    OrcaSlicer 1.9.0 adds codes that breaks printer.
    Third-party software
    8
    19
    1.9k
    • Fireflyundefined
      Firefly @Firefly
      @Firefly
      OrcaSlicer180.gcode
      OrcaSlicer190.gcode
      • Exerqtorundefined
        Exerqtor
        Uhm, excuse me? 🤣
        EDIT:
        Made sence once the posts got resurrected.
        Fireflyundefined 1 Reply Last reply Reply Quote 0
        • Fireflyundefined
          Firefly @Exerqtor
          @Exerqtor
          yes found the problem, by default all these 'adds' were on, I feel it should be off by default. these codes disabled my printer and could of done damage. it's a OrcaSlicer problem.
          droftartsundefined paralepsisundefined 3 Replies Last reply Reply Quote 0
            droftarts administrators @Firefly
            @Firefly To give this thread context, do you mind if I undelete your original post, if you can't? Otherwise I'll delete the thread as it isn't helpful for others looking for the answer to the same problem.
            • paralepsisundefined
              paralepsis @Firefly
              @Firefly yes, this is default behavior when switching to RRF in PrusaSlicer also. It's a terrible default.
              Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
              • gringoundefined
                gringo
                There is a switch at the printer preferences page.
                Search the side where you can set the speed and acc limits.
                You can choose if orca slicer put them to the G_Code or not.
                I had the same Problem and it took a while to check what happened.
                  @Firefly odd that it made the printer crash, as the commands look like normal Gcodes. I’ve had the same problem with PrusaSlicer as @paralepsis mentions, but the printer just runs a bit slower rather than crashing.
                  In PrusaSlicer, go to Printer settings > machine limits and there’s a drop down box at the top. Change from ā€œemit to Gcodeā€ to one of the other choices. I tend to use ā€œUse for time estimatesā€, and have the machine limits set to how they are set in config.g, so time estimates are reasonably accurate.
                  paralepsisundefined Fireflyundefined 2 Replies Last reply Reply Quote 0
                    paralepsis @droftarts
                    @droftarts It depends on what happens to be in those boxes. I found I got unreasonable jerk/accel settings that really messed things up (some time ago, in my case with PrusaSlicer). Skipping steps all over the place, etc.
                      dc42 administrators @paralepsis
                      @paralepsis I've had it in mind for some time to add an option for RRF to ignore M201, M203 and probably also M566/M205 commands in print files. IMO print files have no business messing with machine limits.
                      Exerqtorundefined paralepsisundefined Phaedruxundefined 3 Replies Last reply Reply Quote 1
                      • Exerqtorundefined
                        Exerqtor @dc42
                        Even if "Emit limits to G-code" is ticked or not Orcaslicer still hammers in M204 & M205.
                        I guess M204 is ok, but M205 should be left out. Shouldn't it?
                        I'll open an issue on their GIT to see if this is intended or a bug, imo it shouldn't send those commands when the box is unticked.
                        dc42undefined paralepsisundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @Exerqtor
                          @Exerqtor yes M204 is fine (RRF will apply the M201 limits if they are more strict). M205 is questionable because it could exceed what the printer can do. One possibility would be to treat it like M204, i.e. treat the M566 settings as machine limits and not allow M205 to set higher limits.
                            paralepsis @dc42
                            @dc42 makes sense to me!
                              paralepsis @Exerqtor
                              @Exerqtor M204 is leveraged by PrusaSlicer for feature-based acceleration control, is useful to have around.
                                Phaedrux Moderator @dc42
                                @dc42 said in OrcaSlicer 1.9.0 adds codes that breaks printer.:
                                As long as it's optional. I use Cura and set independant speed, accel, jerk values for different move types. First layer, external perimeters, infill, travels.
                                • Fireflyundefined
                                  Firefly @droftarts
                                  @droftarts it was bad for my printer, it slammed the hot end to the right and forcing the belt to grind/skip. It moved the opposite direction it was suppose to go, very weird and not making any sense to me.
                                  • DocTruckerundefined
                                    DocTrucker @Phaedrux
                                    @Phaedrux Parsing gcode files to use M201.1 or M204 would help control acceleration on the fly. Not sure why they'd want to change max speed on the fly rather than just use feed rates?
                                    As for variable jerk/instant speed on the fly I'm not sure there is a way to deal with this with the current gcode library?
                                    As there are already slicers in the wild using these gcodes badly perhaps it may be easier to have new gcodes for use in config files that can't be overriden in build files?
                                    Edit: Whats the market share of Duet equipped/reprapfirmware compatible machines like vs Prusa compatible systems now?
                                      Phaedrux Moderator @DocTrucker
                                      @DocTrucker said in OrcaSlicer 1.9.0 adds codes that breaks printer.:
                                      I think the only gcode limit Cura changes now is M566 for jerk. Feedrate is handled by G1 and for acceleration I believe they use M204.
                                      I can't say what other slicers do. Last I checked Prusa didn't allow for on the fly jerk changes at all without post processing.
                                      • droftartsundefined droftarts referenced this topic
