    motor not moving
    MultiAxis Printing
    3.3k
    • zecretonundefined
      zecreton @Phaedrux
        droftarts administrators @zecreton
        @zecreton Maybe Bossa can't cope with the é in Téléchargements. Try moving the .bin file to a folder without accents.
        Also make sure to tick 'Erase all', 'Lock' and 'Boot to flash.
          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
          You can try the command line bossac as well.
          zecretonundefined 1 Reply Last reply Reply Quote 0
          • zecretonundefined
            zecreton @Phaedrux
            @Phaedrux that made another error "you do not have permission" when i tried to transfer the file
              Are you running with admin rights?
              • zecretonundefined
                zecreton @Phaedrux
                @Phaedrux yes
                  @zecreton what are you doing when it says you don’t have permission? Moving the file to a different folder? Is do, where are you trying to move it to? Or trying to flash the firmware?
                  • zecretonundefined
                    zecreton @droftarts
                    @droftarts i just changed it to a different folder and it worked, but for the webcontrol file it says that the file exceeds flash size
                      @zecreton so what is the capacity of ithe SD card? Often they are formatted for both standalone mode, and SBC mode, which can take up a lot of the space. If you aren’t using SBC mode (ie with an attached Raspberry Pi) then you can copy your config files off the SD card, reformat to use the full card size, then copy the config back on. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting
                      zecretonundefined 3 Replies Last reply Reply Quote 0
                      • zecretonundefined
                        zecreton @droftarts
                        @droftarts the SD card is 16GB
                        • zecretonundefined
                          zecreton @droftarts
                          @droftarts how to copy the SD files?
                          • zecretonundefined
                            zecreton @droftarts
                            @droftarts hello?
                              @zecreton Can you put the SD card in your computer? That's the easiest way to check the capacity, copy files off and format it. If you have managed to flash the firmware and can access DWC, you can also download files by highlighting all of them, right clicking and selecting 'Download as ZIP'.
                              It may say '16GB' on the SD card, but they can be formatted into smaller sections. If you have access to DWC, send M39 and post the response. I expect the partition on the SD card is full.
                              • zecretonundefined
                                zecreton @droftarts
                                @droftarts i don<t have an sd card slot and i can<t access DWC
                                  @zecreton For reading the SD card on your PC, get a Micro SD card to USB adapter from Amazon or other shop, eg https://www.amazon.co.uk/Integral-Micro-Card-Reader-USB/dp/B001JPPQS6
                                  @zecreton said in motor not moving:
                                  I may have misunderstood what you were trying to do. Did you try to flash the 'webcontrol file' to the 6XD using Bossa? Only the firmware file is flashed to the 6XD, which you already did. The webcontrol files go on the SD card. Is the 6XD working again now? If not, because you sent the 'webcontrol file' to it, re-flash with the 'Duet3Firmware_MB6XD. If it is working, DWC should still be on the SD card, and you should be able to connect to it again, same as before you erased the firmware.
                                  zecretonundefined 2 Replies Last reply Reply Quote 0
                                  • zecretonundefined
                                    zecreton @droftarts
                                    @droftarts i can't even see the mainboard port when i plug it in my computer
                                    • zecretonundefined
                                      zecreton @droftarts
                                      @droftarts does that mean it's broken?
                                        Do you mean via USB? Try a different USB cable, and/or a different port on your computer. It really would help if you gave a bit more information, and describe what you have done each time.
                                        • zecretonundefined
                                          zecreton @droftarts
                                          @droftarts it doesn't appear in the ports when i connect it, i tried a different cable and different port but it doesn't work
                                            Have you tried the reset procedure to clear the firmware again with the erase jumper?
                                            What lights are visible on the board when you connect by USB?
                                            zecretonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
