    Bloob on print
    • claustroundefined
      claustro
      Hi guys, lately my printer has started to print badly.
      I tried to print the same part with the same setting with 2 different filaments. All the print has the same defect in the perfect same place, can you help me identify the problem?
      Thank you
      Andrea
      sneakyferretundefined oliofundefined cosmowaveundefined 3 Replies Last reply Reply Quote 1
      • sneakyferretundefined
        sneakyferret @claustro
        @claustro not sure if applicable but a YouTuber was having the exact same problem with a different printing software and found that it was the resume after power loss feature causing the issue. Maybe give this a look? Video here about their problem
        oliofundefined 1 Reply Last reply Reply Quote 1
        • oliofundefined
          oliof @sneakyferret
          @sneakyferret that's not applicable to RepRapFirmware. Marlin needs to write the recovery info continuously because many boards don't have voltage monitoring. Duet boards have voltage monitoring and recovery info will only be written on a voltage drop.
          • oliofundefined
            oliof @claustro
            @claustro looks like this happens on layer changes. We would need to know more about the machine (photos would be good), and see your config.g as well as a sample gcode file (or atl east like the first 100 lines).
            • cosmowaveundefined
              cosmowave @claustro
              @claustro
              Do you use retract ? Please posr the settings. Is it a direct drive or bowden?
              Mankati FSXT+, DeltaTowerV2, E3D MS/TC
