    Tips for autotuning a very large heated chamber?
    780
    • p8blrundefined
      p8blr @droftarts
      @droftarts I'll have to get back to you on the compiling errors, but yes we're using that page as a guide.
      On a different note, I attempted to autotune to 60C today, it hit that temperature very quickly, but got stuck in phase 3 and DWC stopped working. Refreshing the page gets to the "connecting" page but that's it. I've tried different phones/PCs but all get stuck at connecting. This has happened a lot before, but I figured it was a normal bug, but now I've noticed that it's correlating with me combining the heaters. It messes it up to the point that when I reboot the printer, that it won't connect again until I pull out the sd card, modify config.g and then start it up again.
      Both versions of my config.g are over 2000 characters so I'm just attaching them
      workingconfig.g
      brokenconfig.g
      DriveSetup.g
      startup.g
      daemon.g
      I should also note that I'm running a raspberry pi 4 in sbc mode with a fast 32gb samsung evo card, and I'm on release candidate 2 (same issue with 1)
      • chrishammundefined
        chrishamm administrators @p8blr
        @p8blr Can you press F12 or open the dev tools in your browser session and check for potential errors in the console? If nothing shows up there, can you please check the duetcontrolserver log? See the section about journalctl in https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#increasing-log-level.
        It doesn't look like DSF loses connection to the Duet so I suspect something else is going on.
        Duet software engineer
        p8blrundefined 2 Replies Last reply Reply Quote 0
        • p8blrundefined
          p8blr @chrishamm
          @chrishamm I'll have to put that code back and run a PID autotune again, I'll get back to you with an update.
          • p8blrundefined
            p8blr @chrishamm
            @chrishamm I changed the settings and restarted and got the error, I didn't even have to autotune.
            journalctl -u duetcontrolserver -f
            Also I should mention that putty freezes up very frequently when this error happens.
              @p8blr If PuTTY freezes as well that probably means the Pi stops working at some point. In that case I'd rather check the electronics again. Are you operating the Pi from the Duet's 5V rail? If yes, consider removing the 5V -> SBC jumper and hook up the Pi to an external 5V PSU.
              p8blrundefined 1 Reply Last reply Reply Quote 0
              • p8blrundefined
                p8blr @chrishamm
                @chrishamm I'm powering the pi via a usb C supply. My suspicion is that because the freezing happens at a regular pace, perhaps it has to do with the daemon.g. Is that possible?
                  @p8blr I need the full DuetControlServer log to answer that. Your excerpt didn't show anything significant.
                  • p8blrundefined
                    p8blr @chrishamm
                    @chrishamm How do I generate that?
                    chrishammundefined 2 Replies Last reply Reply Quote 0
                      @p8blr journalctl -u duetcontrolserver --no-pager -b
                        @p8blr I believe this is a duplicate of this report. Can you try out one of those DWC builds and check if it is fixed then? See here.
                        • p8blrundefined
                          p8blr @chrishamm
                          @chrishamm
                          report.txt
                          • p8blrundefined
                            p8blr @chrishamm
                            @chrishamm I can, I'll get back to you on it...
                            • p8blrundefined
                              p8blr @chrishamm
                              @chrishamm So far I'm not getting any more issues connecting to the web interface with the heaters combined now, just errors that the DWC versions don't match.
                                T3P3Tony administrators @p8blr
                                @p8blr have you refreshed page? this bites me on occasion on upgrades!
                                • p8blrundefined
                                  p8blr @T3P3Tony
                                  @T3P3Tony refreshing the page seems to work fine. I know what you mean though, sometimes before when I refreshed the page it wouldn't reconnect.
                                    @p8blr yep if DWC is upgraded the page needs to be refreshed before it's upgraded in the version you browser is displaying!
                                    • p8blrundefined p8blr referenced this topic
