    fail to establish connection between 6HC and multiple 1XD boards
    253
    • gloomyandyundefined
      gloomyandy @Joseph
      @Joseph Just to be clear when you tested the boards with just a single board connected to the mainboard, did you also enable the terminating resistor on the board under test?
      Josephundefined 1 Reply Last reply Reply Quote 0
      • Josephundefined
        Joseph @gloomyandy
        @gloomyandy I tested a single board just 1 hour ago, I checked the terminating resistor and I did enable it, but it still doesn't work😢
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
          gloomyandy @Joseph
          @Joseph I'm pretty much out of suggestions, in the single board test did it show any sign of syncing correctly? I suppose the only other thing to try would be maybe to use a single board and a different cable?
          • Josephundefined
            Joseph @gloomyandy
            @gloomyandy the single board did syncing when connecting at first, but suddenly it lost the connection, it is not stable. Thanks for your suggestions 😊
            gloomyandyundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
              gloomyandy @Joseph
              @Joseph Hmm that's unusual. I'd be looking very closely at the cables and the plugs/sockets (and possibly the soldering around them), if all of your 1XD boards when tested alone (and with different cables) do the same thing I'd be looking very carefully the the socket on the mainboard. But maybe the Duet folks have some other suggestions?
                jay_s_uk @Joseph
                @Joseph please provide a photo showing the single board setup wiring as well as the basic config you are using to test the connection.
                Also provide the output of M122 and M122 BX, where X is the CAN address of the board you are trying
                • Josephundefined
                  Joseph @jay_s_uk
                  Hi here are the photos. It is very wired, sometimes the board can flash synchronously, but when I send M115 code, it seems that the mainboard can't read it.
                  I guess maybe the mainboard failed?
                  BTW I posted all my confiig.g code above, which has a black background .
                  jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @Joseph
                    @Joseph you might want to unplug everything and start again. but i don't know how much further traction you'll get with support knowing they are cloned boards.
                      droftarts administrators @Joseph
                      @Joseph Is your 6HC a clone board as well?
                      • Josephundefined
                        Joseph @droftarts
                        @droftarts yes
                        • Josephundefined
                          Joseph @jay_s_uk
                          @jay_s_uk ok, thanks for your helping!
                            @Joseph If you can't connect to DWC over the network, that would seem to be more related to the Raspberry Pi (or whatever SBC you are using). For the board, it's hard to say what has changed that has caused this failure. It's possible something has failed on the 6HC, but given that it has come at the same time as the SBC losing network connection, perhaps that's the place to start looking.
                            As all your boards are clones, there's not much more I can do to help.
                            • Josephundefined
                              Joseph @droftarts
                              @droftarts thanks for your helping!
