    RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
    Beta Firmware
    14
    83
    6.7k
      dc42 administrators @balajiramani
      @balajiramani are you definitely running the 3.6.0-alpha.4 build? There was a minor bug in G32 calibration on deltas in early 3.6.0 alpha builds but I fixed that some time ago.
      balajiramaniundefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @DonStauffer
        @DonStauffer does that same macro work if you invoke it from the DWC command line using M98?
        DonStaufferundefined 1 Reply Last reply Reply Quote 0
        • balajiramaniundefined
          balajiramani @dc42
          @dc42 Yes, I downloaded it from the latest link you posted. Here is a screenshot.
            @balajiramani my delta is working perfectly with alpha.4. Please post your bed.g file and provide more details about when the probing sequence goes wrong.
              balajiramani @dc42
              @dc42 Here is a video that shows the crash - https://forum.duet3d.com/assets/uploads/files/1721977512327-pxl_20240726_065615215-2.mp4. The motion from from one probe point to the other is more of a 'U' shaped travel, instead of a straight line.
              Let me know if you need any other information.
              Here is bed.g file.
              M561						; clear any bed transform, otherwise homing may be at the wrong height
              M290 R0 S0			; Remove any baby stepping
              ; bed.g file for RepRapFirmware, generated by Escher3D calculator
              ; 16 points, 4 factors, probing radius: 150, probe offset (0, 0)
              ; If the printer hasn't been homed, home it
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                G28
              ; Probe the bed and do auto calibration
              G1 X0 Y0 Z10 F10000        ; go to just above the first probe point
              while true
                if iterations = 5
                  abort "Too many auto calibration attempts"
                G30 P0 X0.00 Y150.00 Z-99999 H0
                if result != 0
                  continue
                G30 P1 X96.42 Y114.91 Z-99999 H0
                if result != 0
                  continue
                G30 P2 X147.72 Y26.05 Z-99999 H0
                if result != 0
                  continue
                G30 P3 X129.90 Y-75.00 Z-99999 H0
                if result != 0
                  continue
                G30 P4 X51.30 Y-140.95 Z-99999 H0
                if result != 0
                  continue
                G30 P5 X-51.30 Y-140.95 Z-99999 H0
                if result != 0
                  continue
                G30 P6 X-129.90 Y-75.00 Z-99999 H0
                if result != 0
                  continue
                G30 P7 X-147.72 Y26.05 Z-99999 H0
                if result != 0
                  continue
                G30 P8 X-96.42 Y114.91 Z-99999 H0
                if result != 0
                  continue
                G30 P9 X0.00 Y75.00 Z-99999 H0
                if result != 0
                  continue
                G30 P10 X64.95 Y37.50 Z-99999 H0
                if result != 0
                  continue
                G30 P11 X64.95 Y-37.50 Z-99999 H0
                if result != 0
                  continue
                G30 P12 X0.00 Y-75.00 Z-99999 H0
                if result != 0
                  continue
                G30 P13 X-64.95 Y-37.50 Z-99999 H0
                if result != 0
                  continue
                G30 P14 X-64.95 Y37.50 Z-99999 H0
                if result != 0
                  continue
                G30 P15 X0 Y0 Z-99999 S6
                if result != 0
                  continue
                if move.calibration.initial.deviation <= 0.03
                  break
                echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
              ; end loop
              echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                @balajiramani it sounds to me that segmentation is not working on those moves. If you send M669 without parameters, what does it report?
                  balajiramani @dc42
                  @dc42 Here is what I see:
                  M669
                  Kinematics is Linear delta, 100 segments/sec, min. segment length 0.20mm
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @balajiramani
                    @dc42 Just had time to TRY a print with the alpha.4 binaries you uploaded the other day (on both the D3 Mini & the 1LC), and the bed leveling seems to be working.
                    BUT now the extruder won't extrude (or retract for that matter), either through G-code or if I to use the "extrude buttons" in DWC & PD.
