    1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
    Beta Firmware
    9
    147
    8.7k
      T3P3Tony administrators @Exerqtor
      @Exerqtor I think we will arrange a replacement board being sent to you to rule this out. Can you email info@duet3d.com to co-ordinate.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Exerqtorundefined
        Exerqtor @T3P3Tony
        While waiting for the replacement/test board to arrive I have to get some prints done. So I reverted back to 3.5.0-b4 on the main and tool board. Then tried the same "doomed" job as I've been testing out the different 3.5.0-rc's on and it's currently going without any issues (like i expected).
        Here is a couple reports, the first one is from layer1 with the second being from layer81.
        Layer 1 / Z 0.25:
        M122
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
        Used output buffers: 1 of 40 (30 max)
        Static ram: 102996
        Dynamic ram: 130800 of which 0 recycled
        Never used RAM 4316, free system stack 138 words
        Tasks: NETWORK(1,ready,19.3%,197) HEAT(3,nWait,0.0%,331) Move(4,nWait,0.1%,244) CanReceiv(6,nWait,0.1%,557) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,74) MAIN(1,running,78.0%,578) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.8%,266), total 100.0%
        Owned mutexes:
        Last reset 00:19:17 ago, cause: software
        Last software reset at 2024-02-24 13:14, reason: User, Gcodes spinning, available RAM 11080, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 1157769, completed 1157767, timed out 0, errs 0
        MCU temperature: min 38.3, current 44.3, max 44.3
        Supply voltage: min 3.0, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/516/56, gc cycles 277
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 60866, writes 32, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 60866, writes 32, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: not present
        Driver 6: not present
        Date/time: 2024-02-24 13:34:08
        Cache data hit count 1894456688
        Slowest loop: 226.36ms; fastest: 0.09ms
        === Storage ===
        Free file entries: 16
        SD card longest read time 7.9ms, write time 5.7ms, max retries 0
        DMs created 83, segments created 12, maxWait 1002320ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        next step interrupt due in 106 ticks, enabled
        === DDARing 0 ===
        Scheduled moves 439, completed 400, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
        === DDARing 1 ===
        Heater 0 is on, I-accum = 0.4
        Heater 1 is on, I-accum = 0.0
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 3
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is doing "G4 P250        " in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 4, axes/extruders owned 0x0000807
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        Extruder 0 sensor: no filament
        === CAN ===
        Messages queued 10819, received 23940, lost 0, boc 0
        Longest wait 3ms for reply type 6053, peak Tx sync delay 4577, free buffers 18 (min 17), ts 5787/5785/0
        Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
        === Network ===
        Slowest loop: 207.25ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        = WiFi =
        Interface state: active
        Module is connected to access point
        Firmware version 2.1beta7
        MAC address c4:5b:be:ce:91:93
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43028
        WiFi IP address 192.168.10.x
        Signal strength -51dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002001
        M122 B121
        Diagnostics for board 121:
        Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
        Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
        All averaging filters OK
        Never used RAM 1440, free system stack 88 words
        Tasks: Move(3,nWait,0.0%,111) HEAT(2,nWait,0.5%,65) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,0.0%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.5%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,142), total 100.0%
        Last reset 00:19:21 ago, cause: VDD brownout
        Last software reset data not available
        Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 56507, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 58104
        Moves scheduled 311, completed 305, in progress 1, hiccups 6, step errors 0, maxPrep 528, maxOverdue 71, maxInc 71, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 0.98
        Peak sync jitter -2/9, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 23.3, current 24.3, max 24.5
        MCU temperature: min 40.3C, current 58.4C, max 58.4C
        Last sensors broadcast 0x00000012 found 2 78 ticks ago, 0 ordering errs, loop time 1
        CAN messages queued 24058, send timeouts 0, received 10938, lost 0, free buffers 18, min 18, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 327, adv 35902/74656
        Accelerometer: LIS3DH, status: 00
        I2C bus errors 0, naks 3, other errors 0
        Interrupt 5726621 to 0us, poll 2 to 2104us
        Driver 0: ok
        Layer 81 / Z 16.25:
        M122
        Used output buffers: 14 of 40 (37 max)
        Static ram: 102996
        Never used RAM 3668, free system stack 128 words
        Tasks: NETWORK(2,nWait,18.2%,197) HEAT(3,nWait,0.0%,331) Move(4,nWait,2.4%,244) CanReceiv(6,nWait,0.1%,557) CanSender(5,nWait,0.1%,328) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.8%,74) MAIN(1,running,76.3%,578) IDLE(0,ready,1.2%,29) AIN(4,delaying,1.0%,266), total 100.0%
        Owned mutexes:
        Last reset 00:50:38 ago, cause: software
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 3039527, completed 3039526, timed out 0, errs 0
        MCU temperature: min 46.2, current 46.4, max 46.6
        Supply voltage: min 23.8, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/708/248, gc cycles 679
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 302, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 302, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2024-02-24 14:05:30
        Slowest loop: 9.14ms; fastest: 0.12ms
        === Storage ===
