    Bed leveling mesh calibration not working
    Duet Web Control
    bed leveling
    1.6k
    • gloomyandyundefined
      gloomyandy @Mythbear74
      @Mythbear74 As above please upload your config.g config-override.g, mesh.g, and bed.g files. Without them there is not much we can do to help you.
      Mythbear74undefined 1 Reply Last reply Reply Quote 0
      • Mythbear74undefined
        Mythbear74
        All right, I’ll have in a bit
          Mythbear74 @Mythbear74
          @Mythbear74 https://drive.google.com/drive/folders/1mVh4PYC3evAnAbOAZaH302QmmA_yATmp?usp=sharing
            Here it is
            soare0undefined 1 Reply Last reply Reply Quote 0
            • soare0undefined
              soare0 @Mythbear74
              @Mythbear74 Why not post here, as code?, Unless is for some secret military project, but then... google drive?
                Mythbear74
                Yeah, like I said before I’m new and this is like my first time using the thing also, I don’t know how to find this tab when signing into this account
                • soare0undefined
                  soare0 @Mythbear74
                  @Mythbear74 I paranoidly may think that on google drive you posted some infected files, if I would judge your answer. This... tab you speak about, will appear when you reply, at least on a normal computer.
                  Again, here is the explanation, in included image. If you still cant figure it, maybe you should make your 3d printer a gift for somebody. Dont mean to be ... mean, but just honest.
                    Mythbear74
                    So do you want me to send the code again but in this other way
                      You can drag and drop the config.g onto the post box to upload it here. Or even copy and paste the text here.
                        Mythbear74
                        Here is my config.g it was having trouble sending the file
                        ; Configuration file for SKR-E3-RRF (firmware version 3)
                        ; generated by RepRapFirmware Configuration Tool v3.1.10+4-LPC on Tue Jan 19 2021 17:25:01 GMT+0800 (中国标准时间)
                        M950 P1 C"SP"
                        M42 P1 S1
                        G90                                            ; send absolute coordinates...
                        M83                                            ; ...but relative extruder moves
                        M550 PAsa3DPrinter                         ; set printer name
                        M552 S-1
                        M552 S0
                        M587 S"namllok" P"7856501514"
                        M552 S1
                        M586 P0 S1                                     ; enable HTTP
                        M586 P1 S0                                     ; disable FTP
                        M586 P2 S0                                     ; disable Telnet
                        M569 P0 S0                                     ; physical drive 0 goes forwards using default driver timings
                        M569 P1 S0                                     ; physical drive 1 goes forwards using default driver timings
                        M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
                        M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
                        M584 X0 Y1 Z2 E3                               ; set drive mapping
                        M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                        M203 X12000.00 Y12000.00 Z600.00 E1200.00      ; set maximum speeds (mm/min)
                        M201 X600.00 Y600.00 Z20.00 E350.00            ; set accelerations (mm/s^2)
                        M906 X700 Y700 Z650 E750 I30                   ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                        ; Set idle timeout
                        M208 X0 Y0 Z0 S1                               ; set axis minima
                        M208 X230 Y230 Z250 S0                         ; set axis maxima
                        M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                        M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                        ;M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
                        ;M591 D0 P7 C"e0stop" S1  R50:130 L7.0 E10
                        M950 S0 C"Servo0"                               ; create servo pin 0 for BLTouch
                        M558 P9 C"^probe" H5 F800 T20000                ; set Z probe type to bltouch and the dive height + speeds
                        M557 X10:180 Y10:180 R-1 P2:2                      ; define mesh grid
                        G31 P500 X-40 Y10 Z4.3                           ; set Z probe trigger value, offset and trigger height
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                        M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                        M307 B1 S1.00                                  ; disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                        ; map heated bed to heater 0
                        M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B3950  ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                        M307 H1 B0 R3.192 C111.5:105.0 D6.72 S1.00 V24.0                           ; disable bang-bang mode for heater  and set PWM limit
                        M143 H1 S260                                                  ; set temperature limit for heater 1 to 300C
                        M950 F0 C"fan0" Q400                          ; create fan 0 on pin fan0 and set its frequency
                        ;M106 P0 S0 H1 T0                                ; set fan 0 value. Thermostatic control is turned off
                        M950 F1 C"fan1" Q400                          ; create fan 1 on pin fan1 and set its frequency
                        M106 P1 S0 H1 T60                              ; set fan 1 value. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                               ; define tool 0
                        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                        ;M575 P1 S1 B57600                              ; enable support for PanelDue
                        ;M575 P1 S2 B57600
                        M552 S1; enable network
                        M150 X2
                        T0 P0
                        G29 S1
                        M501
                          Mythbear74 @gloomyandy
                          Heres the others
                          ; config-override.g file generated in response to M500 at 2024-02-19 18:43
                          ; Heater model parameters
                          M307 H0 R2.000 C140.000:140.000 D65.00 S1.00 V0.0 B0 I0
                          M307 H1 R3.192 C111.500:105.000 D6.72 S1.00 V24.0 B0 I0
                          ; Workplace coordinates
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                          ; bed.g
                          G29  ; probe the bed and enable compensation
                          I don't have a mesh.g
                          • soare0undefined
                            soare0 @Mythbear74
                            @Mythbear74
                            I see you have no ideea what you are doing there. Dont know why you used R parameter. I think that is for a delta printer.
