    Bed leveling mesh calibration not working
    Duet Web Control
    bed leveling
    1.7k
    • Mythbear74undefined
      Mythbear74
      So I did what the guide said, but for some reason, the model keeps coming up as incredibly uneven and all it does is probe the four corners. I don’t know if it’s supposed to do that or it’s supposed to do the whole board.
      • oliofundefined
        oliof @Mythbear74
        @Mythbear74 please share with us some more details about your printer (print area, nozzle location relative to probe), as well as your config.g and if you have them config-override.g, mesh.g, and bed.g .
        • soare0undefined
          soare0 @Mythbear74
          @Mythbear74
          M208 X0:524 Y0:600						  ; Xcarriage move, Ycarriage move
          ;********************other stuff
          M208 X0 Y0 Z0 S1                                   ; set axis minima
          M208 X525 Y601 Z800 S0                             ; set axis maxima
          M557 X20:520 Y50:550 S50                          ; define mesh grid
          That is, assuming that homing works right, at least. My grid is big, you need to adapt. It may be that my M208s are redundant, but you got the ideea. This is what configuration did for me, and I just modified it a little.
          gloomyandyundefined 1 Reply Last reply Reply Quote 0
          • gloomyandyundefined
            gloomyandy @soare0
            @soare0 It is really best to share the full files as requested above, makes it much easier for folks to be able to understand what is happening.
            soare0undefined 1 Reply Last reply Reply Quote 0
            • soare0undefined
              soare0 @gloomyandy
              @gloomyandy
              Indeed, but thats not me who need to share the full file dear...
                Mythbear74
                Oh ya I forgot more information
                Ender three with bltouch using a btt skr2 mainboard I think running reprap, the only thing I’ve gone and changed is the M557
                  gloomyandy @Mythbear74
                  @Mythbear74 As above please upload your config.g config-override.g, mesh.g, and bed.g files. Without them there is not much we can do to help you.
                  Mythbear74undefined 1 Reply Last reply Reply Quote 0
                    Mythbear74
                    All right, I’ll have in a bit
                      Mythbear74 @Mythbear74
                      @Mythbear74 https://drive.google.com/drive/folders/1mVh4PYC3evAnAbOAZaH302QmmA_yATmp?usp=sharing
                        Here it is
                        • soare0undefined
                          soare0 @Mythbear74
                          @Mythbear74 Why not post here, as code?, Unless is for some secret military project, but then... google drive?
                            Mythbear74
                            Yeah, like I said before I’m new and this is like my first time using the thing also, I don’t know how to find this tab when signing into this account
                            • soare0undefined
                              soare0 @Mythbear74
                              @Mythbear74 I paranoidly may think that on google drive you posted some infected files, if I would judge your answer. This... tab you speak about, will appear when you reply, at least on a normal computer.
                              Again, here is the explanation, in included image. If you still cant figure it, maybe you should make your 3d printer a gift for somebody. Dont mean to be ... mean, but just honest.
                                Mythbear74
                                So do you want me to send the code again but in this other way
                                  You can drag and drop the config.g onto the post box to upload it here. Or even copy and paste the text here.
                                    Mythbear74
                                    Here is my config.g it was having trouble sending the file
                                    ; Configuration file for SKR-E3-RRF (firmware version 3)
                                    ; generated by RepRapFirmware Configuration Tool v3.1.10+4-LPC on Tue Jan 19 2021 17:25:01 GMT+0800 (中国标准时间)
                                    M950 P1 C"SP"
                                    M42 P1 S1
                                    G90                                            ; send absolute coordinates...