        SD card longest read time 8.3ms, write time 4.2ms, max retries 0
        DMs created 83, segments created 39, maxWait 350ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        next step interrupt due in 27 ticks, enabled
        === DDARing 0 ===
        Scheduled moves 55744, completed 55731, hiccups 0, stepErrors 0, LaErrors 1, Underruns [0, 0, 0], CDDA state 3
        === DDARing 1 ===
        File is doing "G1 X230.443 Y223.609 E.02122" in state(s) 0
        File2 is idle in state(s) 0, sync state 1
        Q0 segments left 1, axes/extruders owned 0x0000807
        Queue 0 has 'M106 S204' for move 55735
        === CAN ===
        Messages queued 157, received 118, lost 0, boc 0
        Longest wait 4ms for reply type 6029, peak Tx sync delay 133, free buffers 18 (min 17), ts 28/28/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 19.54ms; fastest: 0.07ms
        Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        = WiFi =
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36164
        Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
        M122 B121
        Never used RAM 888, free system stack 88 words
        Tasks: Move(3,nWait,1.0%,111) HEAT(2,nWait,0.6%,57) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,0.2%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.2%,57) MAIN(1,running,89.7%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.2%,142), total 100.0%
        Last reset 00:50:42 ago, cause: VDD brownout
        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 35259, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 172975
        Moves scheduled 48482, completed 48482, in progress 0, hiccups 154, step errors 0, maxPrep 1236, maxOverdue 713, maxInc 461, mcErrs 0, gcmErrs 0, ebfmin -0.99, ebfmax 1.00
        Peak sync jitter 1/11, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 23.9, current 24.3, max 24.5
        MCU temperature: min 40.3C, current 74.1C, max 74.1C
        Last sensors broadcast 0x00000012 found 2 175 ticks ago, 0 ordering errs, loop time 2
        CAN messages queued 1522, send timeouts 0, received 2712, lost 0, free buffers 18, min 17, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 416, adv 35935/74658
        I2C bus errors 0, naks 0, other errors 0
        Interrupt 5726621 to 0us, poll 10 to 2689us
        Driver 0: ok
        (And again, the "VDD brownout reset cause" on the 1LC is the reboot after downgrading to 3.5.0-b4 and relays controlling the 24V rails flipping off/on).
        Doubt it's any value in those reports, but it's atleast another proof that the issue manifest after 3.5.0-b4.
        I'll let the print finish just for the sake of sanity and arguent and update this post.
        And it finished without a hickup:
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Exerqtor
          @dc42 I received the replacement 1LC today, so I first updated the firmware to the binaries you posted a couple days ago on both the main & old tool board. Then ran a test
          print with the same file as before to have solid point of reference before swaping boards.
          The old board behaved just like suspected and stoped extruding a little bit into layer 3, here are the reports.
          Extruding:
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3+ (2024-02-27 13:52:47) running on Duet 3 Mini5plus WiFi (standalone mode)
          Used output buffers: 21 of 40 (32 max)
          Static ram: 103264
          Dynamic ram: 128648 of which 0 recycled
          Never used RAM 5512, free system stack 144 words
          Tasks: NETWORK(2,nWait 7,15.9%,220) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,delaying,0.8%,68) MAIN(1,running,81.1%,610) IDLE(0,ready,1.2%,30) AIN(4,delaying,0.9%,260), total 100.0%
          Owned mutexes:
          Last reset 00:11:35 ago, cause: software
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 696225, completed 696224, timed out 0, errs 0
          MCU temperature: min 34.2, current 40.7, max 40.7
          Supply voltage: min 2.6, current 23.9, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1092/632, gc cycles 176
          Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 36577, writes 31, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 36577, writes 31, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 36587, writes 20, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 36587, writes 20, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 36587, writes 21, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2024-02-28 16:00:56
          Cache data hit count 1133766067
          Slowest loop: 217.97ms; fastest: 0.09ms
          === Storage ===
          SD card longest read time 7.5ms, write time 50.3ms, max retries 0
          DMs created 83, segments created 14, maxWait 557540ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 44 ticks, enabled
          Moves shaped first try 43, on retry 0, too short 2, wrong shape 169, maybepossible 1
          === DDARing 0 ===
          Scheduled moves 345, completed 315, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
          === DDARing 1 ===
          Heater 0 is on, I-accum = 0.5
          Daemon is doing "G4 P250" in state(s) 0 0, running macro
          check 0 clear 0
          === CAN ===
          Messages queued 6581, received 14457, lost 0, errs 1237, boc 0
          Longest wait 4ms for reply type 6029, peak Tx sync delay 46266, free buffers 26 (min 25), ts 3480/3478/0
          === Network ===
          Slowest loop: 27.07ms; fastest: 0.00ms
          === WiFi ===
          Failed messages: pending 0, notrdy 0, noresp 0
          Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
          M122 B121
          Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-26 15:24:37)
          Never used RAM 3688, free system stack 91 words
          Tasks: Move(3,nWait 7,0.0%,91) HEAT(2,nWait 6,0.4%,95) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
          Owned mutexes:
          Last reset 00:11:38 ago, cause: power up
          Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 21380, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 46371
          Moves scheduled 194, completed 193, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 297, maxOverdue 39, maxInc 39, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
