    RRF[3.5.1]/RRF[3.5.0] : Gcode bad command error
    448
    • JayTundefined
      JayT
      @Phaedrux :
      If I simulate the gcode, I get some errors like bad command or message box stating expected integer after Y.
      Sometimes error says "C1 " instead of G1. When I look back at the line number in Gcode, Line looks ok.
      Because when I run it the second time, or simulate second time, bad command error either does not come at all, or it comes at a different line.
      My problems are similar as posted in the thread :
      https://forum.duet3d.com/topic/35553/bad-command-error-using-rrf-3-5-0-and-3-5-1-using-duet2-wifi/2
      1. I tried with different versions of cura, problem remains same.
      2. Everytime line number and error changes for bad command, even during simulating
      3. I tried 3.5RC4, such problems are not faced before 3.5.0.
      • chrishammundefined
        chrishamm administrators @JayT
        @JayT What board do you have and can you share the affected G-code file?
        Duet software engineer
        JayTundefined 1 Reply Last reply Reply Quote 0
        • JayTundefined
          JayT @chrishamm
          @chrishamm :
          I am using Duet 2 wifi. Will share a few gcode files. As stated, this problem isn't in 3.5 RC4 much.
          I am not able to upload gcode file directly. How do I share?.
            Phaedrux Moderator @JayT
            @JayT said in RRF[3.5.1]/RRF[3.5.0] : Gcode bad command error:
            How do I share?.
            dropbox or some sort of cloud storage if it's too large to upload
            • JayTundefined
              JayT @Phaedrux
              @Phaedrux : @chrishamm : It uploaded well please see with RRF 3.5.1version.
              1. 30mmTestCube_44MIN.gcode
              2. CFFFP_Flex_Dino_Keychain.gcode
              3. PCB COVER_500_5_15H.gcode
                droftarts administrators @JayT
                @JayT this sounds more like an SD card reading problem. Check SD card isn’t nearly full, back it up, then reformat it or try a fresh SD card. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                • JayTundefined
                  JayT @droftarts
                  @droftarts :
                  I will check on this , however...If its SD card issue, then why don't I get same problem when I flash 3.5 RC4/3 or on older version of RRF, for the same gcode file?
                  Can you try to simulate them in your printer with RRF3.5.1 for once, with Duet 2 wifi?
                    @JayT I need to do a test Duet 2 setup next week anyway (I don’t have any printers running Duet 2 any more, only a 2D plotter), so will try simulating your files then.
                    Can you share your config.g, and any other files that config.g depends on (ie macros called) and daemon.g if used? Then I can set my Duet up the same, just with nothing physically connected.
                    In the meantime, try a different SD card. I don’t know if there’s been any changes to the SD card read/write code between 3.5.1 and older firmware that makes marginal cards fail, but there may be.
                    JayTundefined 1 Reply Last reply Reply Quote 1
                    • JayTundefined
                      JayT @droftarts
                      @droftarts : Please see config below. I am not using daemon.g
                      G90
                      M83
                      M550 P"INFD300s"
                      M551 P"INFD300"
                      ;M552 S1
                      M552 S-1
                      M586 P0 S1
                      M586 P1 S0
                      M586 P2 S0
                      M569 P0 S1
                      M569 P1 S1
                      M569 P2 S1
                      M569 P3 S1
                      M569 P4 S1
                      M569 P5 S1
                      M584 X0 Y1 Z2:3:4 E5
                      M350 X32 Y32 I0
                      M350 Z16 E16 I1
                      M92 X160.0 Y160.0 Z2133.33 E932.00
                      ;change as per machine
                      M566 X720.00 Y720.00 Z300.00 E600.00
                      M203 X8400.00 Y8400.00 Z420.00 E8400.00
                      M201 X3000.00 Y3000.00 Z30.00 E250.00
                      ;M-curr
                      M906 X2200 Y2200 Z1600 E800 I50
                      M84 S30
                      M208 X0 Y0 Z0 S1
                      M208 X300 Y300 Z304.1 S0
                      ; filament Sensor
                      M591 D0 P7 C"exp.e3stop" R15:300 L7 E17 S1
                      M574 X1 S1 P"xstop"
                      M574 Y1 S1 P"ystop"
                      M574 Z1 S1 P"zstop+e0_stop+e1_stop"
                      M950 S0 C"exp.heater3"
                      M558 P9 C"^zprobe.in" H5 F120 T6000
                      G31 P500 X0 Y0 Z1.038
                      ; Auto level, coordinates as per motor order in M584