                    When I canceled the print on PD i got these error messages:
                    CAN response timeout: board 121, req type 6044, RID 220.
                    Error: at column 2: G10: hA
                    CAN response timeout: board 121, req type 6029, RID 222
                    CAN response timeout: board 121, req type 6044, RID 223
                    Which is new behaviour from alpha.2+3.
                    AND the hotend heater (connected to the 1LC) won't turn off. Both DWC & PD show active/standby heat to be 0, but the heater is still at working temp (255c).
                    If i manually try to input 0 in active on DWC and push enter i get this error:
                    M568 P0 S0
                    Error:  at column 2: M568: P
                    The only way I've found to actually make it turn off/adjust the temp down is to power toggle or restart the printer.
                    gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                    • gloomyandyundefined
                      gloomyandy @Exerqtor
                      @Exerqtor What version of the firmware do you have installed on the 1LC?
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        @gloomyandy said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                        @Exerqtor said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                        To be more specific:
                        M122 B121
                        Diagnostics for board 121:
                        Duet TOOL1LC rev 1.1 or later firmware version 3.6.0-alpha.4 (2024-08-13 12:30:07)
                        Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                        I just tested if the extrusion works while idle, which it does. I'm about to start a new test print (same job g-code as earlier) and see what happens.
                        Here is a couple M122's from BEFORE starting the print:
                        M122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-alpha.4 (2024-08-13 15:11:57) running on Duet 3 Mini5plus WiFi (standalone mode)
                        Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
                        Used output buffers: 16 of 40 (37 max)
                        Static ram: 92296
                        Dynamic ram: 94544 of which 0 recycled
                        Never used RAM 50316, free system stack 142 words
                        Tasks: NETWORK(2,nWait 7,16.7%,211) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,247) TMC(4,nWait 6,0.9%,65) CanReceiv(6,nWait 1,0.1%,792) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,339) MAIN(1,running,80.5%,665) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.8%,259), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:17:06 ago, cause: software
                        Last software reset at 2024-08-14 18:13, reason: User, Gcodes spinning, available RAM 52872, slot 2
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x00
                        Aux0 errors 0,1,0
                        MCU temperature: min 41.0, current 44.0, max 46.0
                        Supply voltage: min 2.8, current 24.2, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/34, heap memory allocated/used/recyclable 2048/696/252, gc cycles 232
                        Events: 0 queued, 0 completed
                        Date/time: 2024-08-14 18:30:13
                        Slowest loop: 49.66ms; fastest: 0.11ms
                        === Storage ===
                        Free file entries: 18
                        SD card longest read time 8.0ms, write time 9.5ms, max retries 0
                        Segments created 33, maxWait 232923ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00, mcet 0.012
                        Pos req/act/dcf: 10.00/10/0.00 -27991.00/-27991/0.00 4000.00/4000/0.00
                        no step interrupt scheduled
                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 53987, writes 38, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 53987, writes 38, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 54001, writes 24, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 54001, writes 23, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 54002, writes 23, timeouts 0, DMA errors 0, CC errors 0
                        Driver 5: not present
                        Driver 6: not present
                        === DDARing 0 ===
                        Scheduled moves 63, completed 63, LaErrors 0, Underruns [0, 0, 0]
                        === DDARing 1 ===
                        Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
                        Heater 0 is on, I-accum = 0.5
                        Heater 1 is on, I-accum = 0.0
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is doing "G4 P250" in state(s) 0 0, running macro
                        Aux2 is idle in state(s) 0
                        File2 is idle in state(s) 0