          Peak sync jitter -2/9, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 23.3, current 24.1, max 24.4
          MCU temperature: min 39.2C, current 50.6C, max 50.6C
          Last sensors broadcast 0x00000012 found 2 121 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 14535, send timeouts 0, received 6637, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 36007/74649
          I2C bus errors 0, naks 3, contentions 0, other errors 0
          Interrupt 5726621 to 0us, poll 2 to 1512us
          Driver 0: ok
          Not extruding:
          M122
          Used output buffers: 13 of 40 (40 max)
          Static ram: 103264
          Never used RAM 4960, free system stack 138 words
          Tasks: NETWORK(2,nWait 7,17.4%,218) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.4%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,330) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,77.0%,610) IDLE(0,ready,1.3%,30) AIN(4,delaying,0.9%,260), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:16:08 ago, cause: software
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 968535, completed 968535, timed out 0, errs 0
          MCU temperature: min 40.4, current 46.0, max 46.6
          Supply voltage: min 23.7, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/772/312, gc cycles 235
          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2024-02-28 16:05:28
          Cache data hit count 1522225812
          Slowest loop: 36.63ms; fastest: 0.10ms
          === Storage ===
          SD card longest read time 8.4ms, write time 4.5ms, max retries 0
          DMs created 83, segments created 37, maxWait 2140ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 15 ticks, enabled
          Moves shaped first try 290, on retry 63, too short 121, wrong shape 2546, maybepossible 57
          === DDARing 0 ===
          Scheduled moves 4027, completed 3987, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
          === DDARing 1 ===
          File is doing "G2 X223.055 Y232.264 I.189 J-.413 E.01443" in state(s) 0
          Queue 0 has 'M106 S135' for move 4021
          check 0 clear 0
          === CAN ===
          Messages queued 5799, received 5612, lost 0, errs 0, boc 0
          Longest wait 6ms for reply type 6024, peak Tx sync delay 295, free buffers 26 (min 25), ts 1361/1361/0
          === Network ===
          Slowest loop: 20.10ms; fastest: 0.07ms
          === WiFi ===
          Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 43028
          Signal strength -56dBm, channel 6, mode 802.11n, reconnections 0
          M122 B121
          Never used RAM 3112, free system stack 71 words
          Tasks: Move(3,nWait 7,0.3%,87) HEAT(2,nWait 6,0.4%,95) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
          Owned mutexes:
          Last reset 00:16:11 ago, cause: power up
          Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 5275, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 339601
          Moves scheduled 2821, completed 2821, in progress 0, hiccups 111, segs 36, step errors 0, maxLate 0 maxPrep 886, maxOverdue 97, maxInc 38, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
          Peak sync jitter 0/9, peak Rx sync delay 225, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 23.9, current 24.1, max 24.4
          MCU temperature: min 39.2C, current 55.8C, max 55.9C
          Last sensors broadcast 0x00000012 found 2 148 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 5639, send timeouts 0, received 5877, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 363, adv 35929/74647
          I2C bus errors 0, naks 0, contentions 0, other errors 0
          Interrupt 5726621 to 0us, poll 9 to 1728us
          Driver 0: ok
          • Exerqtorundefined
            Exerqtor @Exerqtor
            Had to make two posts due to character limit.
            And the new board behaves exactly the same.
            Extruding:
            M122
            Used output buffers: 17 of 40 (32 max)
            Static ram: 103264
            Dynamic ram: 128512 of which 0 recycled
            Never used RAM 5648, free system stack 135 words
            Tasks: NETWORK(2,nWait 7,16.0%,228) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,80.8%,595) IDLE(0,ready,1.3%,30) AIN(4,delaying,0.9%,260), total 100.0%
            Last reset 00:11:44 ago, cause: software
            Last software reset at 2024-02-28 17:11, reason: User, Gcodes spinning, available RAM 11836, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 704369, completed 704369, timed out 0, errs 0
            MCU temperature: min 34.0, current 43.4, max 43.4
            Supply voltage: min 2.8, current 23.9, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1924/1464, gc cycles 175
            Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 36995, writes 46, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 47, reads 36994, writes 47, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 37018, writes 23, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 37017, writes 24, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 37017, writes 24, timeouts 0, DMA errors 0, CC errors 0
            Date/time: 2024-02-28 17:23:20
            Cache data hit count 1145422321
            Slowest loop: 225.76ms; fastest: 0.09ms
            === Storage ===
            SD card longest read time 7.8ms, write time 46.0ms, max retries 0
            DMs created 83, segments created 14, maxWait 534741ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
            next step interrupt due in 65 ticks, enabled
            Moves shaped first try 48, on retry 0, too short 2, wrong shape 155, maybepossible 1
            === DDARing 0 ===
            Scheduled moves 307, completed 301, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === DDARing 1 ===
            File is doing "G1 X107.735 Y134.32 E.04472" in state(s) 0
            check 0 clear 0
            === CAN ===
            Messages queued 6647, received 14643, lost 0, errs 1247, boc 0
            Longest wait 2ms for reply type 6031, peak Tx sync delay 47841, free buffers 26 (min 25), ts 3521/3519/0
            === Network ===
            Slowest loop: 199.19ms; fastest: 0.00ms
