Accelerometer not found on specified port
Here is what I have.
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.0-rc.3 ELECTRONICS: Duet WiFi 1.02 or later + DueX5v0.11 FIRMWARE_DATE: 2024-01-24 17:56:24
Tried on Duet 2 board with daughter board removed
M955 P0 C"spi.cs2+spi.cs1" I61 .
No Luck! -
@jay_s_uk any thoughts on what might be my problem?
@myersm1234 did you disable the temp sensors in your config as well when trying without the temp daughterboard?
This post is deleted! -
@jay_s_uk yes I did
@droftarts do you have any more suggestions ?
@myersm1234 when you send M955 P0 C"spi.cs2+spi.cs1" I61 in the console, what does it actually report? And when you send M955 P0 after?
@droftarts This is what I get
M955 P0
Error: M955: Accelerometer not found; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.4+1 on Sat Apr 13 2024 14:49:41 GMT-0400 (Eastern Daylight Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"My Printer" ; set hostname M911 S12 R12.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ; Accessories M575 P1 S0 B57600 ; configure PanelDue support ; Network M552 S1 ; configure WiFi adapter M586 P0 S1 ; configure HTTP ; Accelerometers M955 P0 C"spi.cs2+spi.cs1" I61 ; configure accelerometer on board #0 ; Smart Drivers M569 P0 S0 D2 ; driver 0 goes backwards (X axis) M569 P1 S0 D2 ; driver 1 goes backwards (Y axis) M569 P4 S1 D2 ; driver 4 goes forwards (extruder 0) M569 P6 S1 D2 ; driver 6 goes forwards (Y axis) M569 P7 S0 D2 ; driver 7 goes backwards (Z axis) M569 P8 S0 D2 ; driver 8 goes backwards (Z axis) M569 P9 S0 D2 ; driver 9 goes backwards (Z axis) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0 Y1:6 Z7:8:9 ; set axis mapping M671 X7:320:500 Y145:500:145 S99 M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X1200 Y1200 Z1200 ; set axis driver currents M92 X106.67 Y106.67 Z400 ; configure steps per mm M208 X0:500 Y0:500 Z0:450 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z180 ; set maximum speeds (mm/min) M201 X600 Y600 Z200 ; set accelerations (mm/s^2) ; Extruders M584 E4 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1200 ; set extruder driver currents M92 E282.94 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ; Kinematics M669 K0 ; configure Cartesian kinematics ; Probes M558 K0 P9 C"^zprobe.in" H5 F6000:120:120 T18000 ; configure BLTouch probe via slot #0 G31 P500 X0 Y0 Z3.6 ; set Z probe trigger value, offset and trigger height M950 S0 C"duex.pwm1" ; create servo #0 for BLtouch ; Endstops M574 X1 P"xstop" S1 ; configure X axis endstop M574 Y1 P"ystop" S1 ; configure Y axis endstop M574 Z1 S2 ; configure Z axis endstop ; Mesh Bed Compensation M557 X25:475 Y25:475 S50:50 ; define grid for mesh bed compensation ; Sensors M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 ; configure sensor #1 ; Heaters M950 H0 C"bedheat" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 M950 H1 C"e0heat" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H0 R0.418 K0.0323:0.000 D1.35 E1.35 S1.00 B0 ; configure model of heater #1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"fan0" ; create fan #0 M106 P0 S0 L0 X1 B1 ; configure fan #0 M950 F1 C"fan1" ; create fan #1 M106 P1 S0 B1 H1 T45 ; configure fan #1 M950 F2 C"fan2" ; create fan #2 M106 P2 S0 L0 X1 B1 ; configure fan #2 ; Tools M563 P0 S"Micro Swiss" D0 H1 F1 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ; Miscellaneous T0 ; select first tool
@myersm1234 Can you send
M98 P"config.g"
and post the response? This should run config.g and show any errors.It may be worth trying with the ribbon cable between the Duet and Duex disconnected, too.
I should be getting a Duet3D accelerometer in the next couple of days, I'll set it up as you have and test.
@droftarts Thank you sir, I will get this done tomorrow night.
