1: standstill, SG min n/a
                                  Driver 2: standstill, SG min n/a
                                  Driver 3: standstill, SG min n/a
                                  Driver 4: standstill, SG min n/a
                                  Driver 5:
                                  Driver 6:
                                  Driver 7:
                                  Driver 8:
                                  Driver 9:
                                  Driver 10:
                                  Driver 11:
                                  Date/time: 2024-01-23 08:52:21
                                  Slowest loop: 10.88ms; fastest: 0.20ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 9.5ms, write time 0.0ms, max retries 0
                                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
                                  no step interrupt scheduled
                                  Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                  === DDARing 0 ===
                                  Heater 1 is on, I-accum = 0.0
                                  Movement locks held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Q0 segments left 0
                                  Code queue 0 is empty
                                  === Network ===
                                  Slowest loop: 15.57ms; fastest: 0.00ms
                                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  HTTP sessions: 1 of 8
                                  === WiFi ===
                                  Interface state: active
                                  Module is connected to access point
                                  Failed messages: pending 0, notrdy 0, noresp 0
                                  Firmware version 1.26
                                  MAC address bc:ff:4d:e8:23:dc
                                  Module reset reason: Power up, Vcc 3.40, flash size 2097152, free heap 27104
                                  WiFi IP address 192.168.1.21
                                  Signal strength -32dBm, channel 0, mode 802.11n, reconnections 0
                                  Clock register 00002002
                                  1/23/2024, 8:51:55 AM	Connected to 192.168.1.21
                                    @droftarts
                                    ; Configuration file for Duet WiFi (firmware version 3.3)
                                    ; generated by RepRapFirmware Configuration Tool v3.4.0 on Mon Jan 01 2024 15:36:02 GMT-0600 (Central Standard Time)
                                    M575 P1 S1 B57600                              ; enable support for PanelDue
                                    G90                                            ; send absolute coordinates...
                                    M83                                            ; ...but relative extruder moves
                                    M550 P"1 Ender 5 plus"                         ; set printer name
                                    M552 S1                                        ; enable network
                                    M586 P0 S1                                     ; enable HTTP
                                    M586 P1 S0                                     ; disable FTP
                                    M586 P2 S0                                     ; disable Telnet
                                    M569 P0 S1                                     ; physical drive 0 goes forwards
                                    M569 P1 S1                                     ; physical drive 1 goes forwards
                                    M569 P2 S1                                     ; physical drive 2 goes forwards
                                    M569 P3 S1                                     ; physical drive 3 goes forwards
                                    M584 X0 Y1 Z2 E3                               ; set drive mapping
                                    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                                    M92 X80.00 Y80.00 Z800.00 E130.00             ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 E150.00           ; set maximum instantaneous speed changes (mm/min)
                                    M203 X3000.00 Y3000.00 Z3000.00 E3000.00      ; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                                    M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30                                        ; Set idle timeout
                                    M208 X0 Y0 Z0 S1                               ; set axis minima
                                    M208 X350 Y350 Z400 S0                         ; set axis maxima
                                    M574 X2 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                                    M574 Y2 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                                    M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
                                    M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                                    M558 P9 C"^zprobe.in" H5 F120 T12000           ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P500 X0 Y0 Z2.51                            ; set Z probe trigger value, offset and trigger height
                                    M557 X15:215 Y15:195 S20                       ; define mesh grid
                                    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                                    M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                                    M140 H0                                        ; map heated bed to heater 0
                                    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                                    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                    M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S450                                   ; set temperature limit for heater 1 to 450C
                                    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                    M106 P0 S1 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                                    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                    M106 P1 S1 H-1                               ; set fan 1 value. Thermostatic control is turned on
                                    M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                                    M106 P2 S1 H1 T45                              ; set fan 2 value. Thermostatic control is turned on
                                    M563 P0 D0 H1 F0                               ; define tool 0
                                    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                    M501                                           ; load saved parameters from non-volatile memory
                                    T0                                             ; select first tool
                                      @Blunt2007 For your WiFi problems:
                                      === WiFi ===
                                      This generally looks fine. -32dBm is a good, strong signal. Does your Duet have an external aerial?
                                      A possible problem is that it is set to channel 0; I think this is reporting incorrectly (there is no channel 0, only 1 to 12) as you are on a slightly older version of the WiFi firmware, 1.26.
                                      As you are using the latest RRF version 3.5.0-rc.2, you could update the WiFi version. From https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-rc.2 upload the "DuetWiFiServer.bin" file. You will need to input your SSID and password again, using the "runonce.g" script.
                                      Also make sure you are using the same version of DWC as firmware. Check by looking at the Setting > General and Machine-specific tabs. If it is not the same, upload the "DuetWebControl-SD.zip" file from the firmware release.
                                      Then send M122 again, and see what channel you are connected on. If you don't have an external aerial that plug in, the following might be the cause of disconnections:
                                      Particularly if using channel 1, change the router WiFi channel. Duets with onboard WiFi antennas may be more susceptible to interference from the Duet itself at this frequency. Try channel 6 or 11.
                                        @droftarts every time I try loading a m 420 bad leveling it kicks me off. And then I got to restart my browser to access board again and then when I try entering m420 bed leveling it kicks me off again I'm trying to get this on there because the screen is coming up with a m 420 does not exist. I got the fan working that was wires were reversed fan is working now now I'm trying to get my BL touch to work
                                        oliofundefined Blunt2007undefined 3 Replies Last reply Reply Quote 0
                                        • oliofundefined
                                          oliof @Blunt2007
                                          M420 is not supported in RepRapFirmware. Are you maybe running G29 or G32?
                                            Blunt2007 @Blunt2007
                                            @Blunt2007