                            If you understand what I am saying (as I think you are translating online from chinese), try something like this:
                            M557 X10:180 Y10:180 S40
                            You will have a 16 point mesh bed.
                            However,
                            M557 X10:180 Y10:180 S4:4
                            may cover better the area, also, with 16 points mesh bed.
                              Mythbear74
                              No I’m not from China. It’s just this thing is actually a gift to me and I can just got thrown it after they set it up. I will try putting in that code and then give you an update. thanks😄
                                Mythbear74
                                All right, so I tried both those inputs, but it did the same problem. Is there any more information you need?
                                • soare0undefined
                                  soare0 @Mythbear74
                                  @Mythbear74
                                  If you will put here the files, either as code or copy pasted, as well as a short clip with the problem, I am sure that they will be many to help much better than me. I am sorry, but it is difficult otherwise.
                                  PS. It is not a problem if you eventually are from China, I just expressed the feeling that you do not understand what we are saying, wich is usually because a language barrier.
                                  PS2. Do not insert those files as images/screen captures, as probably some of them will not fit on your monitor (I see that your config files start at line 46). Unless ... you will rotate the monitor to portrait, if you insist with screen captures.
                                  PS3. There is also the possibility that the printer has an hardware issue, so.... files and clip needed.
                                  PS4. Normally, it should have been a difference between your M557 and mine. Maybe you can show how the original M557 was (assuming it was the original).
                                  PS5. If you do not try to do mesh, the printer works right?
                                    Mythbear74
                                    Honestly at this point I’d rather like to know how to completely eradicate the height map system so it forgets about it.
                                    PS, I am not from china I am in the US and I am quite new to this
                                      droftarts administrators @Mythbear74
                                      @Mythbear74 said in Bed leveling mesh calibration not working:
                                      At the end of your config.g are these three lines:
                                      T0 P0
                                      G29 S1
                                      M501
                                      The G29 S1 loads the mesh file called /sys/heightmap.csv, which is usually the last mesh created. If you comment that out (ie put a semicolon like ; at the beginning of the line) or just delete it, no mesh will be loaded.
                                      However, I think the original problem of your bed mesh probe starting "in an area without anything under it" is caused by your probe offset. This is defined by the G31 command in the probe section, and more specifically I think the X and Y coordinates are incorrect. Currently you have:
                                      To get them correct, see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing#measuring-probe-x-y-offset. The whole page is worth a read.
                                      I've taken the liberty of adding your config.g, config-override.g and bed.g to your posts as text (cut and pasted from the files on Google Drive). We couldn't see the full config.g in your screenshots.
                                      • soare0undefined
                                        soare0 @droftarts
                                        @droftarts said in Bed leveling mesh calibration not working:
                                        Indeed, -40 it is much, but if the printer is something like a ”classic” Ender:
                                        this may be it. Y=10 is almost sure ok, this is why I asked for some clip/photo.
                                        Probably erasing G29 is the best Ideea, anyway...
                                          Mythbear74 @soare0
                                          @soare0 yes but do you have a way of actually achieving the erase of the height map/G29
                                          soare0undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                          • soare0undefined
                                            soare0 @Mythbear74
                                            @Mythbear74 Del or Back keys on your keyboard?
                                            And if you are not able at least to submit a photo with your printer or a clip with its behaviour, I am very doubtful that anybody will be able to help you with this.
                                            Maybe Deanna Troy's mother, as she is a good mind reader ...