            === WiFi ===
            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39764
            M122 B121
            Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
            Never used RAM 3688, free system stack 85 words
            Tasks: Move(3,nWait 7,0.0%,95) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
            Owned mutexes:
            Last reset 00:11:46 ago, cause: power up
            Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 25412, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 43148
            Moves scheduled 171, completed 167, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 268, maxOverdue 38, maxInc 38, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.99
            Peak sync jitter -3/9, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
            VIN voltage: min 23.7, current 24.5, max 25.3
            MCU temperature: min 40.5C, current 55.5C, max 55.5C
            Last sensors broadcast 0x00000012 found 2 185 ticks ago, 0 ordering errs, loop time 1
            CAN messages queued 14716, send timeouts 0, received 6697, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 322, adv 35722/74642
            Interrupt 5726621 to 0us, poll 2 to 1472us
            Driver 0: ok
            Not extruding:
            M122
            Used output buffers: 22 of 40 (40 max)
            Static ram: 103264
            Never used RAM 5072, free system stack 135 words
            Tasks: NETWORK(2,nWait 7,17.4%,218) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.4%,238) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,76.9%,595) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
            Last reset 00:17:04 ago, cause: software
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 1025081, completed 1025080, timed out 0, errs 0
            MCU temperature: min 43.2, current 46.2, max 46.6
            Supply voltage: min 23.5, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/580/120, gc cycles 245
            Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 47, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 16869, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Date/time: 2024-02-28 17:28:41
            Cache data hit count 1601436176
            Slowest loop: 35.52ms; fastest: 0.10ms
            === Storage ===
            SD card longest read time 9.7ms, write time 10.6ms, max retries 0
            DMs created 83, segments created 38, maxWait 2147ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
            next step interrupt due in 34 ticks, enabled
            Moves shaped first try 439, on retry 114, too short 173, wrong shape 3194, maybepossible 90
            === DDARing 0 ===
            Scheduled moves 5246, completed 5224, hiccups 0, stepErrors 0, LaErrors 4, Underruns [0, 0, 0], CDDA state 3
            === DDARing 1 ===
            Q0 segments left 6, axes/extruders owned 0x0000807
            check 0 clear 0
            === CAN ===
            Messages queued 7296, received 6608, lost 0, errs 0, boc 0
            Longest wait 6ms for reply type 6024, peak Tx sync delay 264, free buffers 26 (min 25), ts 1604/1604/0
            === Network ===
            Slowest loop: 19.51ms; fastest: 0.06ms
            === WiFi ===
            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43020
            Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
            M122 B121
            Tasks: Move(3,nWait 7,0.3%,87) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.5%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
            Owned mutexes:
            Last reset 00:17:06 ago, cause: power up
            Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 28621, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 359702
            Moves scheduled 2891, completed 2891, in progress 0, hiccups 154, segs 36, step errors 0, maxLate 0 maxPrep 871, maxOverdue 136, maxInc 81, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
            Peak sync jitter -2/10, peak Rx sync delay 214, resyncs 0/0, no timer interrupt scheduled
            VIN voltage: min 24.3, current 24.4, max 25.0
            MCU temperature: min 40.5C, current 60.0C, max 60.0C
            Last sensors broadcast 0x00000012 found 2 104 ticks ago, 0 ordering errs, loop time 0
            CAN messages queued 6604, send timeouts 0, received 7291, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 353, adv 35628/107888
            Interrupt 5726621 to 0us, poll 9 to 1545us
            Driver 0: ok
              droftarts administrators @Exerqtor
              @Exerqtor I'm going to set up a printer tomorrow with a Mini 5+ and 1LC, to see if we can replicate this issue. Can you post your current config.g and any other relevant files (I can't immediately find them in the thread, sorry if you have already posted them), and tell me a little about your printer? I think you have a Voron Trident or something similar, with a Stealthburner? It would also be good to know what extruder and hot end, nozzle size, filament type and size, etc. I'm a bit limited in hardware, but I'll try and replicate your setup at least functionally. Is the gcode file you linked in the first post of this thread still the one all the tests have been carried out on?
              • Exerqtorundefined
                Exerqtor @droftarts
                @droftarts
                I'll take a complete SD-card dump and upload later today including the job file. I think I forgot to do it earlier dispite saying I was going to do so a while back🤦‍♂️
                Specs:
                • Voron Trident
                • Meanwell 24v & 5v PSU (original, not clones lol)
                • Keenovo 230v bed heathwr, through a Omron SSR.
                • Stealthburner toolhead with optoTAP
                • Stealthburner leds connected to the mainboard (if you want / have the parts to test that)
                • Highflow(60w) Revo micro (with a 0.4mm HF nozzle atm)
                • LGX-lite and a 0.4mm highflow nozzle
                • Hall-element filament runout sensor
                • Regarding filament I've tried and comfirmed it bugging out with both 1,75MM Flashforge, Esun and Fiberlogy ABS/ABS-plus & ASA.
