    Z-axis / tramming issues with 3.6.0-alpha2+3
    Beta Firmware
    2.1k
    • edspedundefined
      edsped @dc42
      @dc42 Still seeing accumulation on one of the leadscrews so I'm hesitant to test...
      • edspedundefined
        edsped @dc42
        @dc42 Same iterations on 3.5.2
        • o_lampeundefined
          o_lampe @dc42
          @dc42 said in Z-axis / tramming issues with 3.6.0-alpha2+3:
          The issue with bed tramming might be fixed. I don't have a suitable machine to test it on.
          IIRC, the problem was also seen on a Delta printer...that's why I hesitate to test 3.6.a+
            dc42 administrators @o_lampe
            @o_lampe no this issue does not affect deltas.
              dc42 administrators @edsped
              @edsped thanks, looks like it's adjusting the 3rd leadscrew the wrong way on the second and subsequent iterations.
                dc42 administrators @dc42
                I have now reproduced and fixed this issue. I've prepared a new alpha release which I hope to make available tomorrow after some internal testing.
                Exerqtorundefined edspedundefined 2 Replies Last reply Reply Quote 2
                • Exerqtorundefined
                  Exerqtor @dc42
                  @dc42 Sweet, i just saw the commits and was about to ask for a build, but i'll wait til you've done the internal one 😃
                  • edspedundefined
                    edsped @dc42
                    @dc42 Awesome, looking forward to giving it a try as improved input shaping looks very promising.
                    Running a 6HC board FWIW.
                      I've put 3.6.0-alpha.4 binaries at https://www.dropbox.com/scl/fo/cckwiq91gn16hvl1zdjnp/AF0SMEtkVfiArSPeYaBDGPY?rlkey=kqkknk9q1kiq684u4s55ce8d4&dl=0. Release notes are at https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-alpha4-in-preparation.
                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                      • Exerqtorundefined
                        Exerqtor @dc42
                        I've tried a couple "dry runs" now and it's been behaving so far at least.
                        • edspedundefined
                          edsped
                          I have a couple of test runs on mine now as well and tramming appears to be working as it should. For some reason input shaping doesn't seem as good as on earlier versions but will play more to verify.
                          • edspedundefined
                            edsped
                            On a side note I seem to be getting a lot of connection interrupted errors, pretty much the same as I get when running a web control and paneldue simultaneously, though paneldue has been disconnected for many months now.
                            Edit: Setup, Jubilee with MB6HC and (4) RRF 36 connected tools
                            • edspedundefined
                              edsped
                              Been printing on and off for several prints and knock on wood haven't had any tramming issues. Print quality is also very much improved over 3.52. Looking forward to further improvements.