                        Queue2 is idle in state(s) 0
                        Q0 segments left 0, axes/extruders owned 0x0000803
                        Code queue 0 is empty
                        Code queue 1 is empty
                        === Filament sensors ===
                        check 0 clear 0
                        Extruder 0 sensor: no filament
                        === CAN ===
                        Messages queued 9333, received 21187, lost 0, ignored 0, errs 1318, boc 0
                        Longest wait 6ms for reply type 6024, peak Tx sync delay 10502, free buffers 26 (min 25), ts 5135/5133/0
                        Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
                        === Network ===
                        Slowest loop: 19.26ms; fastest: 0.00ms
                        Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        === WiFi ===
                        Interface state: active
                        Module is connected to access point
                        Failed messages: pending 0, notrdy 0, noresp 0
                        Firmware version 2.1.0
                        MAC address c4:5b:be:ce:91:93
                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39620
                        WiFi IP address 192.168.30.50
                        Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
                        Clock register 00002001
                        M122 B121
                        All averaging filters OK
                        Never used RAM 7956, free system stack 92 words
                        Tasks: Move(3,nWait 7,0.0%,100) TMC(2,delaying,3.6%,52) HEAT(2,nWait 6,0.4%,98) CanAsync(5,nWait 4,0.0%,54) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) MAIN(1,running,91.0%,318) IDLE(0,ready,0.0%,26) AIN(2,delaying,5.0%,112), total 100.0%
                        Owned mutexes:
                        Last reset 00:17:09 ago, cause: power up
                        Last software reset at 2024-03-12 16:55, reason: StackOverflow, available RAM 2968, slot 0
                        Software reset code 0x0100 ICSR 0x0042600e SP 0x20007f34 Task Move Freestk 3342 ok
                        Stack: 20004a80 20004ab4 0001cf33 20004c98 20004938 00000000 0001c011 20003320 fffffffd a5a5a5a5 00000000 20007f8c 00000000 20007f8c 0001cc97 00000000 200017c4 20001748 0001c4d7 20001748 200017c4 00000032 454c4449 00022700 0001ac77 200018e0 200018e0
                        Driver 0: pos 34130, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 37260, writes 3, timeouts 0, DMA errors 0, CC errors 0
                        Moves scheduled 4, hiccups 0 (0.00ms), segs 3, step errors 0 (types 0x0), maxLate 0 maxPrep 96, ebfmin 0.00 max 0.00
                        Peak sync jitter -2/9, peak Rx sync delay 222, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 3857541807 ticks, disabled
                        VIN voltage: min 23.8, current 24.7, max 25.2
                        MCU temperature: min 60.4C, current 64.1C, max 65.5C
                        Last sensors broadcast 0x00000012 found 2 165 ticks ago, 0 ordering errs, loop time 0
                        CAN messages queued 15059, send timeouts 0, received 6624, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 294, adv 37049/37148
                        Accelerometer: LIS3DH, status: 00
                        I2C bus errors 0, naks 0, contentions 0, other errors 0
                        Interrupt 5726621 to 0us, poll 5 to 1268us
                        Driver 0: ok
                        EDIT:
                        I've got no idea what was going on earlier, because now it extrudes like it should 😶
                        I'm letting the test print finish to see what's going to happen.
                        • DonStaufferundefined
                          DonStauffer @dc42
                          @dc42 I didn't try it and I reverted to alpha 2. It's called from the last few lines in config.g so I didn't think it would be different.
                          I reinstalled alpha 4 and yes, the error occurs on the M260 lines when the macro is invoked from the console using M98.
                            @DonStauffer my apologies, I accidentally disabled M260 in that build. I will reinstate it in the next build. Meanwhile, M260.0 should do what you want in alpha 4.
                            DonStaufferundefined 2 Replies Last reply Reply Quote 0
                            • edspedundefined
                              edsped
                              Am I the only one having connection interrupted errors with the most recent build? I'm hard wired into a Ubiquiti network if that matters.
                              Bed leveling is working as intended.
                              Controller MB6HC using built in wired network.
                              Jubilee toolchanger with (4) RRF-36's running the tools.