                      M671 X-17.66:297.34:140.00 Y-5.00:-5.00:327.61 S5.0  ;points position with left right &center
                      ; define mesh grid
                      M557 X30:300 Y30:300 S20
                      M376 H5
                      ; End Limits
                      M950 J1 C"exp.e4stop"
                      M581 P1 T2 R0 S1
                      M582 T2
                      M581 P-1 T2
                      M581 P1 T0 R0 S1
                      ;PA
                      M572 D0 S0.055
                      ; Bed Heater
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138
                      M950 H0 C"bedheat" T0
                      M307 H0 B0 S1.00
                      M140 H0
                      M143 H0 S105
                      ; Extuder Heater
                      M308 S1 P"e0temp" Y"pt1000"
                      M950 H1 C"e0heat" T1
                      M307 H1 B0 S1.00
                      M143 H1 S320
                      ; cooling Fans
                      M950 F0 C"fan0" Q500
                      M106 P0 S0 H-1
                      M950 F1 C"fan1" Q500
                      M106 P1 S0 H-1
                      M563 P0 D0 H1 F0
                      G10 P0 X0 Y0 Z0
                      G10 P0 R0 S0
                      M575 P1 S1 B57600
                      M501
                      M911 S21 R22.5 P"M913 X0 Y0 G91 M83 G1 Z5 E-5 F1000"
                      M929 S3 P"/macros/log/DEBUG.txt"
                      M17
                        ;M552 S1
                        M552 S-1
                        I notice you are not enabling networking. Are you running the simulation from a PanelDue?
                        Is there a reason you're running debug logging? This will impact performance, and means a lot of writes to the SD card. It could be that the level of logging has increased in 3.5.1, and is causing what was a marginal problem on the SD card to become a real one.
                        I set up a bench test, with a Duet 2 WiFi on RRF 3.5.1 and PanelDue, powered by USB, with your config.g. I enabled networking. I simulated all three files, which all completed fine.
                        08/05/2024, 16:24:30 	M37 P"0:/gcodes/1714799702668-30mmtestcube_44min.gcode"
                        Simulating print of file 0:/gcodes/1714799702668-30mmtestcube_44min.gcode
                        08/05/2024, 16:24:35 	File 0:/gcodes/1714799702668-30mmtestcube_44min.gcode will print in 0h 45m plus heating time
                        08/05/2024, 16:24:50 	M37 P"0:/gcodes/1714799702737-cfffp_flex_dino_keychain.gcode"
                        Simulating print of file 0:/gcodes/1714799702737-cfffp_flex_dino_keychain.gcode
                        08/05/2024, 16:26:36 	File 0:/gcodes/1714799702737-cfffp_flex_dino_keychain.gcode will print in 1h 31m plus heating time
                        08/05/2024, 16:26:48 	M37 P"0:/gcodes/1714799702831-pcb-cover_500_5_15h.gcode"
                        Simulating print of file 0:/gcodes/1714799702831-pcb-cover_500_5_15h.gcode
                        08/05/2024, 16:29:41 	File 0:/gcodes/1714799702831-pcb-cover_500_5_15h.gcode will print in 5h 44m plus heating time
                        Looking at the DEBUG.txt file the logging created, there's a lot of writes during simulation. I think this is causing a degraded SD card problems. Please try with a new SD card.
                        • JayTundefined
                          JayT @droftarts
                          @droftarts :
                          @droftarts said in RRF[3.5.1]/RRF[3.5.0] : Gcode bad command error:
                          Yes, I ran simulation via PanelDue, not from DWC.
                          Thanks for trying. If gcode simulated well, ***Will try with new SD card.
                          Is that so for 3.5.1? I am writing to SD card with debugging enabled, to debug problems if faced during printing. This log file helps me to understand at times if the print fails or there are problems w.r.t gcode, if dwc isn't connected.
                          What solution do you propose then? Is there a way to create log some other memory place?
                          • JayTundefined
                            JayT @JayT
                            @droftarts :
                            I see this is happening only with 1/2 versions of cura generated Gcode. If I use latest Cura version gcode, I don't see this problem much. However, I will see if stopping the log , helps anyway.
                            Also, I do see that this problem does not appear in previous versions of RRF. May be something is changed w.r.t certain gcode interpretation.
                            @Phaedrux : Please mark this as solved.
                            • droftartsundefined droftarts has marked this topic as solved