                  @Exerqtor Okay, thanks. Your machine might be a little tricky for me to replicate with what I have on hand, as I don't have any high flow hot ends or an LGX. Was the problem noticeable when you did an air print, ie with no filament? That way I won't have to reduce speeds, which may be a factor. I do have a pancake stepper
                  Regarding board setup, it's just the Mini 5+ and 1LC connected? What length is the CAN bus? And you have soldered the termination jumper on the back of the 1LC?
                  Exerqtorundefined 2 Replies Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @droftarts
                    @droftarts I haven't tried an unloaded print, I can try that later today (all though i'm quite sure it will behave just the same).
                    Yup, just those two boards and the jumper is soldered. Regarding canbus length it's 1000-1200mm at most, done with twisted FEP wires.
                    • Exerqtorundefined
                      Exerqtor @droftarts
                      @droftarts
                      Okey, here is the SD-dump (I just took it), the only things I've left out is the "System Volume Information" folder, the debug logs and any other sliced jobs than the one I've been using for testing. And regarding IP-address and WiFi setup that's all done in runounce.g so you will have to deploy that yourself, as i suspect you're well aware of lol.
                      Just as a heads up regarding testing the "air print / unloaded" i'm going to alter the jobfile so the bed temp is 30C, gonna try that now and report back.
                        @Exerqtor Great, thanks. This will have to wait until tomorrow now. Don't forget to enable cold extrude with M302 P1!
                        • Exerqtorundefined
                          Exerqtor @droftarts
                          @droftarts
                          Np, do it whenever you got time 😃 Yeah i skipped changing the hotend temp just incase the powerdraw to the toolboard might be a issue, still haven't had time to run it yet lol.
                          Well that's for sure a definitive answer that loaded filament wasn't the issue, now it's acting up from the first layer again. Won't extrude at all during the print. However if I pause it and manuallly try to extrude through DWC or PD it extrudes without an issue.
                          Here is the reports from the ongoing test without any extrusion:
                          M122
                          Used output buffers: 10 of 40 (40 max)
                          Static ram: 103264
                          Dynamic ram: 128568 of which 0 recycled
                          Never used RAM 5016, free system stack 128 words
                          Tasks: NETWORK(1,ready,144.4%,182) HEAT(3,nWait 6,2.6%,326) Move(4,nWait 6,1.7%,238) CanReceiv(6,nWait 1,4.8%,773) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.7%,340) TMC(4,nWait 6,72.2%,68) MAIN(1,running,290.3%,595) IDLE(0,ready,80.6%,30) AIN(4,delaying,73.6%,260), total 670.9%
                          Owned mutexes:
                          Last reset 24:25:27 ago, cause: software
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 87927453, completed 87927453, timed out 0, errs 0
                          MCU temperature: min 34.4, current 46.0, max 46.4
                          Supply voltage: min 23.4, current 24.1, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1764/1304, gc cycles 18673
                          Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 87, reads 51758, writes 41, timeouts 0, DMA errors 0, CC errors 0
                          Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 88, reads 51757, writes 41, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x51
                          Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 51780, writes 18, timeouts 0, DMA errors 0, CC errors 0
                          Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 42, reads 51780, writes 18, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01
                          Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 42, reads 51781, writes 18, timeouts 0, DMA errors 0, CC errors 0
                          Date/time: 2024-02-29 17:37:03
                          Slowest loop: 229.18ms; fastest: 0.09ms
                          === Storage ===
                          SD card longest read time 9.2ms, write time 67.1ms, max retries 0
                          DMs created 83, segments created 38, maxWait 85780177ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                          next step interrupt due in 13849 ticks, enabled
                          Moves shaped first try 1145, on retry 293, too short 345, wrong shape 6378, maybepossible 191
                          === DDARing 0 ===
                          Scheduled moves 3966, completed 3926, hiccups 0, stepErrors 0, LaErrors 9, Underruns [0, 0, 2], CDDA state 3
                          === DDARing 1 ===
                          Heater 0 is on, I-accum = 0.0
                          File is doing "G1 Z.85" in state(s) 0
                          Q0 segments left 0, axes/extruders owned 0x0000807
                          check 0 clear 0
                          === CAN ===
                          Messages queued 791270, received 1781906, lost 0, errs 0, boc 0
                          Longest wait 6ms for reply type 6024, peak Tx sync delay 276, free buffers 26 (min 25), ts 434512/434512/0
                          === Network ===
                          Slowest loop: 207.39ms; fastest: 0.06ms
                          === WiFi ===
                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42848
                          Signal strength -58dBm, channel 6, mode 802.11n, reconnections 0
                          M122 B121
                          Tasks: Move(3,nWait 7,0.4%,87) HEAT(2,nWait 6,32.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,1.2%,71) CanClock(5,nWait 1,1.8%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,296.3%,53) MAIN(1,running,478.3%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,428.1%,112), total 1238.6%
                          Owned mutexes:
                          Last reset 24:25:32 ago, cause: power up
                          Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 921, writes 4, timeouts 6, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 0 done 185963
                          Moves scheduled 3356, completed 3356, in progress 0, hiccups 235, segs 36, step errors 0, maxLate 0 maxPrep 894, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                          Peak sync jitter -3/9, peak Rx sync delay 221, resyncs 0/0, no timer interrupt scheduled
                          VIN voltage: min 23.6, current 24.4, max 25.2
                          MCU temperature: min 37.8C, current 40.9C, max 63.4C
                          Last sensors broadcast 0x00000012 found 2 95 ticks ago, 0 ordering errs, loop time 0
                          CAN messages queued 1781927, send timeouts 0, received 791335, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 342, adv 35637/104588
                          Interrupt 5726621 to 0us, poll 5 to 1777us
                          Driver 0: ok
                          The only extrusion it did by itself is the load sequence right before doing the purge lines, not even the purge lines themself yielded any movement.
