toolboard endstop problem
464
    nick9one1
    I've just replaced my toolboard as it developed a fault.
    Everything is working except my X endstop.
    I have it wired to IO1.in and GND.
    The endstop opens when pressed (tested working)
    this is my config.
    M574 X1 S1 P"121.io1.in"
    M574 Y2 S1 P"io6.in"
    M564 H1
    M950 S0 C"^121.io0.out" ; create servo pin 0 for BLTouch
    M558 P9 C"^121.io0.in" H3 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y66 Z2.55 ; set Z probe trigger value, offset and trigger height. + brings noxzzle closer to bed
    M557 X5:305 Y20:290 P8 ; define mesh grid
    When homing X I get
    G28 X
    Error: in file macro line 7: G1: Failed to enable endstops
    ; homex.g
    ; called to home the X axis
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jul 01 2021 15:51:11 GMT+0100 (British Summer Time)
    G91 ; relative positioning
    G1 H1 X-330 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 X5 F6000 ; go back a few mm
    G1 H1 X-330 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H2 Z-5 F6000 ; lower Z again
    G90 ; absolute positioning
    Noting in the code has changed relating to the end stop so it must be a hardware or wiring issue?
    I've installed the endstop plugin and X is not triggered and doesn't trigger when I manually press the endstop
    undefined 1 Reply Last reply 3 Jul 2024, 20:12 Reply Quote 0
      gloomyandy @nick9one1
      @nick9one1 What happens if you run M98 p"config.g" do you get any errors reported? After you have executed that command can you home?
      undefined 1 Reply Last reply 3 Jul 2024, 20:15 Reply Quote 0
        nick9one1 @gloomyandy
        @gloomyandy
        Thanks
        I get this;
        undefined 1 Reply Last reply 3 Jul 2024, 20:22 Reply Quote 0
          nick9one1 @nick9one1
          I've just forced a firmware update with M997 B121
          Now i dont get an error and it will attempt to home. But crashed into the endstop as it doesn't seem to be detecting it.
          endstop plugin also isn't detecting when pressed.
          undefined undefined 2 Replies Last reply 3 Jul 2024, 20:29 Reply Quote 0
            This post is deleted!
              @nick9one1 That is an old version of the firmware (3.5.0-rc.2) I'd make sure you have 3.5.2 on both boards and then test again.
              undefined undefined 2 Replies Last reply 3 Jul 2024, 20:32 Reply Quote 0
                @gloomyandy
                thanks, looks like we're on the same page. I just updated.
                No errors anymore, but the X endstop still isn't detected by the endstop monitor..
                  gloomyandy @gloomyandy
                  @gloomyandy You don't need the endstop plugin anymore. It is now built into DWC. I can't remember exactly what happens but the axis letters in the main display (that shows the position of the axis) "change" to indicate that the endstop is active. Try pressing an endstop that you know works and look at the DWC display I think it will be pretty obvious.
                  undefined undefined 2 Replies Last reply 3 Jul 2024, 20:34 Reply Quote 0
                    @gloomyandy If you are no longer getting an error then it may be there is a problem with the endstop switch or wiring?
                      @gloomyandy
                      thanks I found it. I can see the Y tool position change to green on activation.
                      For some reason X still doesn't work 😞
                      Just double checking I'm correct to have it wired to IO1.in and GND? not IO1.in and 3.3v?
                      undefined 1 Reply Last reply 3 Jul 2024, 20:39 Reply Quote 0
                        @nick9one1
                        testing the endstop with a multimeter shows its closed when not pressed and open when pressed.
                        I've temporarily disconnected it and bridged IO1.in and GND with a screwdriver - no change on the X endstop.
                        undefined 1 Reply Last reply 3 Jul 2024, 20:40 Reply Quote 0
                          @nick9one1 What happens if you bridge io1.in to 3.3V do you see it change then?
                          undefined 1 Reply Last reply 3 Jul 2024, 20:45 Reply Quote 0
                            @gloomyandy It does! But the hotend temp drops to -271 and the thermostatic fan comes on.
                            undefined 1 Reply Last reply 3 Jul 2024, 20:46 Reply Quote 0
                              @nick9one1 That does not sound good. I suggest you post your full config.g. Are you sure you briged io1.in to 3.3V and not some other pin?
