    thermistor noise
    1.3k
    • jens55undefined
      jens55 @T3P3Tony
      @T3P3Tony
      Microstepping - X:16(on), Y:16(on), Z:16(on), U:4(on), E:16(on):16(on):16(on):16(on)
        T3P3Tony administrators @jens55
        @jens55 hmm ok, not sure how that can be the same and M92 be so different.
        Sorry to be a pain but please post the full config.g and confirm that the output on the console is:
        M350
        And
        m92
        Steps/mm: X: 100.000, Y: 100.000, Z: 3200.000, U: 30.578, E: 404.800:830.000:830.000:830.000
        • jens55undefined
          jens55 @T3P3Tony
          @T3P3Tony
          For ease of calculation, the microstepping was applied after the M92 command. I believe this was arranged like that in the Jubilee config files and I kept a good portion of the example files including that section.
          I can confirm the M350 and M92 outputs.
          Here is my rather verbose config.g file:
          config(2).g
          I see that I didn't update the comments on my M570 commands, please ignore
          • oliofundefined
            oliof @jens55
            @jens55 why does U only have 4x microsteps?
            T3P3Tonyundefined jens55undefined 2 Replies Last reply Reply Quote 0
              T3P3Tony administrators @oliof
              Ok so now I see. This config is made to calculate everything from first principles so hence the weird numbers you reported before:
              M350 X1 Y1 Z1 U1 E1    ; Disable microstepping to simplify calculations
              M92 E25.3:51.875:51.875:51.875
              M350 E16:16:16:16 I1   ; 16x microstepping for Extruder axes. Use interpolation.
              That together will give you:
              25.316 = 404.8
              51.875
              16=830
              Which are what is reported by M92 when its running.
              So scratch the idea that the microstepping is too high and that directly is causing hiccups.
              Can you do the following:
              First run a test print to see if you get hiccups, every time you send M122 Bnn the hiccup counter is reset. so if you send it multiple times, keep a record of each one.
              Then generate a simple set of test print jobs that moves back and forward (e.g. between X10 and X100) for enough times that you would definitely see the blips if it was a print job. (I would use a text editor to cut and past the line in blocks)
              1. Run with movement, the hot end at temperature, but no part cooling fan and no extrusion. Look for blips and also grab M122 and M122Bnn
              2. Run with the movement, no part cooling, but extrusion (you can have filament not fitted to avoid having a bit of spaghetti to clear up and wasting filament). Look for blips and hiccups and also grab M122 and M122Bnn
              3. Run test 2, but manually setting the part cooling fan to the levels used by your slicer, and looking to see if there are blips as its on and off, or from (say 80% to 100% or other combinations). Look for blips, hiccups and also grab M122 and M122Bnn
              • jens55undefined
                jens55 @oliof
                @oliof
                U is the actuator that locks the tool to the carriage. It does not need to be accurate. In fact, the actuator connects to a clutch mechanism that puts a fixed pressure on things so the position of U only needs to be sort of in the ballpark to do it's job.
                • jens55undefined
                  jens55 @T3P3Tony
                  @T3P3Tony
                  Thanks, I will do some test runs tomorrow (well later today as it is 2:30 am here)
                  • jens55undefined
                    jens55 @T3P3Tony
                    @T3P3Tony
                    Unfortunately I don't think this is going to be too helpful:
                    I did a test print and got just shy of 7000 hiccups
                    I then did the tests you asked for - none showed hiccups (well one had 1 hiccup)
                    test#1, movement, nozzle at operating temperature, no extrusion .... absolutely flat temperature curve
                    test#2, movement, nozzle at operating temperature, extrusion at 4.4 mm3/sec .... only two blips over about a 6 minute test run but still no hiccups, Frequency of blips are much less than during an actual print run.
                    test#3 - same as test #2, very rare blips and no hiccups
                    I then printed the same job I started with but with no filament loaded. I got 6586 hiccups and a bunch of blips on the temperature graph.
                    I ran test#2 again, I saw a number of blips on the temperature graph but hiccups was zero again
                    lastly, I ran test #1 again - flat temperature line, a single tiny blip which was so small that I missed it in my initial look and no hiccups
                      @jens55 thanks for doing those tests. I think it's right to focus on the cause of the hiccups and see if removing that also solves the temperature blips.
                      Can you share the shortest print file you have that shows high hiccups and temperature blips please.
                      • jens55undefined
                        jens55 @T3P3Tony
                        @T3P3Tony
                        This is a file for a knob used in woodworking fixtures. Not necessarily the shortest but it is what I used in my tests.
                        knob.gcode
                        • jens55undefined
                          jens55
                          This is a 'bump' for this thread.
                          It is no longer a 'thermistor noise' issue but one of 'tons of hiccups'.
                          If I should open a new thread I can do that but I thought I could continue this here as a lot of tests were done to narrow down the 'hiccup' issue.
                          To recap, normal/ordinary prints have thousands of hiccups and although the prints are completing correctly, I feel that it is important that the source/reason for the hiccups is tracked down.
                          I have previously reported that on occasion the printer skips a lot of steps at the end of a print as it is moving to the parking position. This is a rare issue that I can't reproduce but I would not be surprised if this somehow relates to the hiccups as well.
                            It would probably best to start a new dedicated thread. Include a recap of the issue and what you've tried to isolate it so far. Include your config and firmware details and a bit about the printer in question. Thanks.
                            • jens55undefined jens55 referenced this topic
