    "Warning: Driver 0 stall"
    • Juan Estanislaoundefined
      Juan Estanislao
      Hello everyone.
      After a lot of work I managed to finish the 3D printer. And everything works correctly, and the prints come out well. The only problem that persists is a message that continually appears on the screen. "Warning: Driver 0 stall"
      This message appears with both driver 0 and driver 1, both motors are the extruders found in the print head.
      This message appears when it has been running for a while.
      Please note that I have heated the chamber.
      Could you please tell me what this message is about?
      On the other hand, could you tell me how I can at least remove the message from the screen? It comes up so many times in a row that I can't use the screen when the message is on the screen.
      Another message that I would like to remove from the screen or make it appear less often is the one that tells me that it is not connected to Wi-Fi.
      Do you know how I can solve this problem?
      Thank you very much for the help.
      • jens55undefined
        jens55 @Juan Estanislao
        @Juan-Estanislao
        Nice build! Sorry, can't help with the question.
        Juan Estanislaoundefined 1 Reply Last reply Reply Quote 0
        • oliofundefined
          oliof
          @Juan-Estanislao I guess you enabled stall detect on the machine and you get stall messages, which might come from Pressure Advance, Retracts, or filament change macros.
          To help sort out what this is, please share your configuration files.
          Juan Estanislaoundefined 2 Replies Last reply Reply Quote 0
            Juan Estanislao @jens55
            @jens55 Thank you very much for your comment.
              Juan Estanislao @oliof
              @oliof
              Thank you very much for your answer. Right now I don't have the files, but as soon as I have them I'll buy them without a problem.
              Thank you very much in advance.
                @oliof I am very sorry that it took me so long to respond to you, but I have not been able to access the printer until today.
                As you requested, I will show you the configuration file.
                ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Nov 24 2022 23:03:50 GMT+0100 (hora estándar de Europa central)
                M550 P"Estanisleitor 2P" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P3 S0 ; physical drive 3 goes forwards
                M569 P4 S1 ; physical drive 4 goes forwards
                M584 X0 Y1 Z2 E3:4 ; set drive mapping
                M92 X239.65 Y240.15 Z2402.00 E427.9:427.9 ; set steps per mm
                M566 X900.00 Y900.00 Z400.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z400.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                M201 X200.00 Y200.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                M906 X1700 Y1700 Z1700 E1100:1100 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X-39 Y0 Z0 S1 ; set axis minima
                M208 X462 Y378 Z419 S0 ; set axis maxima
                M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                :Z-Probe
                M950 S0 C"exp.heater3"
                M558 P9 C"^zprobe.in" H3 F300 T6000 ; FW v3 BLTouch connected to Z probe IN pin
                G31 P500 X61.2 Y8.4 Z0.64 ; Set Z probe trigger value, offset and trigger height Incrementar el valor = acercar la mesa de impresión.
                M557 X24:460 Y11:376 S60 ; Define mesh grid
                M915 X Y S5 R2
                M950 H6 C"nil" ; Disable heaters H3-H7 to free up pins
                M308 S0 P"e0temp" Y"pt1000" ; configure sensor 0 as PT1000 on pin e0temp
                M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
                M570 H0 P400 T400
                M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                M143 H0 S420 ; set temperature limit for heater 0 to 450C
                M308 S1 P"e1temp" Y"pt1000" ; configure sensor 1 as PT1000 on pin e1temp
                M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
                M570 H1 P400 T400
                M143 H1 S420 ; set temperature limit for heater 1 to 450C
                M308 S2 P"bedtemp" Y"pt1000" R4700 ; configure sensor 2 as PT1000 on pin bedtemp
                M950 H2 C"bedheat" T2 ; create bed heater output on bedheat and map it to sensor 2
                M307 H2 B0 S1.00; disable bang-bang mode for the bed heater and set PWM limit
                M570 H2 P1200 T90 ; comando añadido porque tarda mucho en calentar la cama y daba error
                M140 H2 ; map heated bed to heater 2
                M143 H2 S130 ; set temperature limit for heater 2 to 180C
                Cámara
                M308 S3 P"e3temp" Y"pt1000" R4700 ; configure sensor 3 as PT1000 on pin duex.e2temp
                M950 H4 C"exp.heater4" T3 ; create chamber heater output on duex.e3heat and map it to sensor 3
                M307 H4 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
                M570 H4 P4200 T110
                M141 H4 ; map chamber to heater 3
                M143 H4 S70 ; set temperature limit for heater 3 to 90C
                Ventiladores
                Ventilador de pieza
                M106 P0 C"Ventilador De Pieza" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                Bomba de agua y ventilador radiador
                M308 S4 P"e4temp" Y"pt1000" R4700 ; configure sensor 4 as PT1000 on pin duex.e5temp
                M106 P1 C"Ventilador De Cabezal" T60 H4 X1 ; set fan 1 name and value. Thermostatic control is turned on
                Ventilador Filtro Cámara
                M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                M106 P2 C"Ventilador De Cámara" T60 H3 X1 ; set fan 2 name and value. Thermostatic control is turned on
                Ventilador Cabezal soplador
                M308 S5 P"e5temp" Y"pt1000" R4700 ; configure sensor 5 as PT1000 on pin duex.e6temp
                M308 S6 P"e6temp" Y"pt1000" R4700 ; configure sensor 6 as PT1000 on pin duex.e7temp
                M950 F3 C"exp.heater7" Q500 ; create fan 1 on pin fan1 and set its frequency
                M106 P3 C"Soplador Cabezal" T40 H5:6 X1 ; set fan 1 name and value. Thermostatic control is turned on
                Bomba Aire MotorY
                M308 S7 P"e2temp" Y"pt1000" R4700 ; configure sensor 6 as PT1000 on pin duex.e7temp
                M950 F4 C"exp.heater5" Q500 ; create fan 1 on pin fan1 and set its frequency
                M106 P4 C"Bomba Aire MotorY" T50 H7 X1 ; set fan 1 name and value. Thermostatic control is turned on
                M563 P0 S"Material Base" D0 H0 F1 ; define tool 0
                M563 P1 S"Soporte" D1 H1 F1 ; define tool 1
                G10 P1 X38 Y0 Z0 ; set tool 1 axis offsets
                M591 D0 P2 C"e0stop" S1 ; Final de Filamento extrusor 0
                M591 D0 P2 C"e1stop" S1 ; Final de Filamento extrusor 1
                T0 ; select first tool