                            dc42 administrators @Exerqtor
                            @Exerqtor I see that there are some hiccups on the tool board. Does it make any difference if you use M220 S50 just before starting the print, to run it at half speed?
                            • Exerqtorundefined
                              Exerqtor @dc42
                              I can add it to the job code manually and run another test, give me a couple minutes and I'll report back.
                              Nah, same exact thing only does the nozzle loading sequence then nothing:
                              M122
                              Used output buffers: 25 of 40 (40 max)
                              Static ram: 103264
                              Never used RAM 4992, free system stack 106 words
                              Tasks: NETWORK(2,nWait 7,16.2%,182) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.3%,238) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,delaying,0.8%,68) MAIN(1,running,80.5%,595) IDLE(0,ready,1.1%,30) AIN(4,delaying,0.9%,260), total 100.0%
                              Last reset 24:48:18 ago, cause: software
                              Error status: 0x04
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 89299231, completed 89299231, timed out 0, errs 0
                              MCU temperature: min 36.2, current 40.0, max 46.2
                              Supply voltage: min 23.5, current 23.7, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1572/1112, gc cycles 18995
                              Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 106, reads 6635, writes 19, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 107, reads 6635, writes 19, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 48, reads 6647, writes 7, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 49, reads 6647, writes 7, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 50, reads 6646, writes 8, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2024-02-29 17:59:55
                              Slowest loop: 229.98ms; fastest: 0.09ms
                              === Storage ===
                              SD card longest read time 9.0ms, write time 46.1ms, max retries 0
                              DMs created 83, segments created 39, maxWait 1072427ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                              next step interrupt due in 18 ticks, enabled
                              Moves shaped first try 538, on retry 151, too short 149, wrong shape 2343, maybepossible 92
                              === DDARing 0 ===
                              Scheduled moves 348, completed 319, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 3], CDDA state 3
                              === DDARing 1 ===
                              Heater 0 is on, I-accum = 0.3
                              Q0 segments left 3, axes/extruders owned 0x0000807
                              check 0 clear 0
                              === CAN ===
                              Messages queued 15975, received 28320, lost 0, errs 0, boc 0
                              Longest wait 6ms for reply type 6024, peak Tx sync delay 156, free buffers 26 (min 25), ts 6858/6858/0
                              === Network ===
                              Slowest loop: 206.78ms; fastest: 0.06ms
                              === WiFi ===
                              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42676
                              M122 B121
                              Tasks: Move(3,nWait 7,0.1%,87) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.1%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                              Owned mutexes:
                              Last reset 24:48:22 ago, cause: power up
                              Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 29151, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 113840
                              Moves scheduled 3577, completed 3577, in progress 0, hiccups 110, segs 36, step errors 0, maxLate 0 maxPrep 883, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                              Peak sync jitter -2/9, peak Rx sync delay 217, resyncs 0/0, no timer interrupt scheduled
                              VIN voltage: min 23.7, current 24.5, max 24.9
                              MCU temperature: min 37.8C, current 42.5C, max 63.4C
                              Last sensors broadcast 0x00000012 found 2 8 ticks ago, 0 ordering errs, loop time 1
                              CAN messages queued 28289, send timeouts 0, received 15909, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 339, adv 35936/74646
                              Interrupt 5726621 to 0us, poll 5 to 2528us
                              Driver 0: ok
                              Those reports are taken during the first couple loops of the first layer btw.
