    Calibration factors do not equal number of leadscrews
    801
      dc42 administrators @BDPrinters
      @BDPrinters said in Calibration factors do not equal number of leadscrews:
      Error: Number of calibration factors (0) not equal to number of leadscrews (3)
      The bed.g file you posted looks OK but perhaps it contains a hidden character.
      I have been able to make the printer calibrate each motor individually, but one motor always overshoots the calibration, making the bed noticeably not level to the gantry. This could be a different issue but I am not sure at the moment.
      That's usually caused by a mismatch between the order in which the leadscrew locations are specified in the M671 command and the order in which the Z motors are declared in M584.
      BDPrintersundefined 1 Reply Last reply Reply Quote 1
      • BDPrintersundefined
        BDPrinters @gloomyandy
        @gloomyandy I believe they do, I checked them a few times but I will verify. I did want to allow 50mm of adjustment, the bed had quite a bit of deviation (40mm roughly), and I wanted to correct it as much as i could without unplugging the motors and manually turning the z screws
          BDPrinters @dc42
          @dc42 I double checked the bed.g file for hidden characters but I do not see anything other than the text that is shown. I will recheck the order of the screw locations. Does a mismatched order typically lead to this error triggering after the first point is probed but before the second?
          BDPrintersundefined 1 Reply Last reply Reply Quote 0
            BDPrinters @BDPrinters
            @BDPrinters I have verified that the order of the leadscrew locations are correct. I got a second set of eyes hoping I overlooked this and made a mistake, but that isn't the issue unfortunately.
            Any other ideas?
            Thanks
            Tom
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @BDPrinters
              @BDPrinters
              The last G30 P2 has F550 instead of Y550
              BDPrintersundefined 1 Reply Last reply Reply Quote 3
              • gloomyandyundefined
                gloomyandy @BDPrinters
                @BDPrinters The usual way to correct large deviations is to run several iterations of the correction (search the forum and you will find scripts to do this), I really would not try to correct 50mm in one go...
                  BDPrinters @fcwilt
                  @fcwilt @fcwilt Excellent catch on that typo, I completely missed that. Unfortunately after changing it, the issue still persists
                  • fcwiltundefined
                    fcwilt @BDPrinters
                    @BDPrinters
                    I think you M671 is wrong.
                    I think the X50.8 should be the in the 2nd position based on the three G30s but perhaps they are out of order.
                      @gloomyandy I will take that into account next time I run into this issue (hopefully never but you never know).
                      Somehow it worked fine enough to be able to change my calibration settings back to where they were before, so I am happy for now about that
                        BDPrinters @fcwilt
                        @fcwilt Couple questions with this.
                        What makes you think the order could be wrong? Not trying to challenge what you are saying, I just don't see what you are seeing to come to that conclusion, some clarity on that would be welcomed.
                        In my config file, I have that specific z screw being listed third, but in the bed.g file, it is set to be the second probe of the three to be probed. Do the screws need to be probed in the same order in bed.g as they are listed in the config.g?
                        Essentially, how it is set up now, I probe 1,2 then 3,(see below) but the order in the config file would say to probe 1,3, then 2. Is this an issue?
                        Also, I have since changed the bed.g probing locations to a more exact number, the original ones were rough estimates taken with a tape measure. Do the Z screw locations and the probing locations need to be the same? My initial thought is that they do not need to be, as it is the actual location, but specific coordinates to probe for those stated screws, but I could be wrong.
                        My setup for Z screws is laid out as such
                        (0,0) Home                                     2 screw
                        1 screw
        3 screw```
                        Phaedruxundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @BDPrinters
                          No.
                          The order and position of the points probed in bed.g isn't critical, but the order of the points in M671 need to match the order of the motors in M584.
                            @BDPrinters Just to be clear the M671 locations need to be the points at which the bed actually pivots (this may or may not be the same location as the Z-screw locations, that depends on how the bed is mounted).
                              BDPrinters
                              One other thing I just noticed is that I get this error just by homing all. Maybe the issue lies there.
                              Here is my homeall.g file.
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Nov 01 2023 09:48:25 GMT-0400 (Eastern Daylight Time)
                              G1 H2 Z20 F6000          ; lift Z relative to current position
                              G1 H1 X-555 Y-555 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 H2 X5 Y5 F6000       ; go back a few mm
                              G1 H1 X-555 Y-555 F360  ; move slowly to X and Y axis endstops once more (second pass)
                              G90                     ; absolute positioning
                              G1 X15 Y15 F600        ; go to first bed probe point and home Z
                              G30 S0                  ; home Z by probing the bed
                              G1 Z5 F100             ; lift Z relative to current position
                              gloomyandyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                @BDPrinters I don't think your G30 should have the S0 option to it. Just a simple G30 should be fine.
                                  which error exactly?
                                    BDPrinters @Phaedrux
                                    @Phaedrux I get the error that calibration factors are not equal to the number of leadscrewsg28.PNG
                                      @BDPrinters Did you remove the S0 from the G30 command in your homez.g file?
                                        @gloomyandy Yes, that actually seemed to be the problem for the calibration factors not equaling the number of leadscrews. Things seem to be working fine now.
                                        Thanks to all who have given advice on this, it is much appreciated.
                                        Tom
                                        • Phaedruxundefined Phaedrux has marked this topic as solved
                                        • fcwiltundefined
                                          fcwilt @BDPrinters
                                          That seems odd since the docs for G30 without a P parameter state the having an S0 parameter is the same as not having the S0 parameter
                                          A few things come to mind:
                                          • the code for G30 S0 has a bug and it doesn't work like the documentation says it should
                                          • the documentation for G30 S30 is wrong
                                          • you changed something else at the same time which actually fixed the problem
                                          I haven't a clue what is going on.
