    mainboard 6d not answering
    Firmware installation
    714
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux where do i see that?
        I don't have any information about your computer/os setup, but you should be able to find directions from a quick google to determine your internal IP address.
        zecretonundefined 2 Replies Last reply Reply Quote 0
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux it is not the same
          • zecretonundefined
            zecreton @Phaedrux
            @Phaedrux how do i change it?
              The computer must be connected to the same network as the Duet to be able to communicate with it.
              zecretonundefined 1 Reply Last reply Reply Quote 0
              • zecretonundefined
                zecreton @Phaedrux
                @Phaedrux i don't understand, i only have one network
                  What is the IP address of your computer?
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux it is 10.0.0.14 i think
                      If that is your internal IP address then your Duet isn't on the same network.
                      • zecretonundefined
                        zecreton @Phaedrux
                        @Phaedrux if i connect my pc and the mainboard with an ethernet wire it should be the same right?
                          Yes, you can follow the directions here
                          https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux it says permission denied when i try to connect to the mainboard by CuteCom
                            • zecretonundefined
                              zecreton @zecreton
                              @Phaedrux i got it, thank you for all the help