                              undefined 1 Reply Last reply 3 Jul 2024, 20:48 Reply Quote 0
                                @gloomyandy
                                Yes definitely bridged to 3.3v (top two pins on the IO1 connector)
                                Here you go
                                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 02 2021 18:38:31 GMT+0800 (中国标准时间)
                                M550 P"BLV mgn Cube" ; set printer name
                                M669 K1 ; select CoreXY mode
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                G4 S1 ;wait for expansion boards to start
                                M569 P0.0 S0 D2 ; X motor runs forwards
                                M569 P0.1 S1 D2 ; Y motor runs forwards
                                M569 P0.2 S1 D2 ; physical drive 0.2 goes backwards
                                M569 P0.3 S1 D2 ; physical drive 0.2 goes backwards
                                M569 P0.4 S1 D2 ; physical drive 0.2 goes backwards
                                M569 P121.0 S1 D2 ; physical drive 121.0 goes backwards
                                M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0 ; set drive mapping
                                M92 X200.00 Y200.00 Z3200.00 E700 ; set steps per mm
                                M671 X0:290:290 Y155:62:255 S3 ; leadscrews at rear left, front middle and rear right
                                M566 X600.00 Y600.00 Z150.00 E3000.00 ; set maximum instantaneous speed changes (mm/min) - increased Z and E
                                M203 X20000.00 Y20000.00 Z2000.00 E6000.00 ; set maximum speeds (mm/min) - increased E
                                M201 X3000.00 Y3000.00 Z200.00 E5000.00 ; set accelerations (mm/s^2)
                                M906 X1600 Y1600 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 X-3:305 Y-50:305 Z-1.0:500.0
                                M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin io1.in
                                M574 Y2 S1 P"io6.in" ; configure active-high endstop for HIGH end on Y via pin io6.in
                                M564 H1 ; allow jog without homing
                                M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                                M307 H0 R0.291 C1127.4 D26.90 S1.00 ; Set PID for bed values
                                M143 H0 S100 ; set temperature limit for heater 0 to 100C
                                M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0 //0 to 1
                                M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
                                M307 H1 B0 R3.089 C258.2:154.4 D5.95 S1.00 V23.7 ; Set PID for hotend values
                                M950 F0 C"121.out2" Q80 ; create hotend fan 0 on pin toolboard out1 and set its frequency
                                M106 P0 S0 H1 T45 C"Hotend Fan" ; set fan 0 value. Thermostatic control is turned on
                                M950 F1 C"121.out1" Q250 ; create cooling fan 1 on pin toolboard out1 and set its frequency
                                M106 P1 S0 H-1 B1 C"Part Cooling Fan" ; set fan 1 value. Thermostatic control is turned off
                                M563 P0 D0 H1 F1 ; define tool 0
                                ;M563 P1 D0 H1 F1 ; define tool 1
                                ;G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                                ;G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                                ; Custom settings
                                M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                                M575 P1 B57600 S1 ; Connection to PanelDue
                                ;955 P121.0 I10 ; Accelerometer
                                ; Pressure advance
                                ;M572 D0 S0.04
                                M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                undefined 1 Reply Last reply 3 Jul 2024, 20:53 Reply Quote 0
                                  @nick9one1 I'd be checking the board and the connector in that area very closely to see if there is any sort of solder bridge or stray wire etc. bridging io1.in to gnd.
                                  Other then that I'm out of ideas, maybe one of the duet folks has some suggestions?
                                  undefined 1 Reply Last reply 4 Jul 2024, 10:04 Reply Quote 1
                                    @gloomyandy
                                    thanks for you r help with this. I removed the 1LC, reflowed the connectors with plenty of flux and cleaned with IPA - now working.
                                    undefined 1 Reply Last reply 4 Jul 2024, 10:07 Reply Quote 0
                                      @nick9one1 That's great news! Probably worth pinging @droftarts on this as I know the Duet folks like to keep track of hardware problems!
                                      undefined 1 Reply Last reply 4 Jul 2024, 11:18 Reply Quote 1
                                        @gloomyandy
                                        Well I thought it was working, but I think there is still a slight issue with the duet config or slicer.
                                        The hotend fan turns on correctly at 45C
                                        But the part cooling fan doesn't start automatically. If I use the fan slider once the print has started it does work.
                                        The slicer is set to enable it at layer two.
                                        jay_s_ukundefined droftartsundefined 2 Replies Last reply 4 Jul 2024, 11:32 Reply Quote 0
                                          jay_s_uk @nick9one1
                                          @nick9one1 change
                                          to
                                          M950 F1 C"121.out2" Q80 ; create hotend fan 0 on pin toolboard out1 and set its frequency
                                          M106 P1 S0 H1 T45 C"Hotend Fan" ; set fan 0 value. Thermostatic control is turned on
                                          M950 F0 C"121.out1" Q250 ; create cooling fan 1 on pin toolboard out1 and set its frequency
                                          M106 P0 S0 H-1 B1 C"Part Cooling Fan" ; set fan 1 value. Thermostatic control is turned off
                                          Slicers expect the part cooling fan as fan 0
                                          undefined 1 Reply Last reply 4 Jul 2024, 11:44 Reply Quote 0
                                          4 out of 25