                              M12 after a few "Connection Interrupted" errors
                              m122
                              RepRapFirmware for Duet 3 MB6HC version 3.6.0-alpha.4 (2024-08-13 15:11:47) running on Duet 3 MB6HC v1.02 or 1.02a (standalone mode)
                              Board ID: 08DJM-9P63L-DJ3T8-6J1F2-3SS6J-KA6VB
                              Used output buffers: 1 of 40 (38 max)
                              Static ram: 133840
                              Dynamic ram: 128256 of which 128 recycled
                              Never used RAM 57328, free system stack 103 words
                              Tasks: NETWORK(1,ready,35.9%,182) ETHERNET(5,nWait 7,0.1%,311) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.3%,209) TMC(4,nWait 6,8.5%,53) CanReceiv(6,nWait 1,0.1%,767) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) MAIN(1,running,55.0%,103) IDLE(0,ready,0.0%,29), total 100.0%
                              Owned mutexes:
                              Last reset 00:39:59 ago, cause: power up
                              Last software reset at 2024-08-02 12:23, reason: User, Gcodes spinning, available RAM 62628, slot 1
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 10.7, current 31.1, max 31.4
                              Supply voltage: min 24.0, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.0, current 12.2, max 12.5, under voltage events: 0
                              Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/312/264, gc cycles 0
                              Date/time: 2024-08-16 07:22:24
                              Slowest loop: 224.31ms; fastest: 0.05ms
                              === Storage ===
                              Free file entries: 19
                              SD card longest read time 3.0ms, write time 4.8ms, max retries 0
                              Segments created 381, maxWait 819860ms, bed comp in use: mesh, height map offset 0.000, hiccups added 0 (0.00ms), max steps late 1, ebfmin 0.00, ebfmax 0.00, mcet 0.087
                              Pos req/act/dcf: 58485.00/66365/-0.04 15858.00/15858/0.04 1934.00/1938/-0.97 0.00/0/0.00
                              next step interrupt due in 1 ticks, disabled
                              Driver 0: ok, SG min 0, mspos 327, reads 49227, writes 26 timeouts 0
                              Driver 1: standstill, SG min 0, mspos 276, reads 49227, writes 26 timeouts 0
                              Driver 2: standstill, SG min 0, mspos 352, reads 49231, writes 22 timeouts 0
                              Driver 3: ok, SG min 0, mspos 1007, reads 49228, writes 26 timeouts 0
                              Driver 4: ok, SG min 0, mspos 255, reads 49228, writes 26 timeouts 0
                              Driver 5: ok, SG min 0, mspos 271, reads 49228, writes 26 timeouts 0
                              === DDARing 0 ===
                              Scheduled moves 18403, completed 18344, LaErrors 0, Underruns [0, 0, 0]
                              === DDARing 1 ===
                              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                              Heater 0 is on, I-accum = 0.2
                              File is idle in state(s) 3
                              Daemon is idle in state(s) 0
                              Q0 segments left 11, axes/extruders owned 0x80000007
                              === CAN ===
                              Messages queued 39620, received 192185, lost 0, ignored 0, errs 791, boc 0
                              Longest wait 2ms for reply type 6031, peak Tx sync delay 61333, free buffers 50 (min 49), ts 11997/11996/0
                              Tx timeouts 0,0,0,0,0,0
                              === Network ===
                              Slowest loop: 193.94ms; fastest: 0.03ms
                              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                              HTTP sessions: 2 of 8
                              = Ethernet =
                              Error counts: 0 0 0 1 0 0
                              === WiFi ===
                              Interface state: disabled
                              Module is disabled
                              === Multicast handler ===
                              Responder is inactive, messages received 0, responses 0
                              edspedundefined 1 Reply Last reply Reply Quote 0
                              • edspedundefined
                                edsped @edsped
                                @edsped said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                                Not sure what's going on, I reverted back to 3.5.2 and the dropped connection persists.. All works well using the paneldue but the web interface is all but unusable and sometimes I'm unable to reconnect for several minutes. Not sure what got hosed but something is surely borked.
