What is Laser power velocity ramping??
My Duet controlled machine
318
    adhanabal
    Hello all
    Where can I read more in details about laser power velocity ramping??
    Kindly share
    undefined undefined 2 Replies Last reply 2 Mar 2024, 15:54 Reply Quote 0
      jay_s_uk @adhanabal
      @adhanabal i believe it works with the implementation in lightburn. i've not tried it though
      undefined 1 Reply Last reply 2 Mar 2024, 16:19 Reply Quote 0
        adhanabal @jay_s_uk
        @jay_s_uk oh icee, that is for laser cutter application, how about SLS 3d printer application?
        Is there any software I can use in the same way?
        undefined 1 Reply Last reply 2 Mar 2024, 16:33 Reply Quote 0
          jay_s_uk @adhanabal
          @adhanabal not that i'm aware of. for using duet boards with DLP, RRF is only used for moving the parts of the printer about and not for controlling the actual printing of the parts
            dc42 administrators @adhanabal
            @adhanabal I suspect you mean laser power ramping. This refers to increasing the laser power as the XY speed increases, and reducing it as the speed reduces, for example at corners. RepRapFirmware does this automatically.
            undefined undefined 3 Replies Last reply 3 Mar 2024, 08:42 Reply Quote 1
              jay_s_uk @dc42
              @dc42 ah, I was thinking of raster clustering
                adhanabal @dc42
                @dc42 oh i cee if use extruder output to control the laser , will it work?
                Because I use simplyfi3d for slicing
                And
                M571 P"out9" F200 S255
                In my config
                  adhanabal @dc42
                  @dc42 said in What is Laser power velocity ramping??:
                  @dc42 awaiting your response
                  undefined 1 Reply Last reply 6 Mar 2024, 08:34 Reply Quote 0
                    gloomyandy @adhanabal
                    @adhanabal The system is very simple. If the velocity of the move is zero to begin with then the laser intensity will also be zero, as the laser head accelerates up to the requested move speed then the laser intensity value also increases in a linear fashion such that when/if full speed is reached the intensity will be the requested value. The same thing happens with deceleration. The recommended way to set laser intensity values is using the S parameter to G1 moves.
                    4 out of 9