                              • Exerqtorundefined
                                Exerqtor @Exerqtor
                                @Exerqtor
                                For some reason the half speed factor didn't apply, I just set in manually in DWC and ran another set of reports on the same print session (still no extruder movement):
                                M122
                                Used output buffers: 15 of 40 (40 max)
                                Static ram: 103264
                                Tasks: NETWORK(1,ready,17.8%,182) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.2%,235) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,76.7%,595) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                Owned mutexes:
                                Last reset 24:52:22 ago, cause: software
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU revision 3, ADC conversions started 89542995, completed 89542993, timed out 0, errs 0
                                MCU temperature: min 39.8, current 46.0, max 46.2
                                Supply voltage: min 23.6, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1252/792, gc cycles 19048
                                Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 106, reads 12823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 107, reads 12823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 48, reads 12824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 49, reads 12824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 50, reads 12823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Date/time: 2024-02-29 18:03:59
                                Slowest loop: 36.84ms; fastest: 0.10ms
                                === Storage ===
                                SD card longest read time 8.1ms, write time 6.5ms, max retries 0
                                DMs created 83, segments created 39, maxWait 2727ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                next step interrupt due in 39 ticks, enabled
                                Moves shaped first try 43, on retry 1, too short 33, wrong shape 1516, maybepossible 4
                                === DDARing 0 ===
                                Scheduled moves 2067, completed 2054, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                === DDARing 1 ===
                                check 0 clear 0
                                === CAN ===
                                Messages queued 3885, received 5028, lost 0, errs 0, boc 0
                                Longest wait 6ms for reply type 6024, peak Tx sync delay 198, free buffers 26 (min 25), ts 1219/1219/0
                                === Network ===
                                Slowest loop: 20.37ms; fastest: 0.06ms
                                === WiFi ===
                                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39588
                                Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0
                                M122 B121
                                Tasks: Move(3,nWait 7,0.1%,87) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.0%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                Owned mutexes:
                                Last reset 24:52:27 ago, cause: power up
                                Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 57100, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 2550
                                Moves scheduled 3587, completed 3587, in progress 0, hiccups 5, segs 36, step errors 0, maxLate 0 maxPrep 514, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                                Peak sync jitter -2/9, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
                                VIN voltage: min 24.2, current 24.4, max 24.9
                                MCU temperature: min 37.8C, current 41.7C, max 63.4C
                                Last sensors broadcast 0x00000012 found 2 116 ticks ago, 0 ordering errs, loop time 0
                                CAN messages queued 5062, send timeouts 0, received 3897, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 329, adv 36085/104580
                                Interrupt 5726621 to 0us, poll 9 to 1722us
                                Driver 0: ok
                                I went through the whole system macro by macro in executed order another time yesterday evening and i can't for the life of it find anything that could cause the behaviour this time either.
                                How big is the code changes between 3.5.0-b4 and 3.5.0-rc1 in the regard to what might produce this bug? Given that everything plays nice in beta4 it seems rational to assume that the buggy code got added at that point, and is still persisting in the following release candidates.
                                  @Exerqtor The changes should be listed here: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-350-rc1-changes-since-350-beta4
                                  To actually do a code review, 3.5.0-beta.4 was release on the 9th June, and 3.5.0-rc.1 on 1st September, so it's looking at all the commits over a nearly 3 month period.
                                  I'm just setting up to run the tests, which involves swapping the X axis on my printer! Don't worry, it was due an upgrade.
                                  • Exerqtorundefined
                                    Exerqtor @droftarts
                                    @droftarts said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-r1:
                                    Yeah it's alot of commits/code to read through so I totally get why it's a bitch to track down.
                                    I'll try to disable the filament sensor and see if that makes a difference just for the shits later. Thats pretty much "the only thing" I can't remember trying out this far.
                                    It will be interesting hearing how it plays out for you!
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      Ok so i've tried out a couple other things too now, but it still yields the same result.
                                      • Updated the toolboards bootloader to 2.8, and reinstalled with the binaries mentioned earleir.
                                      • Commented out the filament sensor code from config.g.
                                      • Added M220 S50 to my start gcode so every extruder move is at 50% from the getgo.
                                      Here is the reports from when it's not extruding agian (stopped at the "usual point" in layer 3) :
                                      M122
                                      Used output buffers: 9 of 40 (34 max)
                                      Static ram: 103264
                                      Dynamic ram: 128496 of which 0 recycled
                                      Never used RAM 3128, free system stack 128 words
                                      Tasks: NETWORK(2,nWait 7,17.3%,196) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,1.5%,241) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,78.0%,602) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                      Last reset 00:17:57 ago, cause: software
                                      Last software reset at 2024-03-01 14:10, reason: User, Gcodes spinning, available RAM 4992, slot 1
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 1078021, completed 1078021, timed out 0, errs 0
                                      MCU temperature: min 35.3, current 46.0, max 46.4
                                      Supply voltage: min 2.8, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/1060/600, gc cycles 148
                                      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 56674, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 56673, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 56684, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 56683, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 56685, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2024-03-01 14:28:33
                                      Cache data hit count 1597184571
                                      Slowest loop: 222.42ms; fastest: 0.09ms
                                      === Storage ===
                                      SD card longest read time 9.5ms, write time 46.1ms, max retries 0
                                      DMs created 83, segments created 34, maxWait 210310ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                      next step interrupt due in 16 ticks, enabled
                                      Moves shaped first try 928, on retry 45, too short 162, wrong shape 5053, maybepossible 89
                                      === DDARing 0 ===
                                      Scheduled moves 7843, completed 7803, hiccups 0, stepErrors 0, LaErrors 6, Underruns [0, 0, 0], CDDA state 3
                                      === DDARing 1 ===
                                      Heater 0 is on, I-accum = 0.6
                                      File is doing "G1 Z2.55 F21000" in state(s) 0
                                      === CAN ===
                                      Messages queued 16603, received 21779, lost 0, errs 1297, boc 0
                                      Longest wait 5ms for reply type 6024, peak Tx sync delay 6564, free buffers 26 (min 25), ts 5390/5388/0
                                      === Network ===
                                      Slowest loop: 205.29ms; fastest: 0.00ms
                                      === WiFi ===
                                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42320
                                      Signal strength -53dBm, channel 6, mode 802.11n, reconnections 0
                                      	M122 B121
                                      Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                                      Never used RAM 3244, free system stack 71 words
                                      Tasks: Move(3,nWait 7,0.2%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.9%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:18:00 ago, cause: power up
                                      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 63028, writes 1, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 433233
                                      Moves scheduled 3059, completed 3059, in progress 0, hiccups 227, segs 32, step errors 0, maxLate 0 maxPrep 791, maxOverdue 143, maxInc 51, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                                      Peak sync jitter -3/9, peak Rx sync delay 220, resyncs 0/0, no timer interrupt scheduled
                                      VIN voltage: min 23.7, current 24.4, max 24.9
                                      MCU temperature: min 37.5C, current 53.8C, max 53.8C
                                      Last sensors broadcast 0x00000012 found 2 64 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 21153, send timeouts 0, received 16336, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 372, adv 35617/96411
                                        @Exerqtor you said that if you pause and then extrude manually, it works. Does it work if you send a G1 command that does both movement and extrusion? What happens if you resume the print after the pause?
