    BIQU microprobe issues
    1.3k
      jay_s_uk @Craigrobbo
      @Craigrobbo ok, let's reset. Post the current code you are using.
      Also, consider upgrading to 3.5.2
      Craigrobboundefined 3 Replies Last reply Reply Quote 0
      • Craigrobboundefined
        Craigrobbo @jay_s_uk
        @jay_s_uk said in BIQU microprobe issues:
        Hi, So As per advice I have upgraded to 3.5.2 - It hasn't fixed the issue but at lest I am now on the latest firmware.
        The current code I am using is what I have posted in my very first post, I am open to trying any other suggestions you have.
        Thank you for the help
          This post is deleted!
            While I have been having a play this evening, I tried your S280 commands again from your guide and this just causes very erratic behaviour, sometimes the probe deploys sometimes it doesn't then sometimes it randomly deploys and retracts on its own...
            very strange.
            oliofundefined jay_s_ukundefined droftartsundefined Craigrobboundefined 5 Replies Last reply Reply Quote 0
            • oliofundefined
              oliof @Craigrobbo
              @Craigrobbo your probe might pick up electrical noise.
              Craigrobboundefined 2 Replies Last reply Reply Quote 0
                @Craigrobbo as I've already said, your M950 command is wrong. You also don't use M280 but M42. Make sure you're reading the info for the microprobe and not the bltouch!
                  droftarts administrators @Craigrobbo
                  @Craigrobbo Make sure you're clicking on the 'BTT MicroProbe' tab on this page: https://teamgloomy.github.io/fly_e3_pro_v3_bltouch_3_5.html#micro
                  And make sure you know whether you have a V1 or V2 MicroProbe; I'm assuming it's a V2.
                  As @jay_s_uk pointed out, your configuration is wrong. You have:
                  M950 S0 C"duex.pwm5"
                  M558 P5 C"^!zprobe.in" H3 F250 T6000 A10 R1.25 S0.008 ; Set Z probe type/mode 9. H=Dive Height. F=Speed probe speed,
                  It should be
                  M950 P0 C"duex.pwm5"
                  M558 P9 C"^!zprobe.in" H3 F250 T6000 A10 R1.25 S0.008  ; Set Z probe type/mode 9. H=Dive Height. F=Speed probe speed,
                  Also, add the G4 P500 pause to deployprobe.g and retractprobe.g:
                  ;deployprobe.g
                  M42 P0 S1
                  G4 P500
                  ;retractprobe.g
                  M42 P0 S0
                  G4 P500
                  Don't use M280 to deploy or retract the probe. If it still doesn't work, post pictures of your wiring at each end.
                    Craigrobbo @oliof
                    What should my M950 be?
                    *edit I replied to the wrong quote sorry!
                    oliofundefined Craigrobboundefined 2 Replies Last reply Reply Quote 0
                    • oliofundefined
                      oliof @Craigrobbo
                      @Craigrobbo that's got nothing to do with the configuration, but how your wires are run; i.e. if they run close to motor wires for a longer section. Best to try and get rid of that by either rerouting the wiring or by adding a ferrite bead.
                        Craigrobbo @Craigrobbo
                        @Craigrobbo said in BIQU microprobe issues:
                        very strange.
                        I thought this but its too consistent when it happens.
                        @droftarts said in BIQU microprobe issues:
                        G4 P500
                        I tried this thank you.
                        Unfortunately this also does weird things, So it homes, the probe comes out then it retracts on its own before the bed even touches it...
                        Now for an experiment I tried to touch the probe myself as to mimic a bed home and it just instantly deploys again, and again and will just indefinitely deploy every time i press it in without ever homing...HOWEVER if i let it just randomly retract on its own then it saves the home position... very very very strange.
                        As for wiring its currently tucked away but I am confident it is right.
                        I have it wired identical to my BLtouch (which works perfectly if i plug that in, so this confirms my wiring is right)
                        s for if its a V1 or 2 I m not sure but i bought it about 6 months ago?
                          Craigrobbo @oliof
                          @oliof said in BIQU microprobe issues:
                          I tried both P5 and P9 as mentioned I am going though different suggestions of code, P5 gives me less erratic results but P9 just sends the machine heywire doing random weird stuff and deploys and retracts on its own.
                          Its really strange, when in P5 mode the probe detects when its been touched, however in P9 mode it does not p9 makes it randomly deply, but P5 deploys once then never comes back for its second touch and then i get the error (probe already triggered at start of move)
                          With p9 it just never homes
                            very strange.
                            I thought this too, was one of the first things I checked, i isolated the loom but this didnt help, also the results while random are repetable in terms of how it reacts to different commands and the timing of them
                              Sorry, i replied to the wrong quote, I meant to reply to the next one - I did seperate the wiring to mitigate it, also tried an actual BL touch and this works fine
                              • oliofundefined
                                oliof @Craigrobbo
                                @Craigrobbo are you saying BLTouch works after separating out the wiring, or Microprobe, or both?
                                Craigrobboundefined 1 Reply Last reply Reply Quote 0
                                  Craigrobbo @oliof
                                  The BLtouch worked when the cables re within the wiring loom and the same when seperated too.
                                  • Phaedruxundefined Phaedrux marked this topic as a regular topic
                                  • infiniteloopundefined infiniteloop referenced this topic