@droftarts said in Accelerometer not found on specified port:
This is with the Duex5 disconnected.
M98 P"config.g"
HTTP is enabled on port 80
Error: Accelerometer not found on specified port
Error: Driver 6 does not support mode 'spreadCycle'
Error: Driver 7 does not support mode 'spreadCycle'
Error: Driver 8 does not support mode 'spreadCycle'
Error: Driver 9 does not support mode 'spreadCycle'
Warning: Heater 0 predicted maximum temperature at full power is 321°C
Warning: Sensor number 1 has not been defined
Warning: Heater 0 predicted maximum temperature at full power is 691°C
Error: Heater 1 not switched on due to bad model -
@myersm1234 I have replicated your setup on my bench, with a Duet 2 WiFi and Duex, using RRF 3.5.0-rc.3 and a copy of your config.g
I tested with the accelerometer plugged into the Duet directly first, then the Duex. I plugged in a PT100 board and a thermocouple board, and tested with the accelerometer in those, too, updating the accelerometer configuration in all positions:
18/04/2024, 13:54:43 M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.0-rc.3 ELECTRONICS: Duet WiFi 1.02 or later + DueX5v0.11 FIRMWARE_DATE: 2024-01-24 17:56:24 18/04/2024, 13:55:19 M955 P0 Accelerometer 0 type LIS2DW with orientation 61 samples at 1600Hz with 14-bit resolution, SPI frequency 2000000 18/04/2024, 13:59:40 M955 P0 C"spi.cs6+spi.cs5" I61 18/04/2024, 13:59:45 M955 P0 Accelerometer 0 type LIS2DW with orientation 61 samples at 1600Hz with 14-bit resolution, SPI frequency 2000000 18/04/2024, 14:00:32 G92 X0 Y0 Z0 18/04/2024, 14:00:41 G4 S1 Error: Attempt to move motors when VIN is not in range 18/04/2024, 14:03:56 M955 P0 C"spi.cs4+spi.cs3" I61 18/04/2024, 14:04:01 M955 P0 Accelerometer 0 type LIS2DW with orientation 61 samples at 1600Hz with 14-bit resolution, SPI frequency 2000000 18/04/2024, 14:04:14 M955 P0 C"spi.cs2+spi.cs1" I61 Error: M955: Accelerometer not found on specified port 18/04/2024, 14:05:08 M955 P0 C"spi.cs8+spi.cs7" I61 18/04/2024, 14:05:14 M955 P0 Accelerometer 0 type LIS2DW with orientation 61 samples at 1600Hz with 14-bit resolution, SPI frequency 2000000
As you can see, it was recognised when plugged in in all places! I was able to record motion profiles in the Input Shaping plugin in DWC and view them; these are the 'Error: Attempt to move motors when VIN is not in range' messages, as obviously I don't have any motors connected. I could wave the accelerometer around and it picked up the movement.
So I don't think this is a firmware or configuration issue, and looks like a hardware fault. I think the chances of both your Duet and Duex Temp_DB inputs failing is remote, especially as you have run temperature daughterboards in the past, and that either the cable or the accelerometer is faulty. If you have a multimeter, you could check the cable for continuity of each wire.
However, I think it would be best to swap your accelerometer for a new one. Where and when did you purchase it?
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.Ian
@droftarts Thanks Ian, I really appreciate your help with this.
Thanks again! Mike -
@droftarts Looks like I bought it at Spool3d on Oct.20/23, but just getting to install it now...lol. Probably not worth the effort for warranty, for the cost of a new one.
@myersm1234 Up to you! But it would be good to get it back and find out why it's not working.
@droftarts Hello I received a new accelerometer. Unfortunately I'm having the same issue. Could it be the Duet 2 board? Everything else seems to work with the board though.
Can you take the board out of the printer and test it on a bench setup with nothing else connected?
Also, 3.5.1 firmware is out now, have you updated?
@Phaedrux No I haven't done the update. I will do this before I put it on the bench
@Phaedrux Same thing with the update. If I just unplug everything from the board in place, this should give the same result as on the bench correct?
@Phaedrux With everything unplugged it is recognized on both boards. I guess I'll start plugging things back.
