    SFS V2.0 to Duet 3 Mini
    485
    • SonnyD1undefined
      SonnyD1 @jay_s_uk
      @jay_s_uk I've since switched to another Filament Runout sensor. Now I'm using :
      Creativity 3D Printer Filament Detection Sensor Module Filament Run-Out Pause Detecting Monitor for 3D Printer Lerdge Board 1.75mm Filament (Black) https://a.co/d/dzyfMmf
      • SonnyD1undefined
        SonnyD1
        Guys I really need to get this resolved. I know it's kind of a weird issue. Right now,I have a printer that's unusable. I've done everything that I know how to do.
          Have you tried 3.5.2 that was just released?
          SonnyD1undefined 2 Replies Last reply Reply Quote 0
          • SonnyD1undefined
            SonnyD1 @Phaedrux
            @Phaedrux Ok I just updated to 3.5.2. It eliminated the error but the switch still isn't working. I need to verify the wiring and I'll get back with you. Thank you for your help thus far. Almost there...
            • SonnyD1undefined
              SonnyD1 @Phaedrux
              @Phaedrux I verified the wiring. It matches another machine that works perfectly. I'm at a loss yet again. Clearly I'm not as smart as I think I am. I verified that its not a bad switch by swapping it out with another. I verified the wiring matches a known functional setup and I swapped the signal and the volt wire to be sure. I'm out of ideas. If its a config issue, I can't imagine what it is. Thoughts? Do I have to run a simple switch off the same toolboard that the extruder is on?
              Proschi3Dundefined 1 Reply Last reply Reply Quote 0
              • Proschi3Dundefined
                Proschi3D @SonnyD1
                @SonnyD1 With version 3.5.2, it works perfectly. I mean my filament sensors on the Duet3 Mini and use two tool boards. Before version 3.5.2, I also got an error message unknown pin name.
                Love my Duet 3 Mini.
                https://www.instagram.com/proschi3d
                https://youtube.com/@proschi3d
                https://www.proschi3d.de
                SonnyD1undefined 1 Reply Last reply Reply Quote 1
                • SonnyD1undefined
                  SonnyD1 @Proschi3D
                  @Proschi78 3.5.2 fixed that error on mine as well. Now the sensor still wont work and I can't seem to get any help. I'll keep trying to fix it though. TY for the reply.
                    Can you show us exactly what switch it is, and how it's wired?
                    @SonnyD1 said in SFS V2.0 to Duet 3 Mini:
                    And you've said you've swapped in another board and it's not working either? That would seem to indicate wiring or a crimp maybe.
                    • SonnyD1undefined
                      SonnyD1 @Phaedrux
                      @Phaedrux Yea you nailed it. I went and ran another jumper wire and it worked. So I ran all new wiring. Musta been a bad crimp like you said. The LED on the switch lights up and I get a filament error when I remove filament just like it should. I know I'm a pain and this was a headache but I really appreciate you hangin in there with me. Sometimes the most obvious solution eludes me. TYVM!!!
                      • SonnyD1undefined
                        SonnyD1 @Phaedrux
                        @Phaedrux The filament runout error doesn't pop up on my paneldue like it does on my other printers. Only pops up on the DWC....any idea why?
                          Phaedrux Moderator @SonnyD1
                          paneldue
                          Does the PanelDue firmware match?
