Accelerometer not found.
478
    Festivejelly @droftarts
    @droftarts Tried it both ways, even tried it on the duetx5 expansion board. Nothing. I think the sensor is just dead out of the box. Waiting for a generic LIS3DH to come and ill try wire that in instead.
    undefined 1 Reply Last reply 22 Mar 2024, 23:18 Reply Quote 0
      Festivejelly @Festivejelly
      So I just connected a generic accelerometer and it works fine. Sot he duet one was basically dead from the store. I got it from oozenest I guess I need to contact them for a return?
        Festivejelly
        Got a "new" duet accelerometer from Oozenest.. version 0.2 (which i think is actually the old version) dead too. No LED nothing (with the provided cable) but yet I can plug in a generic accelerometer and it works and detects it fine.
          That's quite strange. Can you send some photos of your setup?
          undefined 1 Reply Last reply 14 Apr 2024, 13:45 Reply Quote 0
            Festivejelly @Phaedrux
            @Phaedrux Will do ill take some later. Its an e3d tool changer and im plugging it into the main board with the supplied cable. As I said before I managed to get a no brand accelerometer to work by using the same supplied duet 3d cable then just branching off some duponts. But when I try to plug either duet 3d accelerometer into the cable nothing happens no lights, and a message saying it cannot find the accelerometer 😞
            Ill take some pics and upload them later.
            undefined undefined 3 Replies Last reply 14 Apr 2024, 16:06 Reply Quote 0
              jay_s_uk @Festivejelly
              @Festivejelly you need to be running 3.5RC1 (I think) or later for the new accelerometer too
                myersm1234
                Hello all, I am having the same issue. I have done everything above. I have a green light thought. Tried it on both Duet 2 wifi and Duex 5. I've also tried a 1k resistor, different cable same length and shorter about 12" and still not found.
                undefined 1 Reply Last reply 15 Apr 2024, 04:09 Reply Quote 0
                  Phaedrux Moderator @myersm1234
                  @myersm1234 Best to start a new thread for your issue.
                    myersm1234
                    Will do. Thanks
                    undefined 1 Reply Last reply 18 Apr 2024, 17:45 Reply Quote 0
                      droftarts administrators @Festivejelly
                      @Festivejelly Can you confirm what firmware version you are using? Please send M115 in the console and paste the response. If you are still on 3.4.5, neither a v0.2 nor v1.0 accelerometer will work. Thought the lack of green power LED does indicate it's not getting power.
                        @Festivejelly Can you have a look at the tests I posted here https://forum.duet3d.com/post/337624, and see if it helps? Otherwise, I think a(nother) warranty replacement is in order.
                        If so, please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                          Festivejelly @myersm1234
                          @droftarts Its 3.4.6 i notice 3.5 was release today so ill upgrade to that to see if that helps. Ill also try your tests.
                          undefined 1 Reply Last reply 8 May 2024, 15:14 Reply Quote 0
                            @Festivejelly Have you made any progress on getting your accelerometer connected? Do you have a PanelDue connected? If so, are you using both cables (ie ribbon and 4-wire)? @myersm1234 found in his thread https://forum.duet3d.com/topic/35460/accelerometer-not-found-on-specified-port/33 that disconnecting the PanelDue ribbon cable fixed it for him, though I was not able to replicate the problem in my bench setup.
