mainboard 6d not answering
Is your computer on the same subnet as the Duet? 192.168.1
@Phaedrux where do i see that?
I don't have any information about your computer/os setup, but you should be able to find directions from a quick google to determine your internal IP address.
@Phaedrux it is not the same
@Phaedrux how do i change it?
The computer must be connected to the same network as the Duet to be able to communicate with it.
@Phaedrux i don't understand, i only have one network
What is the IP address of your computer?
@Phaedrux it is 10.0.0.14 i think
If that is your internal IP address then your Duet isn't on the same network.
@Phaedrux if i connect my pc and the mainboard with an ethernet wire it should be the same right?
Yes, you can follow the directions here
https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
@Phaedrux it says permission denied when i try to connect to the mainboard by CuteCom
@Phaedrux i got it, thank you for all the help
