    Can I use PID tuning with SSR on heater bed?
    • claustroundefined
      claustro
      Hi guys.
      I have a 220 v heated bed. Safety features are grounded lines, temp fuse, home assistant monitoring temperature and cut line if needed.
      I am using bang bang regulation but I would like to switch to pid because teh 1 C° fluctuations make some banding on the print.
      Can I safely use pid regulation on an SSR MOSFET
      Mine is a crydom d2425
      Thank you
      jens55undefined OwenDundefined infiniteloopundefined 3 Replies Last reply Reply Quote 0
      • jens55undefined
        jens55 @claustro
        @claustro , yes!
        • OwenDundefined
          OwenD @claustro
          @claustro
          No issues.
          See here for suggestions including frequency etc
          https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_bed#bed-heater-driven-using-a-solid-state-relay
          • infiniteloopundefined
            infiniteloop @claustro
            @claustro
            Sure you can use PID, but I doubt its effect on the banding you encounter. Can you post a sample image of that?
            Note of caution: try to print some kind of clamp to cover the contacts 1 and 2 of the SSR, the screw heads carry high voltage.
            claustroundefined 1 Reply Last reply Reply Quote 1
            • claustroundefined
              claustro @infiniteloop
              @infiniteloop I am in the process of reducing all possible bending sources in my print, and then I came across this article. So I decided to get rid of this variable
              https://www.cnckitchen.com/blog/bang-bang-or-pid-bed-temperature-control#:~:text=If the parameter B is,while%2C it's bang-bang.
              Thank you for your suggestion .
                @claustro Thank you for the link. I couldn’t imagine the impact on layer height of the effect. Please keep us informed if PID helps.