                                    M83                                            ; ...but relative extruder moves
                                    M550 PAsa3DPrinter                         ; set printer name
                                    M552 S-1
                                    M552 S0
                                    M587 S"namllok" P"7856501514"
                                    M552 S1
                                    M586 P0 S1                                     ; enable HTTP
                                    M586 P1 S0                                     ; disable FTP
                                    M586 P2 S0                                     ; disable Telnet
                                    M569 P0 S0                                     ; physical drive 0 goes forwards using default driver timings
                                    M569 P1 S0                                     ; physical drive 1 goes forwards using default driver timings
                                    M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
                                    M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
                                    M584 X0 Y1 Z2 E3                               ; set drive mapping
                                    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                                    M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                                    M203 X12000.00 Y12000.00 Z600.00 E1200.00      ; set maximum speeds (mm/min)
                                    M201 X600.00 Y600.00 Z20.00 E350.00            ; set accelerations (mm/s^2)
                                    M906 X700 Y700 Z650 E750 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30                                        ; Set idle timeout
                                    M208 X230 Y230 Z250 S0                         ; set axis maxima
                                    M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                                    M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                                    ;M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
                                    ;M591 D0 P7 C"e0stop" S1  R50:130 L7.0 E10
                                    M950 S0 C"Servo0"                               ; create servo pin 0 for BLTouch
                                    M558 P9 C"^probe" H5 F800 T20000                ; set Z probe type to bltouch and the dive height + speeds
                                    M557 X10:180 Y10:180 R-1 P2:2                      ; define mesh grid
                                    G31 P500 X-40 Y10 Z4.3                           ; set Z probe trigger value, offset and trigger height
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                    M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                                    M307 B1 S1.00                                  ; disable bang-bang mode for the bed heater and set PWM limit
                                    M140 H0                                        ; map heated bed to heater 0
                                    M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
                                    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                    M307 H1 B0 R3.192 C111.5:105.0 D6.72 S1.00 V24.0                           ; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S260                                                  ; set temperature limit for heater 1 to 300C
                                    M950 F0 C"fan0" Q400                          ; create fan 0 on pin fan0 and set its frequency
                                    ;M106 P0 S0 H1 T0                                ; set fan 0 value. Thermostatic control is turned off
                                    M950 F1 C"fan1" Q400                          ; create fan 1 on pin fan1 and set its frequency
                                    M106 P1 S0 H1 T60                              ; set fan 1 value. Thermostatic control is turned on
                                    M563 P0 D0 H1 F0                               ; define tool 0
                                    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                    ;M575 P1 S1 B57600                              ; enable support for PanelDue
                                    ;M575 P1 S2 B57600
                                    M552 S1; enable network
                                    M150 X2
                                    T0 P0
                                    G29 S1
                                    M501
                                      Mythbear74 @gloomyandy
                                      Heres the others
                                      ; config-override.g file generated in response to M500 at 2024-02-19 18:43
                                      ; Heater model parameters
                                      M307 H0 R2.000 C140.000:140.000 D65.00 S1.00 V0.0 B0 I0
                                      M307 H1 R3.192 C111.500:105.000 D6.72 S1.00 V24.0 B0 I0
                                      ; Workplace coordinates
                                      G10 L2 P1 X0.00 Y0.00 Z0.00
                                      G10 L2 P2 X0.00 Y0.00 Z0.00
                                      G10 L2 P3 X0.00 Y0.00 Z0.00
                                      G10 L2 P4 X0.00 Y0.00 Z0.00
                                      G10 L2 P5 X0.00 Y0.00 Z0.00
                                      G10 L2 P6 X0.00 Y0.00 Z0.00
                                      G10 L2 P7 X0.00 Y0.00 Z0.00
                                      G10 L2 P8 X0.00 Y0.00 Z0.00
                                      G10 L2 P9 X0.00 Y0.00 Z0.00
                                      ; bed.g
                                      G29  ; probe the bed and enable compensation
                                      I don't have a mesh.g
                                      • soare0undefined
                                        soare0 @Mythbear74
                                        @Mythbear74
                                        I see you have no ideea what you are doing there. Dont know why you used R parameter. I think that is for a delta printer.
                                        If you understand what I am saying (as I think you are translating online from chinese), try something like this:
                                        M557 X10:180 Y10:180 S40
                                        You will have a 16 point mesh bed.
                                        However,
                                        M557 X10:180 Y10:180 S4:4
                                        may cover better the area, also, with 16 points mesh bed.
                                          Mythbear74
                                          No I’m not from China. It’s just this thing is actually a gift to me and I can just got thrown it after they set it up. I will try putting in that code and then give you an update. thanks😄
                                            Mythbear74
                                            All right, so I tried both those inputs, but it did the same problem. Is there any more information you need?
