    motor not moving
    MultiAxis Printing
    3.3k
      Can you take a screen shot of what your root folders look like on the SD card?
      Is there a folder named WWW?
      Download this zip file
      https://github.com/Duet3D/DuetWebControl/releases/download/v3.5.2/DuetWebControl-SD.zip
      Extract the contents into the WWW folder. Replacing the files that are there if they are there.
      Try connecting again.
      zecretonundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
      • zecretonundefined
        zecreton @Phaedrux
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux there is already a file named DuetWebControl-SD.zip, is that normal?
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in motor not moving:
            zecretonundefined 1 Reply Last reply Reply Quote 0
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux so the only files that should be left in www are the ones in the dwc sip file?
              • zecretonundefined
                zecreton @zecreton
                @zecreton *zip
                  Yes. You can delete the entire contents of the WWW folder and replace it with the contents of the zip file.
                  zecretonundefined 3 Replies Last reply Reply Quote 0
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux i did it, the status light is now flashing again, but i still can't access dwc
                    • zecretonundefined
                      zecreton @Phaedrux
                      @Phaedrux nvm it's all working, it's just that the ip adress changed
                      • zecretonundefined
                        zecreton @Phaedrux
                        @Phaedrux im pretty sure the driver is the problem, bc from what we tested before deleting the firmware, the mainboard was sending signals but not the driver
                          Phaedrux Moderator @zecreton
                          @zecreton said in motor not moving:
                          @droftarts you think it could be the motor? i have another motor i could try it with
                          So we're back to here then?
                          zecretonundefined 2 Replies Last reply Reply Quote 0
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux yea, but i already tried another motor but not the driver
                            • zecretonundefined
                              zecreton @Phaedrux
                              @Phaedrux i tried another driver, it still doesn't work
                                Can you be more detailed on what you've actually changed?
                                • zecretonundefined
                                  zecreton @Phaedrux
                                  @Phaedrux i had another driver that is smaller and goes with a smaller motor, so i changed both but kept the same wires
                                    Please more detail than that. When you changed drivers, did you change the config.g to map the axis to the other driver? Did you alter the motor current to match the driver? Photos of your wiring?
                                    The more detail you provide the better chance we have of understanding what is going wrong.
                                    • zecretonundefined
                                      zecreton @Phaedrux
                                      • zecretonundefined
                                        zecreton @Phaedrux
                                        @Phaedrux i didn't change the config.g file and i didn't change the motor current and idk how to do that
                                        • zecretonundefined
                                          zecreton @Phaedrux
                                          Idk what to put there
                                            Sorry I forgot you were working with external drivers here.
                                            As this thread has grown to nearly 100 posts and has involved several issues, I think it may be best if you can create a new thread with a detailed restatement of your current issue. Please include the basic details of your setup and the hardware used. Please include your config.g as well.