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          @dc42 I haven't tried doing a G1 move and extrusion, just extrude and retract with DWC or PD. I'll test that tomorrow.
                                          When i resume the printer after a pause it goes back to the print just like expected except it don't extrude. Pretty much pics up right where and as it did before the pause.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            @dc42 said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-r1:
                                            Sorry for the late reply but I've been out cold with the stomach flu the whole weekend 🤮💩
                                            Finally got around testing this today though! So I made a macro containing G1 X0.1 Y200.0 F1500.0 E15 that I ran (manually from PD) while the printer was paused after it had bugged out during the test print (printhead moves to X/Y0 when paused) and this is what happens:
                                            • The printhead moves to Y200, but don't extrude anything.
                                            • I try to manually extrude 20mm @ 5mm/s, through PD and that works.
                                            • I manually jog the printhead back too X/Y0 and try to run the "G1 macro" once more, with the same outcome ast the first time i tried.
                                            • I then manually extrude another 20mm with PD, that works.
                                            • Tries to resume the print, and it goes on like every other time with all movement and no extrusion.
                                            Here is the reports from when it's resumed after runing the above tests:
                                            	M122
                                            Used output buffers: 19 of 40 (40 max)
                                            Static ram: 103264
                                            Never used RAM 3016, free system stack 138 words
                                            Tasks: NETWORK(2,nWait 7,17.2%,226) HEAT(3,nWait 6,0.0%,342) Move(4,nWait 6,0.8%,238) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,78.7%,602) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                            Last reset 00:13:18 ago, cause: software
                                            Last software reset at 2024-03-04 17:48, reason: User, Gcodes spinning, available RAM 11908, slot 0
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 799401, completed 799401, timed out 0, errs 0
                                            MCU temperature: min 36.2, current 45.3, max 46.6
                                            Supply voltage: min 3.0, current 24.1, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/3076/2616, gc cycles 112
                                            Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 33, reads 41985, writes 33, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 33, reads 41985, writes 33, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 41997, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 22, reads 41996, writes 22, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 41997, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2024-03-04 18:01:30
                                            Cache data hit count 1235346997
                                            Slowest loop: 224.32ms; fastest: 0.09ms
                                            === Storage ===
                                            SD card longest read time 9.7ms, write time 8.2ms, max retries 0
                                            DMs created 83, segments created 38, maxWait 239837ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                            next step interrupt due in 35 ticks, enabled
                                            Moves shaped first try 288, on retry 48, too short 115, wrong shape 2458, maybepossible 56
                                            === DDARing 0 ===
                                            Scheduled moves 3621, completed 3591, hiccups 0, stepErrors 0, LaErrors 1, Underruns [0, 0, 5], CDDA state 3
                                            === DDARing 1 ===
                                            File is doing "G1 X188.12 Y188.973 E.0049" in state(s) 0
                                            check 0 clear 0
                                            === CAN ===
                                            Messages queued 10502, received 16605, lost 0, errs 1286, boc 0
                                            Longest wait 6ms for reply type 6013, peak Tx sync delay 4831, free buffers 26 (min 25), ts 3995/3993/0
                                            === Network ===
                                            Slowest loop: 10.65ms; fastest: 0.00ms
                                            === WiFi ===
                                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42692
                                            M122 B121
                                            Never used RAM 3160, free system stack 71 words
                                            Tasks: Move(3,nWait 7,0.1%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,91.0%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                            Owned mutexes:
                                            Last reset 00:13:21 ago, cause: VDD brownout
                                            Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 7118, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 392533
                                            Moves scheduled 2791, completed 2791, in progress 0, hiccups 111, segs 34, step errors 0, maxLate 0 maxPrep 873, maxOverdue 96, maxInc 41, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                                            VIN voltage: min 23.7, current 24.4, max 25.2
                                            MCU temperature: min 45.1C, current 62.9C, max 62.9C
                                            CAN messages queued 16690, send timeouts 0, received 10583, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 375, adv 35649/107889
                                            Interrupt 5726621 to 0us, poll 4 to 1730us
                                            Driver 0: ok