                                  dc42 administrators @edsped
                                  @edsped I see connection errors too. Do your connections errors go away if you put the PanelDue on the Setup page so that it stops polling the 6HC?
                                  edspedundefined 3 Replies Last reply Reply Quote 0
                                  • edspedundefined
                                    edsped @dc42
                                    @dc42 I'm working through it now. Some of my issues appear to be related to running the Jubilee on an IOT network... I've had ongoing connection issues with the paneldue and leave it disconnected unless I have issues with the web interface. I'll follow up once I get my network in order and run a few tests.
                                    • edspedundefined
                                      edsped @dc42
                                      @dc42 Still getting connection errors. Paneldue is disconnected FWIW.
                                      • edspedundefined
                                        edsped @dc42
                                        @dc42 Did a fair amount of reworking of my network and I'm 45 minutes into a print without a disconnect... I believe my issue was more networking than the alpha firmware. Next try, running DWC and the Paneldue together.
                                          DonStauffer @dc42
                                          @dc42 Thanks for the information.
                                            balajiramani
                                            Hi am seeing a new error today. A few minutes into a print, the printer stopped with the following error:
                                            Error: Movement halted because a step timing error occurred (code 3). Please reset the controller.
                                            Here is the output of M122 after that:
                                            8/18/2024, 5:05:27 PM   M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-alpha.4 (2024-08-13 15:11:39) running on Duet WiFi 1.0 or 1.01
                                            Board ID: 08DAM-999TL-MQ4SD-6JTDL-3SS6N-968BX
                                            Used output buffers: 12 of 26 (21 max)
                                            Static ram: 23368
                                            Dynamic ram: 66976 of which 12 recycled
                                            Never used RAM 16440, free system stack 112 words
                                            Tasks: NETWORK(2,nWait 6,15.9%,195) HEAT(3,nWait 5,0.1%,328) Move(4,invalid,1.1%,272) MAIN(1,running,82.9%,744) IDLE(0,ready,0.0%,29), total 100.0%
                                            Last reset 01:00:54 ago, cause: power up
                                            Last software reset at 2024-08-09 19:04, reason: User, Gcodes spinning, available RAM 13844, slot 2
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            MCU temperature: min 38.2, current 46.3, max 49.1
                                            Supply voltage: min 23.5, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/1184/1096, gc cycles 1
                                            Date/time: 2024-08-18 17:05:26
                                            Slowest loop: 226.73ms; fastest: 0.13ms
                                            === Storage ===
                                            Free file entries: 8
                                            SD card longest read time 6.2ms, write time 4.3ms, max retries 0
                                            Segments created 470, maxWait 2498505ms, bed comp in use: none, height map offset 0.000, hiccups added 1 (0.03ms), max steps late 0, ebfmin 0.00, ebfmax 0.00, mcet 0.085
                                            Pos req/act/dcf: 68507.00/68479/0.99 65547.00/65566/-0.81 65391.00/65409/-0.99
                                            Driver 4: standstill, SG min n/a
                                            Driver 5:
                                            Driver 6:
                                            Driver 7:
                                            Driver 8:
                                            Driver 9:
                                            Driver 10:
                                            Driver 11:
                                            === DDARing 0 ===
                                            Scheduled moves 69133, completed 69131, LaErrors 0, Underruns [0, 0, 0]
                                            Heater 0 is on, I-accum = 0.0
                                            Heater 1 is on, I-accum = 0.2
                                            File is doing "G1 X-13.401 Y-8.549" in state(s) 0
                                            Q0 segments left 1
                                            === Network ===
                                            Slowest loop: 208.96ms; fastest: 0.00ms
                                            Responder states: HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                            === WiFi ===
                                            MAC address 5c:cf:7f:2c:25:00
                                            Module reset reason: Turned on by main processor, Vcc 3.40, flash size 4194304, free heap 40988
                                            WiFi IP address 192.168.1.61
                                            Signal strength -36dBm, channel 6, mode 802.11n, reconnections 0
                                            Clock register 00002002
